Old 04-02-2016, 10:16 PM   #71
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
Here are 15" GYM and 16" michelins.
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 04-03-2016, 06:00 AM   #72
paiceman's Avatar
Upper St Clair , Pennsylvania
Originally Posted by Al and Missy View Post
Ray,
I have heard from multiple sources that you should initially check torque more often after mounting wheels and my experience would seem to confirm that. I think the recommendation is after 50, then 100, and finally 200 miles or at 50, 150, and 350 from start. I usually had at least one lug nut loose on each wheel after just 50 miles.
Al
We did just that when we first picked up our trailer. 50, 100 and 250. Now every other day. Still, after 10,000 miles one lug on each wheel can be moved, I would not by any means call it loose, but it does move.
SAFE TRAVELS
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 04-03-2016, 07:38 AM   #73
MaineStreamer's Avatar
2007 20' Safari
Saco , Maine
Originally Posted by Ted S. View Post
Added Centramatics and had everything spun balanced with my TPMS sensors in place. Inflated to 80psi.
I feel better now.
Which specific Centramatics did you use?
http://www.centramatic.com/wheel-bal...pe=Trailers-RV
Marty Womer
Saco, Maine
MaineStreamer is offline   Reply With Quote
Old 04-03-2016, 11:07 AM   #74
2015 30' FB FC Bunk
Ayer , Massachusetts
I used the 200-221 Special.
After much debate and research, including a lengthy call the the manufacturer, that is what I chose. It is however, not you only option.
http://www.centramatic.com/wheel-bal...00-221_Special
The website is confusing by the way, these are under the RV section, not Trailer section.
Ted S. is offline   Reply With Quote
Old 04-03-2016, 11:21 AM   #75
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We installed the larger diameter Centramatic 300-356 all A plates on our 16" tires.
Old 04-03-2016, 12:25 PM   #76
2015 30' FB FC Bunk
That was my first choice before I talked to them, but both options are good.
Old 04-03-2016, 09:11 PM   #77
DoublTrouble's Avatar
2015 27' FB International
Carlsbad , California
FYI
We just covered 200 miles today. The first trip on the 16s. I stopped to check the mMcGard
Lug nuts twice. Each time I was able to get a bit tighter to 110.
It's a good idea to check yours. Frankly, I did not believe it possible. 😮
DoublTrouble is offline   Reply With Quote
Old 04-03-2016, 09:17 PM   #78
Btw, we were beat to death on
I - 5 north through Los Angeles.
I could not appreciate the wheels or Centramatics. 200 miles in 6 brutal hours. I'm looking for a different way home.
But no popped rivets.....
Old 04-04-2016, 06:43 PM   #79
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Billings to Oceano , first trip for the 16" michelins, checked the torque 5 times, everything is rollin easy....
Old 04-06-2016, 08:05 AM   #80
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Are the Sendel wheels clearcoated or raw aluminum? It seems that if they are not clearcoated then it would be a good idea to get this done before the new tires.
Steve, Christy, Anna and Scout (Border Collie deceased 11-30-2016)
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 04-06-2016, 08:16 AM   #81
dznf0g's Avatar
Oswego , Illinois
They are clear coated.
-Rich-
Old 04-06-2016, 05:20 PM   #82
Redondo Beach , California
I'd like to know how the Michelin's worked out for you.
I'm thinking of upgrading to 16" (Sendel) wheels and Michelin's as well.
Michelin says they don't make a "trailer tires" in 16" . They only tires available in load range E in the 225/75R16 are LT not ST tires.
What is the down side to putting a LT tires on a trailer.
I'm not happy with the GYM just returned from a 7800 mile trip and the GYM were a constant worry. Had to replace two enroute. Luckily no catastrophic events just a pain in the butt type of problem.
Pulling an '06 25' FB Safari.
TV ' 06 Ford Super Duty
Thanks for any updates or advise.
cwojoe is offline   Reply With Quote
Old 04-06-2016, 11:33 PM   #83
2007 20' Safari
Saco , Maine
What does GYM mean or refer to?
Marty Womer
Saco, Maine
Old 04-07-2016, 12:32 AM   #84
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Good Year Marathon "ST" trailer tires.
Ken
Michelin LTX M/S versus Michelin LTX M/S 2 - Which Would You Choose? doutterson Tires 40 10-23-2016 10:08 PM
16" SenDel/Michelin Combo sailorii Tires 28 01-28-2016 10:51 AM
4 Sendel S20T Wheels & Goodyear Marathon Tires WanderStream Airstream Classifieds 0 12-17-2015 02:42 PM
16" SenDel Wheels and Michelin LTX Tires Jcoop Airstream Classifieds 2 01-19-2014 09:37 PM
Michelin LTX M/S tires... Dwight Tires 7 01-14-2010 06:21 PM
