08-10-2016, 05:20 PM
2002 19' Bambi
Golden
19' Bambi tires
Same question need a set of 19' Bambi tires due to tread separation. I am thinking of going with heavy duty trailer tire. Any recommendations?
08-10-2016, 07:12 PM
begorragirl
2017 25' Flying Cloud
Denville
, New Jersey
We got I think 10 ply trailer. I will look for name tomorrow.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
08-11-2016, 05:35 AM
Mantua
, Ohio
If they're 14 inch you might try Maxxis.
08-11-2016, 06:26 AM
2002 19' Bambi
Golden
Bambi Tire
Tire was a Walmart HI RUN ST225 75/15 installed by previous owner 9 years prior. Tread completely separated and tore out trim on the inside of the rear portion of wheelwell. This the first time I have had a tire tread separated from tire. Tire looked fine with no obvious dry rot or cracking. I am looking at a set of 6 ply Goodyear Marathon Load Rangers for $319 out the door.
08-11-2016, 06:35 AM
Sag Harbor
, New York
Welcome to the forum.
The Goodyear Marathons do not get good reviews here on the many tire threads, some of which are listed "above" in this sub-forum's rundown of topics:
http://www.airforums.com/forums/f438/
Michelins seem to get favorable comments, and we are thinking of switching to them, but not sure what the options are in 15" as they seem to moving mostly to 16" . . .
Peter
PS -- FYI this thread contains similar issues:
http://www.airforums.com/forums/f44/...ut-155074.html
PS2 -- Sorry for your damage, but 9 years may be pushing the limits of safety for a single-axle trailer tire IMO.
08-11-2016, 06:56 AM
2002 19' Bambi
Golden
Thank you for the reply. Any recommendation on a source for the wheel well trim?
08-11-2016, 08:31 AM
Mantua
, Ohio
Nine years old!? Way over the 5 year recommendation. It was an accident waiting to happen, and did.
08-11-2016, 09:12 AM
Sag Harbor
, New York
08-11-2016, 09:39 AM
2002 19' Bambi
Golden
Lesson learned, I have the replacement tires now I am running down the outer wheel trim. It does not appear that the inner trim was damaged.
08-11-2016, 10:14 AM
2017 25' International
Niagara-on-the-Lake
, ON Canada
Some sources , such as Discount Tire, recommend replacing trailer tires after as little as three years. The time is from the date of manufacture, not the date they were put into service. Tires can sit in a warehouse for a long time before being installed.
- "Time and the elements weaken a trailer tire.
- In approximately three years, roughly one-third of the tire's strength is gone.
- Three to five years is the projected life of a normal trailer tire.
- It is suggested that trailer tires be replaced after three to four years of service regardless of tread depth or tire appearance."
Here is the decoding information from Tire Rack.
Ray B.
08-11-2016, 11:41 AM
Mantua
, Ohio
I was trying to be nice.
