Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 06-02-2006, 12:28 PM   #1
crazylev
LEV ZEPPELIN
crazylev's Avatar
Profile:  2004 19' International CCD
Chicago , Illinois
? about air preasure at gas stations...
Greetings.
Before each trip I check the tire preasure, among other things, before hitting the road. A couple of days before leaving, I ussually schlepp my portable(?) compressor with me in case the tires need topping off at 65#. This also means I have to schlepp my 50# Honda generator with me since the power outlet by my storage space area is now locked.
The reason I do this, is that the one time I went to a gas station last year to get some air, it seemed that the preasure in my tires was greater than the output of air at the station. It just was not putting any air in the 'ol donuts.
It was one of those units that you have to feed quarters. Do the compressors at Mobil et al even go up to 65#???
Am I destined to proceed like this, or was it merely an anomoly at this particular Mobil station?
Thanks.
Jonathan
I'm out of my mind right now, but will be returning shortly......
crazylev is offline   Reply With Quote
Old 06-02-2006, 12:42 PM   #2
Killo1
Killo1's Avatar
Profile:  2005 22' Safari
Santa Ana , California
Have you considered permanately mounting a 12v mobile air compressor on your trailer? You can get a pretty nice one for about $100. Get some extra hose and you could also refill your car tires if need be.
Alan
2005 22ft Safari
2003 Chevrolet Suburban Z71 5.3l
"Life is like a box of chocolates..." Forrest Gump
Killo1 is offline   Reply With Quote
Old 06-02-2006, 01:05 PM   #3
Tom Nugler
Tom Nugler's Avatar
Profile:  1967 20' Globetrotter
McHenry County , Illinois
Old School
Back when service stations really did service cars they had real compressors chugging away in back. The air in our shop is set to 120#. (How do you think we get lug nuts so tight?) I think the ones you plunk quarters into are pretty weak, if they work at all.
How about trying low tech and getting an old style foot pump at the auto parts joint?
Tom.
Airstream Forums Member # 2806
Not All Who Wander Are Lost.
Tom Nugler is offline   Reply With Quote
Old 06-02-2006, 01:07 PM   #4
crazylev
LEV ZEPPELIN
crazylev's Avatar
Chicago , Illinois
Hi Alan.
For me, everything is about weight. I don't have the most titantic of tow vehicles (VW Eurovan), therefore I try to do as much prep work first, and bring along as few things as possible.
Someday when I get something beefier I'll consider your idea, or just always bring my unit with me.
Jonathan
Old 06-02-2006, 01:07 PM   #5
klevan
klevan's Avatar
Profile:  Albuquerque , New Mexico
Which One Do You Recommend?
Killo1,
Which one do you recommend? The ones I've found appeared neither adequate nor nor substantial enough to be reliable over the long haul.
Ken Levan
2005 Chevy 2500 HD Duramax/Allison
Formerly WBCCI #8654
klevan is offline   Reply With Quote
Old 06-02-2006, 01:10 PM   #6
bake315
bake315's Avatar
Profile:  1994 34' Limited
Elgin , Texas
Images: 161
Thumbs up not a bad idea!
I uh, schlep, a small 12-volt rechargeable air compressor with me when I travel, but it really has to work hard to get air in to the tires. I'd like to find something a bit more permanent, and especially more rugged. With the exception of truck stops and some of the larger travel centers, I'd rather not have to try weaving the rig in and out of a gas station - they don't always put those air/water stations in the most convenient spots. probably would mount it in one of my truck's rear compartments as opposed to the trailer, and get one of those small retractible air hoses.
Cheers, Dave
"Finish."
AIR #4188
1994 34' Limited / 2002 Chevy 3500 CC 4x4 D/A Equal-i-zer Hitch / Jordan Ultima 2020
bake315 is offline   Reply With Quote
Old 06-02-2006, 01:16 PM   #7
crazylev
LEV ZEPPELIN
crazylev's Avatar
Chicago , Illinois
Hey Tom.
You just gave me an incredible idea.
I have a bike tire pump, the manual pump it yourself kind in my basement. It is made by Blackburn model #TPS-2. It is a pretty substantial pump, not the kind that goes on the frame of a bike.
There is a gauge on the pump that goes up to 160PSI (though I'm not sure if it would do that) I just need to get the tires to 65#.
The pump weighs in at about four pounds and would be easy to transport, and be handy to just top off a few pounds should the tires be low.
I'm going to try this this weekend as a test.
Jonathan
Old 06-02-2006, 01:26 PM   #8
crazylev
LEV ZEPPELIN
crazylev's Avatar
Chicago , Illinois
Well a quick phone call to Blackburn and they said they don't "support" using the pump I have for anything other than bikes.
I'm scratching my head wondering what would be the difference between pumping a bike tire to 40# or a car tire to 65#. They did confirm the pump was good to 140#
Am i missing something?
maybe a liability thing???
Jonathan
Old 06-02-2006, 01:29 PM   #9
madrone
Mad1
Profile:  1989 29' Excella
Dallas , Texas
I think you will find neither the bicycle pump or you have the needed duty cycle if that tire needs very much air at all. The "heat of compression" will soon destroy the pump
madrone is offline   Reply With Quote
Old 06-02-2006, 01:34 PM   #10
Tom Nugler
Tom Nugler's Avatar
Yea. That's what I was thinking of.
Years ago VW had a cigarette lighter pump as an accessory for the Camper. Haven't seen one in ages.
Tom.
Old 06-02-2006, 01:39 PM   #11
crazylev
LEV ZEPPELIN
crazylev's Avatar
Chicago , Illinois
Update:
A call to my local bike shop: You can use this pump on an auto type tire, and the guy that I talked with said he had done it himself.
BUT...
Since the volume of air in a big tube like the ones on the AS is MUCH larger than on a bicycle tire, it would take about a half hour just to get three pounds in there.
I was told that I would get a good work-out, but it can be done, in a pinch.
Not sure what "heat of compression" would do to a manual pump though.
Jonathan
Old 06-02-2006, 01:52 PM   #12
Killo1
Killo1's Avatar
Originally Posted by klevan
Killo1,
This link
Portable Air Compressors
seems to have the one I was to referring to. A lot of off roaders permanately install them under the hood.
Alan
2005 22ft Safari
Old 06-02-2006, 01:59 PM   #13
klevan
klevan's Avatar
This link
Thanks! That really fulfills the Airstreaming requirement as well as the off-roading requirements it appears to have been designed for.
Ken Levan
Old 06-02-2006, 02:03 PM   #14
AZstreamin
AZstreamin's Avatar
Profile:  2005 30' Safari
Chandler , Arizona
Jonathan,
This is the air compressor I purchased at Home Depot. $39.99 it is lightweight very portable and is rated at over 100psi. The down side is that it takes a little time to air up; I have found it to be effective. My plan is to add an on board air compressor and air tank to my truck. This will give me plenty of air and an I can add an air horn so all of those jack**** that like to pull-out right in front of me while talking on their cell phone will at least hear my 52' long rig in their rearview mirror.
[IMG]file:///C:/DOCUME%7E1/Brent/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG]
http://www.homedepot.com/prel80/HDUS...gng.0&MID=9876
AZstreamin is offline   Reply With Quote
gas valves gmlcjb LP Gas, Piping, Tanks & Regulators 5 07-17-2006 09:31 AM
Experiences with Carrier Air V installation? Sojourner Furnaces, Heaters, Fireplaces & Air Conditioning 2 03-09-2005 02:53 PM
Heater and Air Conditioner Jeb Airstream Motorhome Forums 2 10-22-2002 07:45 AM
Air streams in New York area?!? mitchm71 Our Community 0 07-25-2002 09:33 AM
Small gas gen sets FrankR Electrical - Systems, Generators, Batteries & Solar 0 04-12-2002 02:37 AM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
