Old 08-06-2005, 03:29 PM   #15
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Originally Posted by TomW
Why would a trailer be different?
What am I missing here?
Tom,
I think it has to do with the extreme load that is placed on the wheel. The side load on the trailer in corners and even sway is tremendous. There is also the issue of aluminum wheels needing to be checked more often for loose lugs....
That is my understanding anyhow
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 08-06-2005, 04:49 PM   #16
Ive pulled lots of trailers lots of miles and have found that the ninit I get out at any stop I walk back and just lay the palm of my hand against the center of the rim and touch the lugs also. If anything is wrong it will produce heat and you will be able to feel it easily. If its hot weater or you have been working the trailer hard like hills and mountains everything including tires will be warm but they wont be hot enough to say ouch. If they are, check further. Mac
slonezy is offline   Reply With Quote
Old 08-06-2005, 05:01 PM   #17
Palm check
The heat check was great advice!You see I have only 16mos. of trailering under my belt,& not alot of miles yet.The lug check I was told was a visual,just make sure they are there and it all looks right.This is also the first trailer I have ever pulled,or stayed in.Friendly advice is very welcomed.
Thanks all
cynthia is offline   Reply With Quote
Experiences with Carrier Air V installation? Sojourner Furnaces, Heaters, Fireplaces & Air Conditioning 10 04-29-2009 07:52 AM
Heater and Air Conditioner Jeb Airstream Motorhome Forums 2 10-22-2002 07:45 AM
cold weather how do air streams do? overlander Our Community 2 10-02-2002 05:10 AM
air horns uncleneal Airstream Motorhome Forums 1 08-16-2002 07:22 AM
Air streams in New York area?!? mitchm71 Our Community 0 07-25-2002 09:33 AM
