Old 09-20-2008, 04:47 PM   #1
aircooled4's Avatar
1971 31' Sovereign
1967 22' Safari
1958 22' World Traveler
Pardeeville , Wisconsin
7.00-15....what would you replace them with?
Im finding several options...not sure if i should go with 70 or 75 series...opinions??
aircooled4 is offline   Reply With Quote
Old 09-20-2008, 06:07 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Options, if you want to go with comparable size and capacity, are:
7.00X15LT
7.00R15LT
ST225/75R15
70 series tires are not recommended for trailer use.
Old 09-20-2008, 06:11 PM   #3
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
Hi
What year model and size trailer are you putting them on?
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Old 09-20-2008, 06:19 PM   #4
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
The old numeric designation for tire sizes were somewhat equivilant to 80 series tires. When I changed out the 7.00-15 bias belted tires on the GT to the "recommended" 225/75 R 15 the coach dropped about an inch in height. Some of this is due to the greater flex in a radial sidewall.
Practically speaking there is more dampening of road shock the higher the sidewall. I don't know if this is a consideration in your choice of tire sizes or if there is some other circumstance you're thinking of.
There are numerous threads on tires here, so hit the search button for more opinions than you can digest in a single sitting.
Tom.
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 09-20-2008, 07:57 PM   #5
aircooled4's Avatar
1971 31' Sovereign
1967 22' Safari
Im putting them on my newly purchased '71 Sovereign...The ones on there are cracked to bad to take the 250miles...
Old 09-20-2008, 08:07 PM   #6
Well Preserved
1993 21' Sovereign
We have ST225/75R15 load range D tires on our Sovereign.
Old 09-20-2008, 09:20 PM   #7
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
That's what we just put on our Overlander as well.
www.nesa.org
Air No. 6427
Old 09-20-2008, 09:31 PM   #8
aircooled4's Avatar
1971 31' Sovereign
1967 22' Safari
One thing i forgot to ask...What bolt pattern is on this? Would wheels from any particular make of pickup work?
Old 09-20-2008, 09:56 PM   #9
azfiredog300's Avatar
Surprise , Arizona
I put on the 225x75R 15 also as well as new axles and noticed that I can make a trip with everything inside staying put. I even left the soap dispenser on the counter and it was still there after 30 miles.
Jerry C.
"Travelstar Galactica"
WBCCI #13317
AIR #25664
Member of the Four Corners Unit
The only true failure is the failure to try.
azfiredog300 is offline   Reply With Quote
Old 09-21-2008, 06:06 AM   #10
Well Preserved
1993 21' Sovereign
They are 6X5 1/2", zero offset. They need to have a weight capacity of 2500 pounds each. This is because of the side flexing that takes place when you turn your trailer.
Old 09-21-2008, 06:10 AM   #11
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
Since 1971 we had almost always used 7.00R x 15" radials on Airstreams which work very well. They are getting harder to find and so a few years ago we started experimenting with alternatives.
The the various trailer tires are ok but they do not hold their ballance well and often suffer from shifted belts.
We have had good luck with several brands or 235/75*15"LT Load Range "C" tires.
The other alternative is a Michelin P235/75R x 15" tires. These tires can carry the Airstream with only 35/41 PSI of pressure. On a vintage unit these take a great deal of road shock out the unit. The downside is that they have a little more sidewall sway.
Andrew T
Andrew Thomson
London, Ontario
Old 09-23-2008, 05:52 AM   #12
SteveH's Avatar
Common Sense , Texas
Tirerack.com has a tire made by Yokahama, 7RX15, which is the new radial designation of the 700X15 size, and I'm considering trying a set. The only thing is the overall diameter is a little larger than the 225's, but several people on here have stated they have changed to 16's, so it shouldn't be a problem.
Yokohama RY215
One of the reviewers made this statement: 7.00 x 15 is a size I needed for my 8,000-lb all aluminum travel trailer. Put some miles on the existing bias ply tires but they looked poorly and were running hot. Tried another tire --radial -- but was displeased with them. The previous owner had one of these in the trunk as a spare with most of the tread worn down, told me that he had kept the best one. It's appearance was good, so I decided to tray a full set of four. Had the trailer axles re-aligned, installed [4] new shocks and had the alloy wheel/tire combination balanced on a Hunter GSP-9700 and the weight necessary was low (!!). Was pleased with how fast Tire Rack got them to us.On Texas days of above 100F the tires were all within 5F of each other after exiting Interstate; they ride very well. In sharp turn and u-turns they do not deflect as badly as the tires I replaced, really not that much. They are not loosing any air, etc.I was told these are tires for commercial service and delivery vehicles, they are certainly heavy for their size and apparent construction. I would recommend them for someone needing a trailer tire of this size and in this load rating. I am looking forward to long life with mine.
Regards,
Steve
Old 09-30-2008, 04:28 PM   #13
Road Ruler's Avatar
Images: 38
Andrew T
We have been using a set of the P235/75r x 15's XL (with the extra load option) for 6 years now. They really work well with our 35 year old Airstream. The 32 to 35lb pressure allows them to have a large road contact patch and they handle road irregularities with ease. The load rating is 8,500lbs for the 4 and our road ready Airstream is only 4,500lbs so lots of headroom in the capacity department.
Quality P rated tires also seem to have a better reliability record compared to ST tires.
Old 01-16-2017, 07:39 PM   #14
1969 27' Overlander
Demorest , Georgia
Trailer tires
When you put the 225 75. r15 tires on your overlander did you notice the trailer dropping down lower. I have heard they are not as tall as the 7.00. 15. We are so low now that we sometimes drag pulling into unlevel sites.
cbmcinvale is offline   Reply With Quote
What if anything do I need to replace? RWinward General Repair Forum 2 08-12-2008 01:42 AM
Need to replace this - but what is it? Tom Randall Phone, CB & Ham Radio 10 05-22-2007 10:40 AM
What If I Replace The Transmission? Chaplain Kent Mechanics Corner - Engines, Transmission & More... 54 01-09-2007 12:14 PM
Should I replace with new? PhilMateo Trailer Values 18 01-20-2006 01:02 PM
replace 10 by 6 by WH CatandMe Water Heaters, Filters & Pumps 0 06-24-2003 12:16 PM
