Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 08-07-2015, 12:05 PM   #1
Pat Cassity's Avatar
2015 27' FB International
Montgomery , Texas
16" Wheels and Tires
I apologize if this has already been discussed. I want to upgrade my 2015 27FB Serenity to 16" wheels and Tires. Is there any modification necessary on this trailer in order to accommodate the larger tires?
Retirement! Every day's a Saturday and Monday's no longer exist!
Pat Cassity is offline   Reply With Quote
Old 08-07-2015, 12:09 PM   #2
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
None.If you add a 16 spare you will need to slightly bend the finger on the carrier.Takes about 2 mins and a large cresent wrench
Old 08-07-2015, 12:18 PM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
There is no additional modification needed. In my opinion, this is about the best upgrade you can do. I have done it to two different Airstreams now.
On my 2015 Flying Cloud I sold the OEM tires and wheels and got back over one third of the upgrade cost.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 08-07-2015, 12:54 PM   #4
Montgomery , Texas
What wheels and tires did you end up purchasing?
Old 08-07-2015, 01:29 PM   #5
moosetags's Avatar
I bought the Sendel T03 wheels and the Michelin LTX M/S 2 tires in LT225/75R16E size.
I found the best price on-line at Performance Plus Tires in Long Beach, California. The shipped me the tires mounted and balanced. We installed them on the Airstream ourselves using Lego blocks to get one wheel up at a time.
We also added Centramatic Balancers.
I had this same combo on my 2005 Safari. When I sold it there were 60,000 miles on the Michelins with no visible tread wear.
Here are some photos of what the new tires and wheels look like.
Brian
ID:	244821   Click image for larger version
ID:	244823   Click image for larger version
Old 08-07-2015, 01:44 PM   #6
2008 27' Classic FB
Ontario , Oregon
16" wheels and tires
I've been trying to find SenDel wheels and am being told they are on back order for at least 60 days. Anyone have an idea of another wheel that will work and look as nice?
Shiloh4570 is offline   Reply With Quote
Old 08-07-2015, 01:55 PM   #7
Montgomery , Texas
Thanks Brian! How did you handle spare? By bending the pins on the carrier as Moflash suggested?
Old 08-07-2015, 04:47 PM   #8
HowieE's Avatar
Princeton , New Jersey
Images: 12
Looking for a steel wheel for the spare with these specs. Any thoughts?
Diameter 16" Width 7" Capacity Bolt Pattern 6 on 5.5" Center Bore 4.25" Offset + 5mm (moves wheel in)
2004 Excursion 4x4
Old 08-07-2015, 06:45 PM   #9
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Hi Pat,
You can find all kinds of wheels that will do as well.
I initially looked for the Sendels locally, but could not find them and didn't want to pay shipping from the US.
All I did was to get the specs of the Sendels that I knew would fit ..... diam x width, bore size, bolt pattern, offset, and weight capacity.
I went to a local tire shop who had the Michelins tires at a good price, and they found me some aluminum wheels that matched the specs.
They came back with several options, and I bought rims whose appearance I actually preferred to the Sendels for about $80 each. They are good for 3200 lbs. each.
So far I have used them on a trip to Arizona, another to Florida, an several shorter trips, and they are fine.
Very happy with tires and wheels.
Brian M. (A different Brian!)
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 08-07-2015, 07:08 PM   #10
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Different Brian - any pics?? 😄
Old 08-07-2015, 07:42 PM   #11
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
King of wheels out of LA ,got them off the internet, for 115 $ including freight
Old 08-07-2015, 08:03 PM   #12
Wingeezer's Avatar
2005 30' Classic
I believe I do have a pic, but I never seem to have much luck trying to post pics on this forum!
If you want to PM me your email, I'm sure I can find one and send!
Brian.
2005 Classic 30'
Old 08-07-2015, 08:06 PM   #13
AStreamNerds's Avatar
Manassas , Virginia
[emoji38] Thanks for the chuckle!
Our Website: https://airstreamnerds.com/
You Tube Channel "Airstream Nerds": https://www.youtube.com/airstreamnerds
Find Us on Facebook: https://www.facebook.com/AirstreamNerd/
AStreamNerds is offline   Reply With Quote
Old 08-07-2015, 08:16 PM   #14
2008 27' Classic FB
Ontario , Oregon
16" wheels & tires
Wingeezer, do you have a contact number and part number for the wheels you like?
Old 08-07-2015, 08:30 PM   #15
bganso's Avatar
1994 30' Excella
Truckee , California
Having the SenDel T03 and Michelins installed tomorrow at 8:30 AM. They told me I got the last 4 wheels from the warehouse. I'll try to remember to post the pics.
bganso is online now   Reply With Quote
Old 08-07-2015, 09:09 PM   #16
W , New England
Here are Different Brian's wheels (with his permission to post) 😃
Name:	ImageUploadedByAirstream Forums1439003317.784471.jpg
Old 08-07-2015, 10:20 PM   #17
moosetags's Avatar
At first I tried bending the pins out with the rack still attached to Lucy. This didn't work too well as it is hard to get any leverage. I removed the rack in about two minutes. it is held to the frame with two bolts. Once I had it out, bending the pins was easy with a piece of pipe.
Here are a few photos.
Brian
ID:	244879   Click image for larger version
Old 08-08-2015, 07:24 AM   #18
Wingeezer's Avatar
2005 30' Classic
I bought five of the wheels for $79Can. each in Oct 2013.
The only info I was given before buying was a copy of a page from a Green Ball Tire website that showed the design and specs.
The Wheel part number from the GreenBall website was GB174-66655G and the specs ....
16"x6"
0 offset
4.25" pilot
8 - 5 1/2 bolt pattern.
3200 lb.
I'm afraid the info won't be much use now though, because I think the reason I got a good price on them was that it was a discontinued style.
Brian.
2005 Classic 30'
Old 08-08-2015, 08:05 AM   #19
Montgomery , Texas
Brian, I am sure that bending the pins is a common practice, as I have read about others doing so numerous times. My concern is that bending the pins may weaken them or even cause them to break during the bending process. I am wondering if Airstream offers a spare tire holder that will accommodate the 16" wheel.
Old 08-08-2015, 09:03 AM   #20
Moflash's Avatar
You only bend the pin approx 1 in.It does not weaken the pin.Lol.I dropped the carrier to remove old spare and used a large Cresent wrench to pull the pin outward.Very simple but some people make a big deal out of nothing......I did not remove the tire carrier.
From 14" wheels to 16" wheels Air Cruiser Wheels, Hubs & Bearings 24 09-16-2011 07:18 AM
15" to 16" Wheels/Tires on 2007 Safari Rollertoaster Tires 53 01-23-2011 06:41 AM
from Old axles/15" wheels/bias tires to Dexters/16" wheels/LT tires fitzjo1 Axles 8 01-18-2011 06:41 PM
