Old 07-13-2010, 12:09 PM   #1
howco's Avatar
1970 27' Overlander
Sumner , Washington
22" rims ok for towing???????
OK, heres a question.
Can I haul my 27' A/S behind my Suburban with my 22" rims and tires on it?
Has anybody done this????
Favorite Bumper sticker:
Yes, this is my truck...
No, I won't help you move....
howco is offline   Reply With Quote
Old 07-13-2010, 02:56 PM   #2
Iwannagocamping
Dakota's Dad's Avatar
Rineyville , Kentucky
I would think, if your custom rims and tires meet the same ratings as the stock ones, then yes.
However, 1)I doubt they do, 2) Not much sidewall on a 22" tire, sure would hate to hit a pothole with that extra load, and 3) most people I know running super low profile tires and rims have also modified the suspension, a whole 'nother can of worms..
See our blog here on how two RV/AS rookies tackle a 1979 Sovereign resto!!
Just the photos.. (sometimes you don't need the blog, just a picture worth a thousand words..)
1979 Sovereign International
2004 Ford Expedition Eddie Bauer
2 Golden Retrievers
Air #36788
TAC#3179
WBCCI #1265
Dakota's Dad is offline   Reply With Quote
Old 07-13-2010, 03:04 PM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Many of the custom wheels of that size are of substantially less strength rating than the stock wheels. They may not handle the loads of a heavy trailer. I would use extreme caution.
Brian
SuEllyn & Brian McCabe
Old 07-13-2010, 03:13 PM   #4
howco's Avatar
1970 27' Overlander
Sumner , Washington
Dakota
Thanks, the rating is about the same as the stock tires and factory 16" wheels, but I was also worried about the side wall lack of height.
Thanks Moose, well taken...
Old 07-13-2010, 03:21 PM   #5
Maniacal Engineer
barts's Avatar
Menlo Park , California
The reduced sidewall compliance will actually improve trailer stability. Low profile tires and rims are much more subject to damage, however, from pot holes, etc, and flat tires are always more exciting when pulling a trailer.
So, it will likely work - but pay attention to your tires!
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 07-13-2010, 03:27 PM   #6
_
assuming the wheel/tire LOAD capacity is SIMILAR to oem...
the other issue is OUTSIDE DIAMETER...
IF the 22s are LARGER (is the speed'o OFF or has it been adjusted) than the factory treads...
1. hp/torque AT the wheels goes down...
2. braking distances may be longer
3. towing capacity goes DOWN
the effect of LARGER ROLLING tires/wheels is similar to CHANGING the rear end gearing...
and that change moves AWAY from hauling potential.
_________
so while it's POSSIBLE to tow a newer 27 foot stream , HOW the tires/wheels alter this...
depends on ALL of the specs and burb' equipment.
here's an older thread about 17s vs 20s towing a BAMBI...
with similar issues just MORESO in your example...
(see post #12, 20 n 24 below...)
http://www.airforums.com/forums/f438...ize-25739.html
the target and options keep SHIFTING.
so many truck now come STANDARD with 20s
that a LOT more tire options exist in 2010 than in 06 when that thread happened...
but 22s are still bling-ish by most measures...
cheers
2air'
Old 07-13-2010, 05:40 PM   #7
You might have to use a huge drop shank ball mount, especially if the trailer is setting low.
1966 Caravel: Best New Tires; Old Rims or New Rims??? divotvance Member Introductions 6 08-11-2016 07:43 AM
Help with rims ND Sovereign Wheels, Hubs & Bearings 5 04-21-2008 07:50 PM
Split Rims Julison Wheels, Hubs & Bearings 5 10-12-2005 08:49 PM
New Rims balrgn Wheels, Hubs & Bearings 12 02-17-2005 06:45 AM
Rims Alex Wheels, Hubs & Bearings 7 05-17-2004 07:15 PM
