Old 08-13-2008, 07:48 PM   #1
rogerdodger's Avatar
Fresno/Clovis , California
2 new tires-which axle??
I am going to replace two tires, they were on the front axle. Is it better to put the new tires on the front, or rear axle, or does it make a difference. The other two ar not too old, and were replaced by the PO.
Thanks for any info.
Roger
Air# 29488
rogerdodger is offline   Reply With Quote
Old 08-13-2008, 07:52 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
It's more work, but rotate one of the old tires to one side, and put the two new tires on the other side. The reason is the new tires will have thicker tread, and be slightly taller, carry more of the weight, and wear (or even fail) faster because of it.
If you are concerned about reversing the rotation of the tire you will be saving and moving, it can be dismounted and remounted backwards on the wheel, maintaining the same direction of rotation.
Old 08-13-2008, 09:31 PM   #3
Ok, it is not more work at all, because I am going thru the brakes and bearing repack, all four wheels are off the ground. Do you recommend the new tires on the right(curb) side, since the road has a slight slope, or does it matter??
Roger
Air# 29488
Single axle or double axle. Which is easier to tow? dottie dawglips Towing, Tow Vehicles & Hitches 11 10-06-2007 10:37 PM
Old axle vs New axle feedback . . . GetOutDoors Axles 21 08-09-2007 01:59 PM
Tires, anybody ever heard of Specialty Tires of America? lebolewis Tires 3 06-08-2006 04:11 PM
Good Axle/ Bad Axle blucloud Axles 2 05-23-2004 04:15 AM
Help on tires: '67 Tradewind 24' double axle pinkflamingoes Axles 21 05-13-2004 10:31 PM
