Old 10-07-2004, 06:04 AM   #1
jasper2222's Avatar
1996 25' Excella
Tallahassee , Florida
age of tires?
can anyone tell me the age of these tires. DOT 3DHH XC70203 A13R
Thanks, Richard
jasper2222 is offline   Reply With Quote
Old 10-07-2004, 07:04 AM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Lutz , Florida
Images: 21
Send a message via AIM to thenewkid64 Send a message via Yahoo to thenewkid64
To know the age of your tires, you can look at the date code on their sidewall. The date code is found in a marking that follows one of the following formats:
DOT XXXX XXX XXXX
first two characters: manufacturing plant identification mark
last four digits: date code (week / year)
The other characters are left at the manufacturer's discretion.
Example: DOT U2VK 3ML 2602: In this case, the tire has been manufactured on the 26th week of 2002 -- in other words, in June 2002.
DOT XXXX XXXX XXX (older three-digit date code format)
last three digits: date code (two for the week / one for the year)
Example: DOT P1RW B4LR 109: This particular tire was made on the 10th week of 1999.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 10-07-2004, 07:07 AM   #3
87MH's Avatar
1978 31' Sovereign
Images: 292
Best Guess (for free)
Cooper Tires mfg in Albany, GA the second week of 2003.
Cooper MIGHT be able to tell you load ratings, speed limitations, rim size, and max pressures for the tires.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
7 14.5 Tires Over59 Tires 28 08-17-2010 02:20 PM
Tires Causing Sway? Pick Tires 14 12-03-2006 04:38 PM
Tires good or bad? 72 Excella500 Tires 14 06-12-2004 03:16 PM
Questions about trailer tires... cactushead Tires 2 10-22-2003 05:58 PM
tires? trailer will sit after move goodgrey Tires 4 12-06-2002 02:10 PM
