Old 11-23-2011, 01:54 PM   #57
1985 31' Limited
Nellysford , Virginia
Tires
Okay, so I am ready to pull the trigger on 4 Michelin LTX M/S2 tires for my 31 ft AS, factory wt 5550#. Any last minute reason I should think otherwise? Getting them installed/out the door at an independent dealer for $681 minus the $70 Michelin "rebate".
Vacillated back and forth between Maxiss and Michelin. Settle on Michelin based on good feedback here.
RTurnConn is offline   Reply With Quote
Old 11-23-2011, 04:47 PM   #58
The Silver Bullitt
Xenomorph's Avatar
1976 27' Overlander
Ventura , California
You have 15" rims? What's your GVWR? I'm not an expert by any means but you may be cutting it close. 1985 x 4 = 7940lbs
Xenomorph is offline   Reply With Quote
Old 11-23-2011, 05:22 PM   #59
2005 28' Safari
saline , Michigan
Ultimately, you have to feel comfortable and safe with your choice. I would read Andrew T's post on this thread again or send him a PM. The load rating on that tire is 2185 not 1985. Besides that, what is a margin of safety on a ST tire at any load rating? The failures reported on this forum and many other RV forums were most likely not from overload. Read them yourself. I chos e the Michelins because I would feel more comfortable with them even if I was closer to the max rating.
Kos
Kosm1o is offline   Reply With Quote
Old 11-23-2011, 08:20 PM   #60
1985 31' Limited
GVWR is 8500. I don't think I pack that much "stuff" in the AS.
Old 11-23-2011, 09:57 PM   #61
The Silver Bullitt
Xenomorph's Avatar
1976 27' Overlander
Kos
I think the sidewall says 1985lbs at 50 psi and then also rates it at a 108 which comes to 2200lbs. Not sure which one is more correct. I will take a pic of mine tomorrow and post it to make sure.
Old 11-24-2011, 07:10 AM   #62
1981 31' Excella II
New Market , Alabama
There is no margin of safety on ST trailer tires. They take a crappy made tire and overrate and over pressure the tire. That is probably one reason that they explode with such force.
Perry
Kos
Old 11-24-2011, 07:49 AM   #63
r carl's Avatar
Lin , Ne
Perry
And if you want the loudest explosion get a china E rated tire.
Old 11-24-2011, 07:55 AM   #64
Scott J-24's Avatar
2009 27' FB International
Los Angeles , California
can you say BOOM
Scott, Becky & Heidi (our standard poodle and travel companion)
WBCCI #1215
Air #54601
Remember... No matter where you go, there you are...
2009 27FB International Ocean Breeze
2010 Toyota Tundra CrewMax, 5.7L V8, 4x4
Scott J-24 is offline   Reply With Quote
Old 11-24-2011, 09:33 AM   #65
Whirlaway's Avatar
2008 27' Classic FB
Anytown , Massachusetts
Basic question? Tires 101
Happy Thanksgiving to ALL!
First off thank you for starting this thread since I need new tires on my
AS 27. I have some beginnings of dry rot on one side wall.
However after reading all these posts with great interest, I just went outside and looked at the factory ST tires. The first set of numbers:
ST 225.
I have been clicking on all the links and no where does it explain how
a ST 225; can become a LT 235? Does this number designate model or a of tire size?
Could someone kindly explain the difference between these two major points through out this post. I would like to pick the most correct tire for my AS 27. After reading the posts I am very confused trying to pick up on the "little" differences.
  1. ST 225 vs. LT 235 does this designate a size or model?
  2. LT 235/75R 15 vs. LT235/75R15 XL
Many thanks,
Lin.
Life Is Not A Dress Rehersal
It's okay to have too much fun
WBCCI #8701* TAC MA-1 * NEU UNIT
Gracie...A Liver & White GSP
Get busy livin', or get busy dyin'." - The Shawshank Redemption
Whirlaway is offline   Reply With Quote
Old 11-24-2011, 09:47 AM   #66
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
ST 225.
Many thanks,
Lin.
ST stands for trailer tire (speed rating of 65 MPH), LT means light truck. 225 is the width to height ratio of the tire. A 225 is narrower than the 235. XL means extra load capacity of the tire. JMHO
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 11-24-2011, 09:53 AM   #67
Whirlaway's Avatar
2008 27' Classic FB
Now that was so simple!
Thanks!
Old 11-24-2011, 10:09 AM   #68
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I believe that 225 (or 235) is the width of the tire in millimeters and 75 is the aspect ratio or the percent of the width that equals the sidewall height.
Richard
Old 11-24-2011, 10:16 AM   #69
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
That does make more sense. Thanks for the input
Julia & Bob
W/ Deedee & Boo
AIR #30685
Old 11-24-2011, 12:34 PM   #70
The Silver Bullitt
Xenomorph's Avatar
1976 27' Overlander
ST 225.
Many thanks,
Lin.
Unfortunately there aren't a lot of options in the 225 size. 235 is 10mm or .4 inches wider on the tread size. Good luck!
Airstream Tire Failure Poll Phoenix Tires 150 05-14-2018 07:34 PM
Truck & Trailer Weights nickmeloy Towing, Tow Vehicles & Hitches 6 04-02-2014 10:02 AM
Tire mount under front of trailer CJ of Okla Tires 2 09-09-2011 08:50 AM
A sad end to a wonderful trailer rmk110761 Airstream History 9 02-15-2011 09:12 AM
TowMaster range E trailer tire tvanwave Tires 8 01-14-2011 04:50 PM
