Old 04-04-2009, 08:18 PM   #1
30' 1999 Excella
Tin Diesel's Avatar
Kingwood , Texas
Send a message via Yahoo to Tin Diesel
Air pumps - manual
We've had our Airstream for four years now, and the job I hate most is checking tire pressure. Not that the checking part is hard, its the topping off.
If we're home, it means dragging out the air compressor lines to reach all the way to the driveway. If we're on the road, it means pulling out the 12V pump and the 12V extension cord - not to mention that the little 12V bugger is NOISY! Not a good thing to do in the early morning in a crowded campground when you're getting ready to leave.
And all that for what is usually 1/2 or 1 PSI needed per tire!
If have found the solution for topping off - a simple manual 'sport' pump like THIS ONE. There's a dozen listed online, but this one would work fine.
At first, I thought I'd be pumping 'till I popped (not the tire). However, this little unit pumped my 75 PSI tires on my F250 very easily - 10 strokes for 1 PSI. (These sport pumps can pump up to 150 PSI for high-performance racing bicycles).
On the Airstream, it was even easier - maybe 8 strokes for 1 PSI.
Obvioulsy you wouldn't want to use it for a complete flat, but for a quick check in the morning, its great. Lightweight - easy to store in the rear compartment. Also, nice to have as a backup - manual gadgets tend to work when you need them!
Just thought I'd mention it....
Hey, its the only way to be sure!
Tin Diesel is offline   Reply With Quote
Old 04-10-2009, 09:15 AM   #2
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
The link didn't go to a pump, however I believe most will search for it on that site.
Good idea thanks for the post.
>>>>>>>>>>>>>>>Action
Old 04-10-2009, 11:01 AM   #3
1963 24' Tradewind
San Diego , California
Nice to have one as a backup, you never know!!
Sixty3TW4US is offline   Reply With Quote
Old 04-11-2009, 02:57 PM   #4
30' 1999 Excella
Tin Diesel's Avatar
Kingwood , Texas
sorry about the link problem.
Here's another try:
Blackburn TPS-2 Floor Pump @ Performance Bicycle
fuel pump location? jagcb750 Classic Motorhomes 17 12-17-2010 12:57 PM
Sewer fixtures for black/grey water pumps beerrun'r Waste Systems, Tanks & Totes 0 02-27-2009 01:40 PM
Mid 60s Water Pumps mountaindove Fresh Water Systems 10 09-16-2007 06:12 PM
Water Pumps, Hydroboosts and Automobiles swebster Mechanics Corner - Engines, Transmission & More... 32 02-19-2006 09:43 PM
Fuel Pumps 85/345 Mechanics Corner - Engines, Transmission & More... 2 12-13-2004 07:21 PM
