Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 01-14-2003, 08:10 PM   #1
Retired Moderator
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
Question 67 trade wind tires?
what type of tires would you use on a '67 26 foot trade wind?
bias ply or radial? what size?
john
Old 01-14-2003, 08:17 PM   #2
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 156
Greetings John!
I have been using Good Year Marathon tires on my Overlander (26') for the past eight years, and am totally pleased with their performance. I believe that the size is P225 75 R15 - ST (Load Range D) - - at full inflation, four tires are rated in excess of 8,000 pounds capacity.
I have been so well pleased with the performance of the Good Year Marathons on my Overlander that I also purchased a pair for my recently acquired '78 Argosy Minuet. I believe that the tire size on the Minuet is P225 75 R15 - ST (Load Range C).
Good luck with your decision.
Kevin
Kevin D. Allen
AIR #827
Old 01-14-2003, 08:37 PM   #3
Retired Moderator
john hd's Avatar
madison , Wisconsin
Images: 40
kevin
thanks for the fast reply, i have marathons on my '92. load range C very pleased with their performance.
this question is for a friend, why do you have d's on one and c's on the other?
john
Old 01-14-2003, 08:48 PM   #4
Anna , Illinois
Images: 156
Greetings John!
The load range decision was based upon carrying capacity needed for each coach. The Minuet is a single axle with a GVWR of 3,500 pounds, and the load range C tires were able to provide 120%+ of that capacity and were chosen for that reason. My Overlander weighs around 6,000 pounds when fully loaded, and the load range D tires on tandem axles provided 120%+ of that capacity and were chosen for that reason. New rims were part of the package with the Overlander, but the Minuet still has its factory styled steel wheels.
I was taught many years ago to always go for extra capacity in tires when possible so that there is at least a 20% over-capacity factor. I guess that is another reason that I always order the largest factory offered tires on my vehicles, and then often go up one size when replacing the tires - - not as frequently with the new p-metric tires; but was always the case in the days of the alpha-numeric tires.
Kevin
Kevin D. Allen
AIR #827
Old 01-15-2003, 04:51 PM   #5
Retired Moderator
john hd's Avatar
madison , Wisconsin
Images: 40
recall?
kevin,
are your load range D tires subject to the recall? or do they have the magic "s" on them?
john
Old 01-15-2003, 05:53 PM   #6
Anna , Illinois
Images: 156
Greetings John!
My current set of Load Range D Marathons were put on after the recall was announced, and my dealer assured me that they were post-recall tires. I keep telling myself that I must double-check them, but haven't as yet. I have a high degree of confidence in my Good Year dealer as I have been doing business with him for more than 20 years - - in fact, I recently asked him to inspect the tires he sold me two years ago for my Suburban fully expecting to be advised to purchase new tires when his recommendation was to keep the current tires as they had enough tread for another 15,000 to 25,000 miles (the tires already have in excess of 53,000 miles of travel).
Kevin
Kevin D. Allen
AIR #827
Old 01-15-2003, 06:44 PM   #7
Profile:
Goodyear Marathons Recall
I remember a thread(unable to locate) that talked about the Goodyear Marathon Recall.
If I remember correctly, the load "c" was the tire being recalled and it use replaced with the load "d" with an "s" within a circle after the word "radial".
Do any of you remember this, as I don't want to give bad infor out.
When I went to buy new tires for my trailer(I had load "c"), I was told by the Goodyear tire center that they now only sell these in load "d".
This was before I was aware of the recall.
John
John is offline   Reply With Quote
'59 Trade Wind flyfshr 1959-69 Tradewind 192 11-15-2006 12:50 AM
Any Other '59 Trade Wind Owners? flyfshr 1959-69 Tradewind 11 06-02-2006 11:17 AM
1962 Trade wind $ Scot 1959-69 Tradewind 22 01-11-2004 10:48 PM
Replacing Black Tank 1966 Trade Wind Pat66TW Waste Systems, Tanks & Totes 2 06-30-2003 09:42 PM
