Old 10-23-2012, 01:04 PM   #1
wheelerimage's Avatar
1965 20' Globetrotter
1955 22' Safari
Butte , Montana
Images: 8
55 Safari - Need new rims & tires
I need to get rid of the old split rims and weathered tires. I don't want to replace the axle at this time.
What rims do I need? It has six lug, 15inch rims.
I figured I would just take it to a tire shop, but I thought I would check the forums first.
wheelerimage is offline   Reply With Quote
Old 10-23-2012, 01:18 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
6 on 5 1/2, 15 inch. The last tires I bought were the 235 75 15. BUT...check your fit. It was a tight squeeze at 235. A 225 65 15 fit no problem. On my 56 Cloud I run 700 x 15 Bias. (hear the screaming in the distance....thats normal around here.)
Old 11-05-2012, 10:34 AM   #3
Jenaz, Switzerland , Graubunden
I have a similar dilemma; have a62 safari with standard r15 wheels with old tyres...i would like to upgrade to a metric PDC and use a load rated metric tyre here in Europe...(using alu usa wheels)!
Questions are should I go to r16 and what width rim should i use ? Eg 8 inch?
How many studs? What is the overall height of the tyre, what offset should I buy etc etc...heads spinning.....
Anyone got any experience?
Uppla is offline   Reply With Quote
