Old 09-11-2011, 07:20 PM   #1
1981 31' Excella II
New Market , Alabama
7.0 x 15 what is this in a modern tire?
My 81 Excella 2 has 7 x 15 C load range tires. What is the modern equivalent tire for this trailer. The 7 x15 are really hard to find surely there must me a modern equivalent.
Perry
Old 09-11-2011, 07:26 PM   #2
SteveH's Avatar
Common Sense , Texas
There are some companies making a 7R X 15 (the radial replacement for the old 7.00 X 15 bias ply), but most people are using the 225/75 X 15 ST tire. However, lots of people are having troubles with the newer "ST" tires. Yokohama is one that I know makes the 7R X 15 tire in a load range D.
Regards,
Steve
Old 09-13-2011, 06:48 PM   #3
1964 22' Safari
Fort Collins , Colorado
I have a 1964 Safari that needs tires replaced also. I am having the axle done this week. What do you think of truck tires? I know there is a debate about what to put on. Radial or biasply, Truck or Trailer tires? So any thoughts which way? I had heard a little bit about ST tire problems. I will look into the Yokohama also....
Hopetoday is offline   Reply With Quote
Old 09-13-2011, 06:55 PM   #4
1981 31' Excella II
You can get Goodyear Marathons if you want to pay the price or you can go with Chinese made tires that are considerably cheaper. I talked to Topline tires and they had C rated tires for about $80 each installed and D rated for about $100 each installed. Sam's club wanted almost $600 for a set of 4 mounted and balanced. They said they have had less problem with the chinese made tires than the American Branded tires made who knows where. 225/75-15 is the right size.
Perry
Old 09-13-2011, 07:14 PM   #5
1964 22' Safari
Hi again, I Just got off the phone with Discount Tire and thought I'd share my findings... they have a 225/75/15 Carlisle Radial Trail RH 10 ply loade range "E" rated 2846lbs/tire. My Safari is 3250lbs dry. Its their newest tire for trailers, new rubber composition supposedly better to last longer with out dry rotting. They are 115.00/tire. The Yokohama's RY 215 LT tires are 188.00/tire.
I am going to talk with my axle guy tomorrow and see what he thinks of the new Carlisle's.
Good luck with your search!
Old 09-13-2011, 07:18 PM   #6
1964 22' Safari
Hi Perry, I Just read your post about the Chinese and American Tires. must have just missed it when I posted about Discount Tire.
Thanks for the info!
Tracey
Old 09-13-2011, 08:46 PM   #7
1981 31' Excella II
Carlisle's has been making tires for decades. Does your trailer only have one axel? Let's say your trailer gross weight is 5000lb loaded then you need a tire that can handle 2500 lbs. So load range E is about right. I will probably run D rated tires since I have two axels.
Perry
Old 09-14-2011, 08:25 AM   #8
1964 22' Safari
Thanks Perry! Yes, mine is single axel.
Good luck to you!
Tracey
Airstream Tire Failure Poll Phoenix Tires 150 05-14-2018 08:34 PM
Need One Tire.. 1Rookie Tires 8 06-13-2011 07:09 PM
Wheel and tire Combo Mr & Mrs S Wheels, Hubs & Bearings 2 05-09-2011 11:10 PM
Local Tire Brands.... KyMoonshine Tires 5 04-06-2011 05:56 PM
Correct Tire Pressure on Tow Vehicle Jim Pona Tow Vehicles 4 02-01-2011 11:37 AM
