The clearance of the front of the front tire is acceptable at 1", as tire movement over uneven road surface will be more or less up and down. The clearance issue would be under a dymanic circumstance when the axle is moving up and the trailer body is moving down. Is there enough clearance between the top of the tire and the wheel well?
>>>>>>>>>>Action
