Old 06-03-2006, 07:12 PM   #29
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Originally Posted by crazylev
When towing something like and AS, boat, or any heavy trailer, do you have to adjust tire preasure?
I'm assuming you are talking about the tow vehicle pressures. While I haven't weighed this van nor my current trailer, I am aware that the manufacturer of my tow vehicle has a recommend tire pressure on the driver's side door. Being one who brings along other items including the trailer, the load in the van not only includes the obvious hitch weight, but its passengers, grill, a full fuel tank, possibly Patty's electric cart, just to name some of the things.
Bottom line I want the van to be at its rated cargo capacity specs, so the answer to your question is yes, I check the tow vehicle tires before each trip and bring them up to manufacturers specs prior. I've never done wrong doing it that way and I have a high degree of comfort level when I hit the road.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 06-03-2006, 08:47 PM   #30
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
I usually bump the air in the rear tires of the van 3 psi when towing. I generally have the pressure higher anyway since I only use the van for towing or hauling stuff back from the home center, lumber yard ect.
Yes I DO remember the air fillers at the old service stations. Saw one up in Wisconsin last year. I am also an old enough fossil to remember when gas was 26 cents a gallon. 19 if there was a gas war. Now that's a phrase you don't hear any more.
Tom.
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 06-04-2006, 07:24 AM   #31
lewster's Avatar
Naples, FL , Hood River, OR
Yup!
Crank up that old handle to whatever pressure you wanted and listen to it 'ding-ding' while it filled. And 6 grades of Sunoco gas up to 101 octane. I sure miss those days!!
Anyway, every large truck stop like Flying J, T/A, Loves etc. has real air capacities. You also might just go down to your local tire shop to get a charge!
Old 06-04-2006, 07:28 AM   #32
ZoominC6's Avatar
Colleyville , Texas
Klevan, I looked at some of the compressors yesterday and they appear to be of high quality and much stronger than the little, cheap, emergency types we can purchase at auto supply shops. One was extremely small (no larger than a couple of fists) and could be mounted in the engine compartment I guess but I'll be darned if I could figure out where in my TV to mount it. One that was a little larger was equiped with a carry handle and stand with vibration isolation and a 35ft air hose with battery clamps from the compressor for easy attachment to your TV or trailer batteries. While very portable, it was also small enough, maybe 12" long at the largest dimension. Most were rated for 150psi. While I've always carried one the cheap varieties for the bikes and emergencys, I wonder how long before it would burn up should I run it for any length of time. Some of the larger units (not that much larger) had small air tanks and might be appropriate for mounting in a pickup bed or tool box. The units I looked over were sold by a four wheel drive specialty shop.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Experiences with Carrier Air V installation? Sojourner Furnaces, Heaters, Fireplaces & Air Conditioning 10 04-29-2009 07:52 AM
gas valves gmlcjb LP Gas, Piping, Tanks & Regulators 5 07-17-2006 09:31 AM
Heater and Air Conditioner Jeb Airstream Motorhome Forums 2 10-22-2002 07:45 AM
Air streams in New York area?!? mitchm71 Our Community 0 07-25-2002 09:33 AM
Small gas gen sets FrankR Electrical - Systems, Generators, Batteries & Solar 0 04-12-2002 02:37 AM
