07-13-2008, 07:55 PM
1967 26' Overlander
Fairbanks
, Alaska
1967 Overlander Spare
Was the spare tire carried on the front or back of the 1967 Overlander?
07-13-2008, 08:00 PM
2002 25' Safari
Dewey
Spares were an option on multi axle trailers. In case of a flat you could remove that tire and limp (slowly) into the next town for service. Airstream has never put spares on the rear as far as I know. The design of the shell and frame make it a bad idea.
The spare carries I have seen are under the front section of the trailer in a carrier attached to the frame. My spare rides in the back bed of my truck.
Richard
07-13-2008, 08:04 PM
1967 26' Overlander
Fairbanks
, Alaska
Thanks, I ask because the AS I am looking at to buy has a funny fold up bracket on the back bumper. It might be a bike rack or small motorcycle rack? Any Idea?
07-13-2008, 08:08 PM
Corona
Any rack on the back that was used to carry something, IS bad news.
That usually causes rear end separation, very quickly, that can be rather expensive to repair.
07-13-2008, 08:10 PM
1967 26' Overlander
Fairbanks
, Alaska
I will have to inspect this rack closer. Thanks for the heads up.
07-13-2008, 08:42 PM
, At Large
To nswer your original question, you could put a spare between the front of the body and the LP tanks, and Airstream makes a bracket that will hold a spare wheel and tire, which mounts under the front of the trailer.
10-01-2008, 09:16 PM
1966 22' Safari
Hilltop Lakes
How does one mount the spare between the front of the body and the propane tanks? Ours was originally carried on the rear bumper, and that's bad. We're definitely moving it from there, but need a new location. In the truck is the interim solution, but would like to have it mounted on the trailer. I've seen pictures of Airstreams with the spare behind the propane tanks, but there wasn't enough detail to see just how it was secured in place.
10-02-2008, 03:39 AM
My 26-foot 1967 Overlander has a flat bar that is attached with rivets to the front of the Airstream behind the LP tanks. The bar has a threaded hole, in which a long bolt with a flat plate are used to hold the spare in place.
10-03-2008, 08:33 PM
1966 22' Safari
Hilltop Lakes
Any chance you could post a picture of that spare tire mount? Sounds like what we need, but need info to find or build one.
Thanks.
10-03-2008, 09:17 PM
1966 22' Safari
Chico
While I don't think it is factory stock, this is what is on my 66Safari
NUTZ
10-03-2008, 11:22 PM
1966 22' Safari
Hilltop Lakes
Thanks. Shouldn't be too hard to make something like that.
10-04-2008, 07:59 AM
1974 Argosy 28
Fresno/Clovis
I am also interested in mounting my spare at the front of my AS. I saw somewhere on this site, an AS with the tire mounted below the propane tanks and frame, with a long bolt type of mounting. Anybody remember this, and where the pictures are posted??
Thanks for any help,
After this posting, I found what I am looking for. I put the pics in a word file. I don't know how to post the site here, if anyone knows how, let me know so I can point it to you. Thanks,
Roger
10-04-2008, 08:20 AM
1959 18' "Footer"
Corpus Christi
I would think that a fixture supporting the tire on the A frame would be better than the tire weight on the body. Anyone seen something like that?
10-04-2008, 09:05 AM
1974 Argosy 28
Fresno/Clovis
I found one made by freshair, neil holman.
http://www.airforums.com/forums/f438...r-41271-2.html
Not sure if this works, try the link above. There are two ideas at this link.
Roger
10-07-2008, 07:55 PM
1967 26' Overlander
Owings Mills
, MD
Amen, Andy. My previous owner had bike racks on the rear bumper. Not good. As for our spare, I'll probably go with the bed of the truck solution in the short term.
