Old 06-24-2011, 06:53 AM   #1
my3sonsdad's Avatar
1975 Argosy 26
Vienna , VIRGINIA
'97 Jeep GC / '70s Safari Tires
My 97 Jeep GC 5.2/v8 currently has Michelin LTX M/S P225/70r16 tires. I've read many of the tire threads here and on the Jeep forums and the recommendations seem to converge toward a LT 245/70r16 LR D or E. I plan to tow a 70's Safari. Will the P225's be sufficient or will I need to replace with the LTs?, thoughts on moving to 245s?
1975 Argosy 26
2015 Jeep GC Summit EcoDiesel w/Hensley
my3sonsdad is offline   Reply With Quote
Old 06-24-2011, 08:11 AM   #2
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I would go with the stock spec tire size. The 245 is much taller than the 225 and will hurt you in the hills. They do make an LT225 size tire.
The P tire is rated at 1703 lbs at 35 psi.
The LT tire is rated at 2640 at 50 lbs. This tire will ride a bit rough but there will be less squish in the sidewall. If you are towing long distances you may want to upgrade.
LTX M/S | Michelin Tires
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is online now   Reply With Quote
Old 08-03-2011, 07:32 AM   #3
my3sonsdad's Avatar
1975 Argosy 26
Vienna , VIRGINIA
TV Tire selection revisited
I am revisiting my TV tire decision as I ended up purchasing a Argosy 26 which is heavier than a Safari. When I checked the MS2 LTX I didn't see an LT in the current size but only a LT225/75R16/E which is rated at 2840 @ 80 lbs. Any thoughts on changing from a 70 to a 75? Would I gain any additional benefit of running with a Load E tire considering the JGC "squishy" suspension?
1968 GT tires that will fit... RECOMMENDED ALUMINUMINUM Tires 5 10-31-2011 11:30 AM
1955 Airstream Safari - Tires? Streamer55 Tires 4 07-06-2011 12:12 AM
Tires and Alignment Airstream12557 Land Yacht/Legacy Motorhomes 0 06-08-2011 05:04 AM
Replacement tires for 2006 Safari 23 Goal15 Tires 0 05-16-2011 12:45 PM
'70s Safari bertro Trailer Values 1 01-26-2011 03:05 PM
