Old 07-30-2019, 07:18 AM   #661
waninae39's Avatar
2017 22' Sport
NCR , Ontario
NOTE: be sure to ask for metal valve stems when the tires are instlled on the wheels.
they are the same cost.
the plastic ones can break and crack over time.
waninae39 is offline   Reply With Quote
Old 07-30-2019, 04:40 PM   #662
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
Originally Posted by waninae39 View Post
when i phoned around town, no dealer had issue finding next day stock on Michelin Defender 225/75-16" LTX E rating profile.
the same profile in 15" are very hard to come by , as very few truck use anything as small as 15" any more. most use 16" up to 22"
They do not offer a 15" Michelin in an LT rated tire anymore; just in 16" and larger. That is why many of us with 15" went to the new GoodYear Endurance... I used to run the 15" Michelins on my older 25' AS's but last time I purchased, I ended up with Michelin P rated Passenger tires on my 2014 model when I replaced the OEM GYM's. Although the Michelins I had them put on were the LTX Defender tires, they were not E rated. The load was fine for the overall load/weight of my AS, but I felt the AS handling was mushy and like it was leaning/riding on the sidewalls when I changed lanes or was in a turn...
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Old 07-31-2019, 07:20 AM   #663
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We use the Dill 1506 TPMS system on both our 2014 Classic and 2015 23D International Serenity and the senders are mounted inside the tire and have a metal valve stem.
I do not trust any tire made by GoodYear. Period.
Never had a Michelin tire failure in over 45 years on my cars and trucks. Switched all three Airstreams we have owned to Michelins as soon as possible after purchase.
In fact, I arrived at the selling dealership of the 2014 23D with 15” Michelins mounted on 15” five lug nut SenDel wheels and left the stock 14” wheels and GYM tires at the dealership.
Old 07-31-2019, 08:08 AM   #664
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I used to think that way but after having a set of all season Michelins come apart on my wife's car, I now feel that they may be better than most, but they are not perfect. Michelin did warranty the whole set and apparently had a raft of replacements. We have been running Conti's on her car ever since and I noe have Yoko's on my Airstream.
Larry
lsbrodsky is online now   Reply With Quote
Old 07-31-2019, 07:37 PM   #665
waninae39's Avatar
2017 22' Sport
NCR , Ontario
the new Michelin 225/75r16 tires and 16" wheels are on our As22FB. they fit well.
we had to use 5 sheets of plywood under the bottle jack even though it has 20" of reach. we put 120 ft-lbs torque on the 16" wheels, 110 ft-lbs are used for 15" wheels
no mods were need as the tires are only 1/2" closer to the sides
here is the bottle jack in action
Name:	Jack with 5 inch of plywood-a.jpg
Old 08-01-2019, 01:22 PM   #666
Ray Eklund's Avatar
2014 25' International
Boulder City , Nevada
Great posts. Nice... jack, too.
Get some 12" square 3" or thicker squares cut from scrap lumber to put under your jack. The thicker base blocks are stable and the jack will take less effort.
My brother in law was towing a nice car in an enclosed car trailer and I looked at his 15" tires. A brand I had never seen and C RATED. After mentioning C Rated 14 inch tires... he bought a set of E Rated Tires when he arrived home. The car was worth more than most new Airstreams. So... not everyone is up on tires.
Human Bean
Ray Eklund is offline   Reply With Quote
Old 08-04-2019, 04:03 PM   #667
1994 30' Excella
Pleasanton , Texas
Tires, 1994 excella30
In 48 pages of information on changing to 16 wheels, Im sure this subject is covered. However, Im not savay enough to sift through all that info to find the answer I need.
Can I change my 1994 Excella 30 to16 wheels and LT tires. Will they fit? Does it work?
craigdowdy is offline   Reply With Quote
Old 08-05-2019, 09:50 AM   #668
Ray Eklund's Avatar
Originally Posted by craigdowdy View Post
In 48 pages of information on changing to 16” wheels, I’m sure this subject is covered. However, I’m not savay enough to sift through all that info to find the answer I need.
Can I change my 1994 Excella 30’ to16” wheels and LT tires. Will they fit? Does it work?
Unlike Dating Services, if you do the research yourself there is much to learn.
I suggest starting a thread concerning your trailer. All it takes is one... Yes! and you are off to the Race Track. The first Date may be your best if you get to squeeze the product in advance of purchase.
Human Bean
Old 08-06-2019, 09:21 AM   #669
1972 25' Tradewind
Calgary , Alberta
Yes. Speed dating.
Monza is offline   Reply With Quote
Old 08-22-2019, 08:43 PM   #670
waninae39's Avatar
2017 22' Sport
NCR , Ontario
canam rv told me to use 55psi cold ( they go up to 68 psi hot) in the 16" Michelin tires on a Bambi
i was using 70PSI cold- (they went up to 79 psi hot)
Old 08-22-2019, 08:56 PM   #671
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
16" Sendel Wheels & 16" Michelin LTX Tires
I always puzzle over this (did a long thread in here the beginning of this season with new GYEs).
Note that the RATE of rise in pressure is nearly double starting at 55 PSI - 24% over 55 cold vs 13% over 70 cold. Yours is a single axle, yes? Mine is a double and seeing 6000 on the scales, 55 cold worked for me with the 15 Michelins but seemed too low on the GYEs based on the rise in temps. I went up to 75 I think - too much pressure - too much bouncing - so came back to 65 cold which is plenty of capacity, about a 15% rise in PSI over cold and a fairly decent ride (though not as pillowy as the Michelins were...).
I dont know that theres a single right or wrong here - just sharing some of my personal experience. Worth everything you paid for it
Old 08-31-2019, 02:09 PM   #672
Ray Eklund's Avatar
2020- 30 & 2019- 33 foot Classics use 16 Inch Michelins
The 2020 30 RV Classic and the 2019 33FB Classic both use LT225/75R/16LRE tires as standard equipment. Found this for you at the Las Vegas Airstream yesterday.
Hope that helps.
Human Bean
Old 09-17-2019, 09:03 AM   #673
c3po's Avatar
2017 25' Flying Cloud
McDonough , Georgia
Hope that helps.
FYI... I've been lurking this Forum for months and just got my password issues resolved so I can post/reply now I have ordered the Sendel T03-66655T 16X6 6/5.5 Aluminum T03 Trailer Wheels (5 of them), and the NEW REPLACEMENT tire for the LTX tire is: Michelin AGILIS CROSSCLIMATE LT225/75 R16 E115 112R BSW . Discount Tire sez everything should be in within the next week or so. Next trip not scheduled till November.
c3po is offline   Reply With Quote
Old 09-18-2019, 09:26 AM   #674
Registered User
2016 28' International
Rochester , Michigan
Thank you, I have been also learning which Michelin to order
westphalia is offline   Reply With Quote
Old 09-19-2019, 01:49 AM   #675
switz's Avatar
2014 31' Classic
Images: 8
The Centramatic wheel balancers for the 16” SenDel wheels with six lug nut bolt pattern is #300-356 All “A” plates. Order directly from their website (Centramatic.com) and no sales tax if you are not in Texas.
Old 09-19-2019, 08:50 AM   #676
Ray Eklund's Avatar
The original tires at Post #1 have EVOLVED into, of course, a better tire by Michelin. (?)
Agilis Crossclimate LT225/75/R16 load range E
Same Sendel wheels. I replaced the original 15 inch SPARE tire/wheel as it would be a 15 inch steel wheel and matched the other four 16 inch Sendel wheels.
Like Switz I purchased four Centramatic #300-356 A Plates for my 16 inch wheels. Installed them yesterday at home, one at a time. Attached the tow vehicle and lifted one tire, removed, added Centramatic, snugged lug nuts, lowered and torqued to 110# (100# to 110# in the manual). After the first service station I will recheck the torque.
Many claim amazing things about the Centramatics... I will see. If all are true... I will be very satisfied. Much like taking vitamins... I do not know if I feel any better or not, before taking them.
The Centramatics are not wrapped at all in a large carton. I had emailed a member if his were shipped this way, but no comment. So... I am on my own. Obviously not an issue being shipped from Texas. A bit of abrasion of being tossed around by UPS.
Human Bean
Old 09-20-2019, 07:18 AM   #677
switz's Avatar
2014 31' Classic
Images: 8
Since the Centramatics are not polished and are behind the wheel and get covered in brake dust, appearance is not high on their list of things to do.
16" SenDel/Michelin Combo sailorii Tires 45 04-06-2019 06:53 AM
Michelin LTX M/S versus Michelin LTX M/S 2 - Which Would You Choose? doutterson Tires 40 10-23-2016 09:08 PM
4 Sendel S20T Wheels & Goodyear Marathon Tires WanderStream Airstream Classifieds 0 12-17-2015 01:42 PM
16" SenDel Wheels and Michelin LTX Tires Jcoop Airstream Classifieds 2 01-19-2014 08:37 PM
Michelin LTX M/S tires... Dwight Tires 7 01-14-2010 05:21 PM
