Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 06-19-2010, 10:46 AM   #1
1969 27' Overlander
Sunny Skies , Rockies
7.00x15 replacement; 225 vs 205
From reading most of the tire threads on this forum, the concesus is that the 225/75R15 should be the replacement tire size for the 7.00x15 although a 205/75R15 is closer in size to the original.
I have a 69 overlander GW 4500lb empty and want to keep it close to stock.
Any light shed on this would be appreciated.
cheers
Marcello is offline   Reply With Quote
Old 06-19-2010, 10:54 AM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
225/75 is pretty much the standard but is smaller in diameter than the 700-15. ( but rated to carry more weight)
700-15 bias tires can probably still be found or ordered through your local farm supply store although you will probably be buying LT (light truck) tires.
At one time you could get 700-15 in a radial but I think they have pretty much disapeared.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 06-19-2010, 01:53 PM   #3
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I just went through the same decision making exercise you are going through. After a lot of looking, reading, and good advise from forum member TomW, I opted for the 225 Marathons. Tom had just replace the LT's on his Overlander with the same tire. I lost less than a 1/2 inch of height from the top of the wheel well opening to the ground.
Old 06-19-2010, 02:10 PM   #4
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
I just bought GYM 205/75R15 (LR-C) for my '58 Overlander. The 225s (LR-D) seemed a little too large and seemed like overkill for my Airstream.
I have the 225s on my 1972 '31 Sovereign and they are great for a trailer of that size and length.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
https://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 06-19-2010, 03:21 PM   #5
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Originally Posted by Marcello View Post
... Any light shed on this would be appreciated.
This somewhat current thread is good reading.
I will never go back to bias-ply tires after experiencing Marathon radial LR C's.
Tom
Old 06-19-2010, 04:16 PM   #6
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Yokohama makes a 700 x 15 LT radial and I think Toyo dose also. I have Yokohama's and they are great tires.
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
replacement for 7.00x15 - size advice SnoSheriff Tires 19 04-30-2011 05:27 AM
225-75-15 is this the right size to replace 7.00 x 15 F250PUP Tires 5 02-19-2010 03:51 AM
225/75R15 Goodyear Marathons do not fit. Silver 81 Tires 13 11-07-2009 11:00 AM
BF Goodrich Commercial T/A LT 225/75R16 Chitown AirStreamers Tires 7 07-29-2008 06:15 PM
7.00x15 6 ply Load Range D rasmuw Tires 21 04-08-2008 09:16 PM
