Old 02-03-2011, 09:40 AM   #1
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
303 product experience?
Anyone used the 303 products for protecting your tires? If so what's your experience. Thanks-
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 02-03-2011, 10:16 AM   #2
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
Very good experience actually. I do recommend this product. No checking or cracking of the tires after many years of usage.
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
http://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Old 02-03-2011, 10:24 AM   #3
_
ST tires are reportedly made with 5-6 years of UV inhibitors in the materials...
so it's unlikely ANY sprayed on stuff will expand that timeframe....
and virtually impossible for ne1 user of those products to determine IF the stuff makes a difference.
still spray or wipe on stuff does make the tires shiny or appear darker,
and many of us like that look.
imo 303 holds up VERY POORLY to water/washing or movement...
when applied to HARD surfaces like tires.
if 'looks' are indicative of performance, 303 looks good on rolling tires for 1-2 weeks.
i have applied other stuff 2tires that looks good for a lot longer and resists washing longer...
but do NOT think any of these products add to tire life or inhibit the effects of sun or ozone or chemical exposures.
IF u really want MORE tire protection from uv, use covers of some sort (while parked)
cheers
2air'
WBCCI Bylaws/Constitution suggestions/recommendations LI Pets WBCCI Forum 289 03-28-2012 11:53 PM
New tankless water heater lewster Commercial Listings 105 02-09-2012 08:37 PM
