Old 06-18-2007, 10:33 PM   #1
codybear's Avatar
1964 22' Safari
SACRAMENTO , California
Images: 315
2 times the charm!
Just got back from our trip from the Coast..stopped for breakfast in Bodega Bay..btw, Tippi Hedren (star of The Birds) will be at the Tides June 30-July 1..
On our way back to the truck and safari, Steve glanced at the tires..would you believe the left side tire had a chunk missing!..we got back into the truck and found the boat launch parking lot, stopped and replaced the bad tire w/the spare..I think we're going to try radials next time..
codybear is offline   Reply With Quote
Old 06-18-2007, 10:49 PM   #2
2007 25' Safari FB SE
Suburbia , Sunny So Cal
I sure am glad you saw the damage before the tire let go.
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 06-18-2007, 10:57 PM   #3
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Was the bad tire on the Safari? If so I would ask a tire person but I don't think you should put radials on a trailer...any trailer.
Neil and Lynn
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 06-18-2007, 11:17 PM   #4
Desert Fox
1985 31' Sovereign
Tucson , Arizona
Smile Hi,
I do not understand. Why no radials on the trailer? Since I put my radials on our AS I gained a 1 mille per gallon and the trailer wants to roll.
Waiting for an good answere.
Regards from Russell in sunny and hot Tucson Az.
RUSSELL is offline   Reply With Quote
Old 06-19-2007, 07:38 AM   #5
CanoeStream's Avatar
St. Cloud , Minnesota
I've always heard 'no radials.' Check this post out: http://www.airforums.com/forums/402431-post175.html
5 meter Langford Nahanni
Old 06-19-2007, 07:55 AM   #6
codybear's Avatar
1964 22' Safari
Images: 315
Here's a pic of it..we had used bias w/split rims on the '64 safari. Anyone have any recommendations?
Old 06-19-2007, 08:14 AM   #7
Still using split rims? Some people do report finding shops that will still work with those -- not for the inexperienced! It will take some care to get high capacity wheels and the right bolt pattern if you ever replace the split rims.
How many years were on those tires?
[On edit: Tim Shephard found a good supplier in Trailer Tire & Wheel Supermarket on theVAP.]
Old 06-19-2007, 10:38 AM   #8
codybear's Avatar
1964 22' Safari
Images: 315
Hi Bob,
Thnx for the tip: the split rim is the old spare tire..he's using regular rims now.
Old 06-20-2007, 08:21 AM   #9
codybear's Avatar
1964 22' Safari
Images: 315
update:
We've got new tires to try now and will see how long they last: Transmaster st Radials, 80 pounds cold pressure 10 ply..steel belted..I asked the tire guy how long he thought they'd last us..he said jokingly, about 20 minutes..
I asked him what caused the tire to fall apart: he suggested: over/under inflation, going from hot to colder temperatures (you lose a pound of pressure with every 10 degrees), rough roads, and other possible factors..
Old 06-20-2007, 06:35 PM   #10
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
10 ply may be a bit of overkill. And if the insides are not shook up after you travel I would say kool!
>>>>>>>>>>>>Action
Old 06-20-2007, 07:33 PM   #11
codybear's Avatar
1964 22' Safari
Images: 315
Hi Moderator Dude!!!..well, they're on and ready to go another couple thousand miles ( time will tell, huh?) through CA then Oregon, Washington, Canada and back..will report on the hefty tires!!!
Old 06-20-2007, 07:39 PM   #12
Silver Threads's Avatar
2000 25' Excella
Kingston , Tennessee
We were told that we couldnt use 10 ply tires. We went through a bunch hassle just to trade them for 8 ply! Is this not true?
John & Tammy Adams
Silver Threads Custom RV Curtains
2000 Airstream Excella | AIR 15902
https://www.etsy.com/your/listings
Silver Threads is offline   Reply With Quote
Old 06-20-2007, 07:44 PM   #13
codybear's Avatar
1964 22' Safari
Images: 315
Hi John, Tammy, We had 8 ply and went to 10 ply...so we'll see how good they hold up!
Old 06-20-2007, 07:51 PM   #14
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Single axle trailers can get away with a heavier-duty tire, because more of their weight is concentrated on each tire. You still should not exceeed the D load inflation pressure, it will shake the trailer up more if you go over that. You may also have an issue with the wheels if you overinflate.
There is no reason not to use radial tires on trailers, that, after all, is what Goodyear Marathons are. ST=Special Trailer 225= size of tire, in millimeters 75=aspect ratio, aka tire width R= Radial 15= diameter.
If you have a problem getting tires inside the wheelwells, you may ant to deflate the tires to gain a little more room to manuever tham. 700x15 tires are slowly going away, we may as well go with the "new" technology.
Bad Times.... canny_banjo_man Off Topic Forum 58 02-21-2008 06:45 PM
1 owner 82 excella,used only 3 times wanderer1 Off Topic Forum 1 06-06-2007 08:51 PM
Absent Members hex Our Community 33 01-03-2003 03:18 PM
Very interesting story/ back pack FrankR On The Road... 2 08-31-2002 08:29 PM
Towing my 1964 Safari - what tow vehicle do I use Neenm Tow Vehicles 6 06-28-2002 04:26 PM
