Old 07-31-2007, 10:15 PM   #1
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Air In Your Spare?
Hi, Sunday I was under my trailer reinstalling my Equal-i-zer street side brackets; You know, moveing the gas line Etc. While under there I pushed on my spare tire with my hand and decided that it didn't feel hard enough. My trailer is almost three years old and I have not even looked at my spare, except to see if someone stole it. So I took it, down and out, to check the pressure and it was at 20 lbs. This would have been just enough pressure to replace a flat with another flat.
Fortunately, I never had to use my spare yet; And with all the posted tire concerns, I thought that I should post my bad example to, maybe, help save someone else who might not admit neglet of their spare tire.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 08-01-2007, 12:59 AM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Thumbs up Good Point!
I have an extension hose on my spare that lets me check the pressure right from the frame (easy to reach without crawling under the trailer) and quickly unscrews from the valve stem if you have to use the spare.
IIRC, it is a Dicor product, but most good auto parts shops should carry them also.
Old 08-01-2007, 01:59 AM   #3
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Good reminder! Thanx...
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 08-01-2007, 03:50 AM   #4
Cyclist
henw's Avatar
2007 28' International CCD
Windermere , Florida
I carry a small air compressor just for such suprises on the road.
henw is offline   Reply With Quote
Old 08-01-2007, 05:05 AM   #5
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
I towed without a spare for the first 5000 miles. I just had one shipped in last week form Southwest Wheel out of Dallas. Remember to place it back in the carrier with the valve down and facing to the front so you can reach it with out taking the tire out.
I always knew I could tow on 3 tires and carried a tire repair kit and air compressor, I didn’t think I was taking much of a risk. Even with a spare I would plug the tire and air it up instead of changing the tire, changing the tire is to much work. Now a blow out is where the spare would come into play.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 08-01-2007, 05:26 AM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Jim, a roll of duct tape would be a good idea if you have a blowout, in case debris knocks stuff loose when the tire comes apart. No, you can't fix the flat with duct tape, I've seen it tried, though.
Old 08-01-2007, 05:59 AM   #7
Jim Clark's Avatar
My son just returned form Scout Camp and he picked up 5 merit badges. He also received the Duck Tape Merit Badge which is not accredit but did come with a patch and two wallets he made. Of course he wants the badge sewn on his sash with the real ones.
Jim N5TJZ Air# 174
2011 F150 Ecoboost
Old 08-01-2007, 08:31 AM   #8
USN/LAPD Retired
Safari-Rick's Avatar
North Las Vegas , United States
It's odd sometimes that you go for periods at a time without checking something and then you get a "feeling" that you better. Well, I'm glad that I did check the spare as I needed it coming home from the summer rally. (see picture below). I am now a BIG fan of checking my spare each time I get ready to use the AS.
2007 Dodge Ram Quadcab 6.7L Diesel w/jakebrake
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
Old 08-01-2007, 10:57 AM   #9
lewster's Avatar
Get a Pressure Pro systym and add a sensor on the spare also. This way, you can check the pressure anytime from the receiver on the dash and you will get an alert if the pressure drops below 12.5%. Also a good idea on the TV's spare tire.
Old 08-01-2007, 02:20 PM   #10
1989 34.5' Airstream 345
Chantilly , Virginia
Tire Fix and slow leak finding
I recommend keeping a Tire repair kit. Don't use the fix a flats, they just make a mess. Get a set with the self vulcanizing strips, the plunger file(to roughen up the hole), and the strip inserter, And get a can of tire contact cement to wipe on the strips as well before inserting. It will last for thousands of miles. We have used them on gravel roads around our farm without fail for years! They do not work on sidewall cuts, but for nail and screw holes they work great. It is best to insert them with the tire mostly inflated.
To do this feed the strip into the insertion tool(the part your fingers touch on one end will be useless, but you have plenty if you have the 4" strips.
Pull the strip until it is just over halfway through.
Then brush on the tire contact cement.
Then pull whatever is causing the leak out(if it is longer than 1/2 inch, you may have to repeat until you have 2 or 3 strips together).
insert the roughing tool one or two times.
Insert the strip until it is about one inch inside, them pull the inserter tool out.
If you are at a gas station or have a compressor, fill the tire to its normal pressure.
wait 5 minutes then trim off the excess leaving just a little above the tread.
Then Hit the road!
One great way to find out if you have a slow leak is get a soda bottle or sprayer bottle. Fill with a tablespoon of dish washing soap then fill up with water. Give it a shake and then spray the soap solution all over the leaking tire. Wait for 10 minutes or 1/2 hour and you will see a small pile of bubbles over the leak. if using the soda bottle, cut a small slice into the cap and just squeeze until the soap solution sprays out.
You may have to drive forward or backwards if the leak is under the tire.
Cheers, Peace and Happy Trails!
PeterKnop is offline   Reply With Quote
Old 08-01-2007, 04:12 PM   #11
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I check mine several times a season. Reading what I have about Goodyear Marathons, it's not a bad practice to follow.
Experiences with Carrier Air V installation? Sojourner Furnaces, Heaters, Fireplaces & Air Conditioning 10 04-29-2009 07:52 AM
spare tire? Chas Tires 14 07-04-2005 07:09 PM
rear air suspensiom problems wb13798 Airstream Motorhome Forums 19 03-03-2003 07:12 AM
Heater and Air Conditioner Jeb Airstream Motorhome Forums 2 10-22-2002 07:45 AM
Air streams in New York area?!? mitchm71 Our Community 0 07-25-2002 09:33 AM
