Old 08-24-2010, 11:24 PM   #15
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Originally Posted by Airslide View Post
Just be sure your wheels can handle "D" rated tires. I made the same switch and Im keeping an eye on my alloys. The D rated tire has some stiff sidewalls and can cause a wheel to fail if not spec'd for it.
Vin
Hi, I think Vinnie meant to say "E" rated tires. That is just too much weight on "D" rated tires. A 30' w/slideout running on the same four tires as my much lighter [6,300 lbs] Safari. [my opinion]
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 08-25-2010, 04:41 AM   #16
r carl's Avatar
Lin , Ne
Just be sure your wheels can handle "E" rated tires. I made the same switch and Im keeping an eye on my alloys. The E rated tire has some stiff sidewalls and can cause a wheel to fail if not spec'd for it.
Vin
Limit air to what the wheels will handle. The sidewalls on D and E ST225 75 15 radial tires feel about the same, wimpy.
Old 08-25-2010, 05:17 AM   #17
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
I miss-quoted on my specs yesterday, tires are D not E as my big hand typed. Tire size is factory spec.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 08-25-2010, 08:10 AM   #18
_
the gym doesn't come in an E rated 15 inch version...
they do make gyms in 16s that are E rated.
given the weight of a 30 slide, the heaviest a/s on 4 wheels...
an E rated tire makes sense and there are 2-3 E rated offerings,
just not from gy.
good to read the retailer is gonna provide some relief on this one.
cheers
2air'
Old 08-25-2010, 08:22 AM   #19
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
Vin
Thanks Robert... Yep.. senior moment.. I meant E rated tires.
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 08-25-2010, 09:34 AM   #20
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
Thanks GCinSC2 - A TPMS is on my list of "Things I definately will purchase" for my truck and trailer.
Mel
2006 GMC 1500 SLE Crew Cab
5.3L V8 Towing Package
Equal-i-zer E2
AIR # 40365
TAC # OK-3
mwells4654 is offline   Reply With Quote
Old 08-25-2010, 05:56 PM   #21
GCinSC2's Avatar
Current status:
TPMS ordered, early X-Mas for me. I chose the Dill 1504. I actually like the idea that it is inside, sorta vandal proof, and monitors the temp from the inside, Dill Tech Support states that it is capable of picking up a hot wheel hub even (brake heat or bearing heat induced) with a cool running tire. With new tires hopefully an e-mail confirmation away, this will be a busy but well timed event.
Spent a lot of last night searching Airfrums, unless something magic comes up, looks like it will be MAXXIS LRE. Not able to factually justify it yet, I know lots of ideas about 16", LT's etc but its kinda my gut feel for right now and yes several fully riveted members here have started using them.
Within the next week:
New tires are planned.
TPMS installed w/new tires.
New Carslile actuator, I'll do the installation while the wheels are off.
Then Labor Day Weekend, campsite reserved, time to relax.
Tonight was an oil change on the 5.9L and fuel filter, guess what, I did it with the cab still on the frame! Yup, that was a shot at Ford.
S/OS #001
Old 08-25-2010, 07:17 PM   #22
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Originally Posted by GCinSC2 View Post
Current status:
This is the best part!
>>>>>>>>>>>>>Action
Old 08-30-2010, 06:46 PM   #23
GCinSC2's Avatar
Update after a 40 mile test drive tonight.
1. GYM's are gone.
2. New MAXXIS load range E replaced the GYM's by tire retailer, even swap based on sidewall bulges at 200 miles. I did the R&R labor on the trailer.
3. Dill 1504 TPMS installed, the retailer installed the transmitters, we hooked up and we are now collecting 8 data points on 4 tires, PSI and Temp. More to learn, but it is working. Interesting to watch it just cycle thru the 4 tires.
4. New Carslile brake actuator installed this weekend, took a bit of learning curve to bleed out. Took a bit of adjusting on the controller to get a nice syncronized brake application.
I feel better, but a long trip will be required to make sure all is well. This was a lot of work.
S/OS #001
Old 09-08-2010, 05:16 PM   #24
GCinSC2's Avatar
Update.
The GYM's are ALL gone, replaced at N/C by the retailer for MAXXIS load range E. I don't have the exact number but there is 2 ratings cast into the inside of the wheel, one ended in 5H the other 6H, the number on the 6H was aver 2800 lbs, assumption 6H = 6 lug holes.
First outing 400 miles with 60-80 miles of hill and dale driving, no problems, felt good.
S/OS #001
My GYM Purchase. $$ Adj. & Valve Stem, The Epilogue GCinSC2 Tires 7 08-08-2010 11:09 AM
HELP!! does the body of an airstream bulge???? purman Ribs, Skins & Rivets 10 09-27-2008 06:00 PM
A $200 Airstream toddster Our Community 1 05-23-2007 11:36 PM
Tire bulge versus indentation AZstreamin Tires 11 09-27-2006 08:41 AM
