06-18-2007, 10:33 PM
1964 22' Safari
SACRAMENTO
2 times the charm!
Just got back from our trip from the Coast..stopped for breakfast in Bodega Bay..btw, Tippi Hedren (star of The Birds) will be at the Tides June 30-July 1..
On our way back to the truck and safari, Steve glanced at the tires..would you believe the left side tire had a chunk missing!..we got back into the truck and found the boat launch parking lot, stopped and replaced the bad tire w/the spare..I think we're going to try radials next time..
06-18-2007, 10:49 PM
1960 22' Safari
in the wilderness
, The great Mojave Desert
I sure am glad you saw the damage before the tire let go.
I'd rather be boon docking in the desert.
WBCCI 3344 FCU
AIR# 13896
CA 4
Yes, we have courtesy parking for you. About an hour North of Los Angeles.
06-18-2007, 10:57 PM
1966 24' Tradewind
Placerville
Was the bad tire on the Safari? If so I would ask a tire person but I don't think you should put radials on a trailer...any trailer.
Neil and Lynn
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
06-18-2007, 11:17 PM
Desert Fox
1985 31' Sovereign
Tucson
Hi,
I do not understand. Why no radials on the trailer? Since I put my radials on our AS I gained a 1 mille per gallon and the trailer wants to roll.
Waiting for an good answere.
Regards from Russell in sunny and hot Tucson Az.
06-19-2007, 07:55 AM
1964 22' Safari
SACRAMENTO
Here's a pic of it..we had used bias w/split rims on the '64 safari. Anyone have any recommendations?
06-19-2007, 08:14 AM
St. Cloud
Still using split rims? Some people do report finding shops that will still work with those -- not for the inexperienced! It will take some care to get high capacity wheels and the right bolt pattern if you ever replace the split rims.
How many years were on those tires?
[On edit: Tim Shephard found a good supplier in Trailer Tire & Wheel Supermarket on theVAP.]
06-19-2007, 10:38 AM
1964 22' Safari
SACRAMENTO
Hi Bob,
Thnx for the tip: the split rim is the old spare tire..he's using regular rims now.
06-20-2007, 08:21 AM
1964 22' Safari
SACRAMENTO
update:
We've got new tires to try now and will see how long they last: Transmaster st Radials, 80 pounds cold pressure 10 ply..steel belted..I asked the tire guy how long he thought they'd last us..he said jokingly, about 20 minutes..
I asked him what caused the tire to fall apart: he suggested: over/under inflation, going from hot to colder temperatures (you lose a pound of pressure with every 10 degrees), rough roads, and other possible factors..
06-20-2007, 06:35 PM
Moderator dude
1966 26' Overlander
Phoenix
10 ply may be a bit of overkill. And if the insides are not shook up after you travel I would say kool!
>>>>>>>>>>>>Action
06-20-2007, 07:33 PM
1964 22' Safari
SACRAMENTO
Hi Moderator Dude!!!..well, they're on and ready to go another couple thousand miles ( time will tell, huh?) through CA then Oregon, Washington, Canada and back..will report on the hefty tires!!!
06-20-2007, 07:39 PM
2000 25' Excella
Kingston
, Tennessee
We were told that we couldnt use 10 ply tires. We went through a bunch hassle just to trade them for 8 ply! Is this not true?
06-20-2007, 07:44 PM
1964 22' Safari
SACRAMENTO
Hi John, Tammy, We had 8 ply and went to 10 ply...so we'll see how good they hold up!
06-20-2007, 07:51 PM
Retired.
, At Large
Single axle trailers can get away with a heavier-duty tire, because more of their weight is concentrated on each tire. You still should not exceeed the D load inflation pressure, it will shake the trailer up more if you go over that. You may also have an issue with the wheels if you overinflate.
There is no reason not to use radial tires on trailers, that, after all, is what Goodyear Marathons are. ST=Special Trailer 225= size of tire, in millimeters 75=aspect ratio, aka tire width R= Radial 15= diameter.
If you have a problem getting tires inside the wheelwells, you may ant to deflate the tires to gain a little more room to manuever tham. 700x15 tires are slowly going away, we may as well go with the "new" technology.
06-20-2007, 08:39 PM
1964 22' Safari
SACRAMENTO
Hi Terry, Steve just commented after I read your post to him..he almost was going to deflate the tire to get it up on the wheel..he asked his neighbor and was able to lift it on..he agrees w/you, phasing out of the bias700x15...
06-20-2007, 09:40 PM
Salem
, Oregon
update:
Hi, I don't think that tire guy knows what he is talking about; Looks to me like a California Black Bear took a bite out of it. Don't feed the animals.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
06-20-2007, 10:02 PM
1964 22' Safari
SACRAMENTO
Hi Robert,
You're absolutely right! No feeding the animals, especially black bears!!!
06-21-2007, 09:16 PM
1984 31' Excella
Broken Arrow
, Oklahoma
Tires
As I have stared before,
You dont need tire with more weight carrying capacity, just tires designed to withstand the heat.
The 65 MPH Special Trailer (except for the Cooper Custom trailer plus) has no safety margin when run at 65 mph on hot summer days.
Those of us who have gone back to the original type tire that came on our trailers have stopped having trouble.
LT 225/75R16 Load Range D.
Beginner
