Old 09-11-2016, 05:35 AM   #309
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Have been stock on the Classic since 2015 and were stock on the Eddie Bauer.
Optional on other larger 2 axle trailers through the dealer or Jackson Center.
When you walk through the front door at the service center the first thing you see is 16" Sendel T03 wheels and Michelin LT tires- at least 2 years ago when I went- so apparently it was a popular upgrade in 2014 and previous years, too.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
m.hony is online now   Reply With Quote
Old 09-11-2016, 10:46 AM   #310
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
The GVW of our 2014 31' Classic is 10,000 pounds.
The stock GYM ST225/75R15D tires (in model year 2014 [and earlier] and have been replaced with the tires we changed to since 2015 model year) are rated 2,540 pounds @ 65 psi. Thus the GYM tire capacity is 10,160 pounds. The Michelin LT225/75R16/E LTX M/S2 tires are rated 2,680 pounds @ 80 psi for a load capacity for four of 10,720 pounds. So we have a greater load carrying capacity with the 16" Michelins or at lower loads have a greater safety margin.
Our actual loads by tire location camping ready after all the modifications
Classic scale numbers May 2015
……….1200 ———————1200
2034…………..2042 ——— 4076
1921…………..2062 ——— 3983
____________________9259
The removal of the six gallon Dometic water tank and water heater and replacing with a Truma AquaGo Comfort instant on water heater reduced the load on the street rear tire.
The Load E tire loads at different pressures
80psi 2,680 (E)
75psi 2,560
70psi 2,440
65psi 2,335 (D)
60psi 2,190
55psi 2,060
50psi 1,940 (C)
45psi 1,790
My target tire pressure of 72/73 psi means each tire has 2,500 pound capacity with the heaviest having a 21% safety margin.
I have had GYM tire failures on my motorcycle trailers. In nearly 50 years of Michelin tire use,I have never had a tire failure. Thus all three Airstreams I have owned were converted to Michelin tires. Works for me.
YMMV
Old 09-25-2016, 11:14 AM   #311
Yulee , Florida
New 16" wheels and tires..great!
Thanks for all the info...new shoes are great!
Griner3 is offline   Reply With Quote
Old 09-25-2016, 01:26 PM   #312
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Western WA , Washington
Yikes, they mounted the tires and your trailer sideways!
The sideways thing is kind of a pain, but I've found that I can fix that before posting if I open the picture in any app, resize it and then post the resized photo instead of the original. For some reason, AF software often rotates the original cameraphone image 90 degrees.
Rocinante is our 2014 International Signature 27FB
Old 09-25-2016, 01:30 PM   #313
Yulee , Florida
Thanks.. lol.. I was on my iPhone or I would have fixed it.
Old 09-25-2016, 02:31 PM   #314
Tincampers's Avatar
Sneedville , Tennessee
Originally Posted by Moflash View Post
Sorry to tell you this but the real reason that manufacturers use ST tires is because they are the cheapest they can buy wholesale.
u
Source? How about they use trailer tires because they are selling trailers?
Tincampers is offline   Reply With Quote
Old 09-25-2016, 03:02 PM   #315
Yulee , Florida
Originally Posted by Tincampers View Post
u
If you feel the company is ultimately buying the tires because they are the absolute best option you are sadly mistaken. At the end of the day what they put on the trailer is a business decision driven at its core by cost and profit. That's not a negative it's a fact.
Old 09-25-2016, 03:15 PM   #316
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
When I bought my 2001 Safari in 2014 the tires had been changed once but the tires on it were aged out, and the spare was original. I opted for the 16" Michelins and Sendel T03 wheels and added a Dill TPMS. When I traded it in on my 2002 Classic this past February, I moved the wheels and tires to the Classic. On the way home I ran over some debris left on a exit ramp from an accident. About a mile later, the Dill alarmed - not the tire's fault. I have now run the wheels and tires about 8 months and 11,000 miles, for a total of about 30 months and 18,000 miles with no incidents. I find the air pressure to be very stable, hardly ever needing any air added and even then, only a pound or two.
The only caution I would give is watch your wheels for filiform corrosion. Right about 1 year mine started corroding, and this is after I put some Collinite Insulator Wax on them before they were installed. Unfortunately I didn't address it with Sendel before the 1 year warranty ran out so now I'll have to live with it.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Al and Missy is online now   Reply With Quote
Old 09-26-2016, 03:55 PM   #317
The Colonel's Avatar
2017 25' Flying Cloud
Navarre , Florida
Originally Posted by Griner3 View Post
Yea I noticed the T03 do have a slightly higher rating (300lbs) but the 25' I have I'm already super on the + side. Thanks for the extra info though!
Griner3, I just put T02s with my new 16" MIchelins for the same reason.
Southern Belle
The Colonel and Southern Belle
The Colonel is offline   Reply With Quote
Old 09-26-2016, 03:58 PM   #318
Yulee , Florida
Southern Belle
Yea I'm very happy with the result... just took it to fort wilderness this past weekend! We also added the Dill TPMS which is great!
Old 09-26-2016, 04:03 PM   #319
m.hony's Avatar
2013 30' Classic
Fort Wilderness is more exciting than T02 or T03 or LT tires, but those things are an expedient to a safe and worry free trip to Disney.
Hakuna Matata for the rest of my days-
It's my problem-free philosophy-
TAC #MS-10
Airforums #70955
Old 09-27-2016, 07:18 AM   #320
dcasr's Avatar
1990 29' Excella
Stone Mountain , Georgia
_____________
Do you mean 3000 lbs since (300lbs) can't be right for a weight capacity. And 300 psi would be kind of high though maybe possible.
2016 Duramax/Allison Crewcab 4x4
WBCCI 2456 Georgia Unit 32
1990 Excella 29' Centramatics
2016 GMC Sierra Crew Cab 2500 HD 4x4
6.6L Duramax + Allison, 3.73 axles
dcasr is offline   Reply With Quote
Old 09-27-2016, 07:20 AM   #321
Yulee , Florida
Originally Posted by dcasr View Post
_____________
300lb is the difference in load capacity between the 2 rim styles.
Old 09-29-2016, 04:36 AM   #322
paiceman's Avatar
Upper St Clair , Pennsylvania
Just for giggles I am pasting a disclaimer I found in our 2017 Classic Owners Manual I am reading as we picked her up two days ago. Yes we have the 16' Michelins as standard equipment, but I've also put them on three other Airstreams we have owned starting back in 2010.
The maximum speed rating on the tires installed
on your trailer is 106 MPH. Do not exceed this
rating. Failure to heed this warning could cause
catastrophic tire failure resulting in property
damage, personal injury, and/or death.
SAFE TRAVELS
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Michelin LTX M/S versus Michelin LTX M/S 2 - Which Would You Choose? doutterson Tires 40 10-23-2016 10:08 PM
16" SenDel/Michelin Combo sailorii Tires 28 01-28-2016 10:51 AM
4 Sendel S20T Wheels & Goodyear Marathon Tires WanderStream Airstream Classifieds 0 12-17-2015 02:42 PM
16" SenDel Wheels and Michelin LTX Tires Jcoop Airstream Classifieds 2 01-19-2014 09:37 PM
Michelin LTX M/S tires... Dwight Tires 7 01-14-2010 06:21 PM
