Old 09-15-2010, 10:19 PM   #15
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
It could be how you use it.
Hi, like others here on the forum I have several tire pressure gauges. And from time to time I compare readings. I have two pencil gauges that I keep in the Lincoln glove box, one is for cars [lower pressure reading] and the other is for trucks. [higher pressure reading] The car one is for my Lincoln and the truck one is for my trailer. I also have the inflater gauge that stays with my home compressor or the portable compressor when towing. I have a high dollar, dual foot, dial gauge, that is accurrate for low and high pressures; I bought this one for my P-30 "Mac Tools" truck with 19.5" wheels. For some reason, these wheels had odd openings and all of the dual foot truck gauges that I tried wouldn't fit correctly. So I had to make a calibrated bend in the air tube of the gauge to make it work. So, what this is all leading to is that if your gauge, or the angle in which you hold it, doesn't make a good seal, you will not get a correct reading. Anytime I use my gauges, and I know it didn't seal correctly, I do it again making sure it was a good seal, giving me a correct reading.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 09-17-2010, 04:48 AM   #16
r carl's Avatar
Lin , Ne
I rounded up my tire guages and there is a 10psi spread between them with none reading the same. I went to 3 tire shops and asked if they could tell me which one is accurate. The best they could do is 1 place said Bubba has a digital guage you can check yours against.
Name:	tire guages.jpg
Old 09-17-2010, 05:32 AM   #17
richinny's Avatar
2011 34' Classic
so, how many of you lubricate your gauges?
Ricky
Old 09-17-2010, 05:39 AM   #18
r carl's Avatar
Lin , Ne
I think taking apart and cleaning is the way to maintain them. Lubing the rubber seals before assembly would work.
MicroPulse Calibration For Battery jeff4506 Batteries, Univolts, Converters & Inverters 9 03-06-2017 05:41 PM
Micro Pulse Tank monitor calibration Silvertwinkie Plumbing - Systems & Fixtures 98 11-03-2014 01:09 PM
Duo-Therm Thermostat out of calibration? silverback Furnaces, Heaters, Fireplaces & Air Conditioning 2 05-03-2009 05:55 AM
GM Gauge that will tell you EVERYTHING JeepinAudiophile Tow Vehicles 1 08-15-2005 02:38 PM
