Old 03-29-2016, 08:08 PM   #43
DoublTrouble's Avatar
2015 27' FB International
Carlsbad , California
I have a slightly different approach. My 16s go on this Friday. I have asked for helium in order to reduce some tongue weight.... 😤
DoublTrouble is offline   Reply With Quote
Old 03-29-2016, 10:39 PM   #44
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Last year when I moved from 5120' ASL to 63' ASL I gained 10 lbs. How do you explain that.. Also, at low tide around here, there are plenty of odors to get high or low with. My favorite is 3 day old dead fish, followed by rotting seaweed.
Ken
Old 03-30-2016, 04:48 PM   #45
Ray Eklund's Avatar
2014 25' International
Boulder City , Nevada
Ken
You need to replace one of the two scales.... somethings smells... fishy to me.
Human Bean
Ray Eklund is offline   Reply With Quote
Old 04-01-2016, 09:00 AM   #46
The wheels are on, the 16 inch michelins, the dill TPMS and centramatics. Only had one glitch with centramatics, the holes for the lug studs were slightly imperfect and a bit of filing was needed. The 16 in spare went in ok with a push from my foot....
Now it's travel time!
Old 04-01-2016, 09:01 AM   #47
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
With peace of mind-
Priceless-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 04-01-2016, 09:03 AM   #48
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Perhaps the ice cream regimen was increased at the lower altitude to increase the weight by 10 pounds?
Old 04-01-2016, 10:15 AM   #49
Ag&Au's Avatar
I figured out what caused it. The weight gain was obviously the result of the weight of the extra 5057 feet of air pushing down on me.
Ken
Old 04-01-2016, 10:49 AM   #50
malinois38's Avatar
2008 28' International
Happy Valley , Pennsylvania
Hitch Ball Adjustment?
Seriously considering this upgrade. Has this upgrade from 15" to 16" tires required anyone to adjust the hitch ball height??
malinois38 is offline   Reply With Quote
Old 04-01-2016, 11:10 AM   #51
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Word on the street, as it were, is that the trailer height changes by no more than 1/2". Whether one has to adjust the hitch ball (or anything else) in response will probably vary from one user to the next based on their current setup.
Rocinante is our 2014 International Signature 27FB
Old 04-01-2016, 11:41 AM   #52
m.hony's Avatar
2013 30' Classic
I did not adjust my ball height.
1/2" of height 20' from the ball didn't change the height/angle much.
The stance of the trailer on the truck still appears the same.
TAC #MS-10
Airforums #70955
Old 04-01-2016, 11:46 AM   #53
FLMarine's Avatar
2009 27' FB International
_ , Florida
16" Sendel Wheels & 16" Michelin LTX Tires
I replaced my 15" bad year marathons in August of 2013 after the front right marthon tread separated and did a little over $5500 with of damage to my 2009 27FB. I had a thread on airforums with pictures about my experience.
I had the wheels and tires replaced with the Sendel 16" rims and Firestone e rated tires. So far I'd estimate I've towed around 20,000 miles in the last three years and it has towed great. I tow at about 68mph and 65psi on the tires.
My Brother put the 16" sendels and e load tires on his 30 bunkhouse and it has towed great for him so far.
I see no downsides to the upgrade as long as there is clearance.
FLMarine is offline   Reply With Quote
Old 04-01-2016, 12:47 PM   #54
m.hony's Avatar
2013 30' Classic
What he said^
TAC #MS-10
Airforums #70955
Old 04-01-2016, 01:09 PM   #55
Rgentum's Avatar
2016 27' Flying Cloud
Woodinville , Washington
Forget the Nitrogen!!! The "solution," when changing tires is to add several chickens to the inside of each tire & then mount the tire on its rim. Therefore, when driving, the chickens will flap their wings, and the downdraft will provide sufficient downward force to counter the weight of the wheels etc. & result in your Airstream truly streaming in air --- floating --- in back of your tow vehicle. Voila: Unlimited mileage tires, whether Goodyears, Michelins, or whatever!!!
Alta & Richard, Seattle area --- WBCCI 8873
"Aurum": 2018 Ram/Cummins 3500
"Argentum": 2016 AS FC 27 FB
"BigDog": M Harlequin Great Dane, 150 lb
WL7Z --- NAUI --- WSBA
Rgentum is offline   Reply With Quote
Old 04-01-2016, 01:24 PM   #56
Mrmill's Avatar
2016 30' International
2015 25' FB Flying Cloud
Paso Robles , California
Funny you should ask!
We just got home from our local tire store with 5 new Michelin LT225/75R16E tires installed on Sendel T3 aluminum rims. Parked it and right away noticed that its slightly higher in the rear now. We will adjust our hitch ball height to compensate.
Mrmill is offline   Reply With Quote
Michelin LTX M/S versus Michelin LTX M/S 2 - Which Would You Choose? doutterson Tires 40 10-23-2016 09:08 PM
16" SenDel/Michelin Combo sailorii Tires 28 01-28-2016 09:51 AM
4 Sendel S20T Wheels & Goodyear Marathon Tires WanderStream Airstream Classifieds 0 12-17-2015 01:42 PM
16" SenDel Wheels and Michelin LTX Tires Jcoop Airstream Classifieds 2 01-19-2014 08:37 PM
Michelin LTX M/S tires... Dwight Tires 7 01-14-2010 05:21 PM
