Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 04-03-2008, 01:30 PM   #1
1967 24' Tradewind
Blairstown , New Jersey
7.00x15 6 ply Load Range D
I need to replace the tires on my 1967 Trade Wind. the current tires on it are badly weathered. The tires on the wheels (which are original) are 7.00x15 6 ply load range D. I thought 6 ply were always load range C. I'm thinking of getting the Marathon 225/75/15 tire, load range C, as I am concerned about the warnings regarding splitting the rims if I were to upgrade the tire. I'm just confused about the tires on there now.
Wayne
rasmuw is offline   Reply With Quote
Old 04-03-2008, 01:40 PM   #2
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Do you have tandem axles. I have load range C on my tandem axle Trade Wind.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 04-03-2008, 01:41 PM   #3
1973 25' Tradewind
Romulus , New York
These tires are still available--The sidewalls are stiff and they hold 65 pounds of air. Radials flex more than these bias ply tires. I replaced mine with the goodyear 700x15 6 ply @ $87. each. They ride and track beautifully.
jayray5 is offline   Reply With Quote
Old 04-03-2008, 01:49 PM   #4
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
Boy am I glad that this came up. We are going to replace the tires on out 54 Cruiser and replace the split rims (cause they REALLY are split) and was wondering what size rim would I need to get for this tire?
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
Old 04-03-2008, 08:17 PM   #5
1967 24' Tradewind
Neil
I have tandem axles. What tire are you using, and what size?
Wayne
Old 04-03-2008, 08:28 PM   #6
1967 24' Tradewind
My old tires are Kelly Springfield Custom Armor Trac. They are rated at 2040 pounds at 60 psi. They are bias ply. What model Goodyear tire do you have? Are they radials?
Wayne
Old 04-03-2008, 10:38 PM   #7
FreshAir's Avatar
1966 24' Tradewind
Wayne
700 x 15 Power King Premium Highway, load range C. I bought them at Les Schwab Tires last October.
Neil.
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
Old 04-03-2008, 10:52 PM   #8
1987 29' Sovereign
Sparta , Tennessee
Send a message via Yahoo to wingfoot321
Rasmuw,
There are very few reasons to buy bias ply tires today. Number one to me would be an original restoration. Number two would be a sidewall penetration if you go off road a lot. Number three would be to get an exact same size tire.
Radials run cooler with less rolling resistance, turn nails much better but, the 225/75r15 is about 1/2 inch lower at the axle centerline which can cause the rear to drag.
You could buy load range c or d and just not inflate the lrd above 55psi.
wingfoot321 is offline   Reply With Quote
Old 04-04-2008, 06:34 AM   #9
1973 25' Tradewind
Romulus , New York
bias ply
I was told by the goodyear rep that I could replace my bias ply tires with the same thing. 700x15 6 ply d Bias ply 65psi.
Old 04-04-2008, 11:06 AM   #10
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
I just checked last night and I have 7.00-15 LT's on my trailer. Dual axles. Now I am a little worried that the LT's should be replaced for ST's.
When I got them I specifically asked for trailer tires.
I will say that the tires look in great shape and have given us zero problems (save having to add air on occation).
Old 04-04-2008, 01:08 PM   #11
Airboss's Avatar
1997 30' Limited
1972 23' Safari
1965 17' Caravel
Howell , Michigan
Send a message via AIM to Airboss Send a message via MSN to Airboss Send a message via Yahoo to Airboss
Im not a big fan of radials on a trailer at all. Ive seen what they do to one when they blow out. They dont just go flat like a bias ply tire does. They come apart in a big way!! I have seen my friends A/S damaged from radial blow outs.. Im thinking about putting bias on my 1997 30 ft Limited..
"If your not living life on the edge... Your taking up too much room. WANTED, Single lady who loves and has a Airstream. Please send photo of Airstream and Tow Vehicle
Operation "SAVE RUDY" Strike Team (Charter Member) RALPH, KW8G..WBCCI # 4201 Metro Detroit & 4CU TAC # MI-007
Airboss is offline   Reply With Quote
Old 04-04-2008, 05:05 PM   #12
1973 25' Tradewind
Romulus , New York
You want TRAILER tires The stronger sidewalls keep the sway down. The height is correct and since no tire on a trailer is good for more than 5 years, I plan on running these on my 73 tradewind forever.
Old 04-04-2008, 05:54 PM   #13
Airboss's Avatar
1997 30' Limited
1972 23' Safari
1965 17' Caravel
Howell , Michigan
The Bias ply are trailer tires..
Old 04-05-2008, 08:44 AM   #14
Vintage Kin
Fort Worth , Texas
Bias-ply runs hotter and doesn't last as long as radials. They were superceded in design more than forty years ago, and haven't been oem provided on cars in more than thirty years.
LT tires are, according to dealer Andy Thompson, more resistant to punctures than the ST tires. I have had both bias and radials on my trailer and it was obvious that the bias-ply tires were having to work harder to do the same job; I went to LT tires of the same rating (both at the recommended weight-rating for the trailer; "ply" rating is obsolete) and now have tires that:
are used in commercial service on delivery trucks that see constant, changing loads and abuse, yet stand up well
run cooler, with a better tread design
are unlikely to be worn out at the end of five years
are tires that the manufacturer depends upon to make and ensure their reputation among commercial customers
The ONLY bias ply tires I now see as being sold new are on ridiculously small trailers sold for homeowners to haul, maybe, an ATV or a lawnmower or two.
Twenty years ago this argument may have had some validity.
Heat is what weakens and kills tires.
Old 04-05-2008, 10:18 AM   #15
Airboss's Avatar
1997 30' Limited
1972 23' Safari
1965 17' Caravel
Howell , Michigan
Untrue..Look at the Carlisle 700 15s Nice trailer tires.. I had bias on my other A/S for yrs.. Not 1 problem.. Ever see what a radial does to the side of a trailer when they blow out?? NOT PRETTY!!!..Bias just go flat...
Old 04-05-2008, 10:25 AM   #16
Airboss's Avatar
1997 30' Limited
1972 23' Safari
1965 17' Caravel
Howell , Michigan
and here is more bias for sale
Old 04-05-2008, 10:42 AM   #17
arm4's Avatar
2008 25' Safari FB SE
Cazenovia , New York
Blow outs...
Hello Airboss,
I am also concerned about what radials do when there is a blow out....or should I say blow up! I have seen a number of AS damaged because of this. I have a 25FB and am thinking of swapping my marathons out for bias. Which bias would you recommend?
Thanks, Randy
arm4 is offline   Reply With Quote
Old 04-05-2008, 10:52 AM   #18
Airboss's Avatar
1997 30' Limited
1972 23' Safari
1965 17' Caravel
Howell , Michigan
Hi Randy,,,A friend has the Carlisles look just like radials..Great tires too...Think the price was under 80 each...Ralph
Old 04-05-2008, 11:01 AM   #19
Airboss's Avatar
1997 30' Limited
1972 23' Safari
1965 17' Caravel
Howell , Michigan
Close friend of mine got 4 new Good year Marithons.. All 4 blew out within a yr.. 2 within a 2 week period...Now way will I ever go with them!!! Thats what I have now and they are coming off soon!!!
Old 04-07-2008, 03:50 PM   #20
Vintage Kin
Fort Worth , Texas
Those Carlisles are the ones I removed. And, it isn't true that they don't blow out. But you're welcome to them, and good luck. Let us know what you find after a few years of use.
1/2 ton tires- load C to load E John Tires 75 03-20-2009 09:15 AM
D or E load range? davidz71 Tires 16 04-09-2008 04:57 AM
Load range D or E? Bing-Bing Tires 5 05-30-2007 01:26 PM
Which Load Range sander17 Tires 27 05-04-2005 06:53 AM
steel radial vs load range c skip Tires 7 05-13-2004 08:39 AM
