Old 01-19-2007, 11:06 AM   #1
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I have a question about my tires:
My ID plate refers to ST205 tires; my manual (such as it is, refers to ST215). The trailer came with 205s. I replaced them with 215s, thinking the manual was the way to go.
When I needed a replacement in BC, couldn't find 215s, so had to buy a 205 and matched it on my trailing axle with a 205 I had as a spare (215s on front, 205s on rear).
So - if I need tires again (and I do), should I buy 205s or 215s?
Thanks - Pat
pmclemore is offline   Reply With Quote
Old 01-19-2007, 12:04 PM   #2
1984 31' Excella
Norfolk , Virginia
Images: 11
Trailer Tires
Pat
What rims do you have on your trailer?
14 inch or 15 inch.
Beginner
Beginner is offline   Reply With Quote
Old 01-19-2007, 12:19 PM   #3
bhayden's Avatar
1978 24' Argosy 24
Woodinville , Washington
Originally Posted by pmclemore
When I needed a replacement in BC, couldn't find 215s, so had to buy a 205 and matched it on my trailing axle with a 205 I had as a spare (215s on front, 205s on rear).s - Pat
Yikes! The 205 vs 215 refers to the width but it also affects the height of the tire. This means your 215s are going to be carrying a dispropotional amount of the load. Sounds like either will work but you shouldn't be mixing the two. That's a BIG no no.
FYIW the trailer came with the 205s because they're cheaper. Sometimes the smaller tire has a greater load capacity (sometimes not). I'd lean toward the 215s but that's just me.
-Bernie
bhayden is offline   Reply With Quote
Old 01-19-2007, 12:30 PM   #4
Desert Fox
1985 31' Sovereign
Tucson , Arizona
Tires,
Hi,
Any tire as long as it is radial type. When I put radials versus bias ply. I gained about 1 mile per gallon. They roll so easy and tow very well. One item I would do is get an aligment on the axels, they do go out of aligment when you hit bumps and chuck holes.
Russell in rainy Tucson Az.
RUSSELL is offline   Reply With Quote
Old 01-19-2007, 01:08 PM   #5
Ready-to-Travel
pmclemore's Avatar
Beginner - my rims are steel 14s.
bhayden - I agree, it is not optimal to do this, but the most important dimension was the width. However, I was in Watson Lake YT getting ready to go down the Cassiar. Not recommended, I agree, but I was glad to get away with it.
So I think I will buy a set of 205s or 215s. And likely not Marathons
Pat.
Old 01-19-2007, 01:41 PM   #6
1984 31' Excella
Norfolk , Virginia
Images: 11
Trailer Tires
Pat
In my mind the Goodyear Marathons will give good trouble free service IF:
1. You never run over 55 MPH (it is a ST tire and speed rated at 65MPH).
2. You keep the tire pressure at the max allowed by the sidewall (this will keep sidewall flexing/heat generation to a minimum.
3. Get a Good Tire Pressure Monitering System.
However, if you plan to keep up with traffic, I would recommend a higher speed rated tire.
I do not know what is available in 14 inch in other types of tires as I did not have to look my self.
If you decide to go to a larger wheel (15 or 16 inch) and different tire there are a number if things you must consider to prevent damage to your trailer (caused by lack of wheel/tire clearance).
Beginner
Trailer Tires Lumatic Tires 171 05-18-2013 10:32 AM
