Old 08-18-2016, 02:42 PM   #211
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Western WA , Washington
That's very good advice, thanks!
We've been using the flow-thru sensors from TST for some time, so we'll just transfer those to the new wheels and re-program the system for the new pressures. Based on the Michelin inflation tables I'm guessing we'll want 65-70 PSI in the new tires.
Rocinante is our 2014 International Signature 27FB
Old 08-18-2016, 02:59 PM   #212
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I run 65 psi cold in my tires.
It gets closer to 70 psi as we travel and the tires heat up.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 08-19-2016, 07:18 AM   #213
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Target pressure for our 31' Classic is 72.5 psi from the Michelin tire pressure table. So the digital thermometer is either at 72 or 73 when the pressure is set.
Old 08-24-2016, 04:19 PM   #214
Ray Eklund's Avatar
2014 25' International
Boulder City , Nevada
Ran the gauntlet with the new wheels and tires through National Forest roads of Wyoming's High Country for the last two weeks.
Mud... dirt... soft... compact... all season boulder and rock routes... not ONE single issue.
Deep tread gains traction in the mud, but releases it onto everything in the way. Fender wells and front of the trailer rock guards! By the pound... not ounce.
The tailer tracked perfectly through all Cross Winds and any traction issues that could be tested by a steep grade climb out of Double Cabin, DuBois, Wyoming in a rain that was steady for 24 hours!
Of course, I must give credit to the SAME Michelin AT2 tires on my Ford F350.
After getting down to lower, warmer and drier elevations... the mud became concrete upon the Rock Guards and Fender Wells of our tow vehicle and trailer. As luck would have it... there is a Car/Truck Wash in Pinedale, Wyoming that was built with this all in mind... after $14.00 out of my pocket and pounds lighter!
I am absolutely thrilled with the results of both tow vehicle and tracking of our 25 foot Airstream. We could have easily been ditched and needed to be towed... although I have to give credit to a number of others who had to depart on short notice and also made it with no major difficulty. No doubt due to the driving skills of those navigating the pot holes of water and slop tossed onto the front of their trailers and coating all of the fender wells.
Double Cabin is missing several hundred pounds... as a group contribution to testing our Airstreams and Tow Vehicles during trying times!
The only thing with any noticeable wear... ME.
Human Bean
Ray Eklund is offline   Reply With Quote
Old 08-24-2016, 06:25 PM   #215
2007 22' International CCD
Ray, sounds like the trip was fun. Thanks for the real life test report on the tires and wheels.
KE4GNK/AE
Old 08-24-2016, 07:49 PM   #216
Ray Eklund's Avatar
Just finished a Thread on LTX and LTX2 Michelins. The latest comment was that they are not Mud and Snow tires. I can verify in MUD they do get traction and toss the mud to the rear... which is where my trailer was at the time.
The LTX2's on the trailer also tossed mud, and when dry, dust, as if I were a Crop Duster.
Snow tires are great in SNOW.
Snow tires are poor on dry pavement compared to LTX tires.
Snow tires are great in mud and back country unpaved roads.
Snow tires are poor for highway travel and noise beyond comprehension.
Our full time 4x4 2008 Land Cruiser, 2012 4x4 Tundra and now our 2016 Ford F350 use LTX Michelins. For ALL Seasons... a great tire.
... although this Spring at home in Castle Rock, Colorado with three feet of snow upon our block long driveway... I became stuck in front of our garage with the LTX AT2 tires. The drifts in the front of the garage were closer to four feet and I had to plow the driveway and dig the Tundra out... for the first time, ever. I suspect that I was now high centered and the tires were barely able to touch the asphalt driveway.
These tires are a great compromise and when dragging your differentials and axles in deep snow... maybe even a 'snow tire' may not have had a much better advantage. Next Spring... catch a Colorado Blizzard and show me yours...
Human Bean
Old 08-25-2016, 10:26 AM   #217
CruizinDux's Avatar
Eugene (Tracktown USA) , Oregon
Originally Posted by Ray Eklund View Post
Just finished a Thread on LTX and LTX2 Michelins. .....
Our full time 4x4 2008 Land Cruiser, 2012 4x4 Tundra and now our 2016 Ford F350 use LTX Michelins. For ALL Seasons... a great tire..
Ray was the above thread this thread, a different thread on AF or elsewhere?
You're speaking of LT225/75R16/E LTX M/S2 correct?
I'm thinking of using these on my TV but dropping down from 19" rims to 17's, then the following year the going with the 16" sendels and the above.
Thx
CruizinDux is offline   Reply With Quote
Old 08-25-2016, 11:06 AM   #218
Rivet Slave
Rocinante's Avatar
16" Sendel Wheels & 16" Michelin LTX Tires
Happy to say that Rocinante got new shoes yesterday, size 16". She also got Centramatic balancers. Click image for larger version
Name:	ImageUploadedByAirstream Forums1472141200.551305.jpg
Old 08-25-2016, 11:31 AM   #219
m.hony's Avatar
2013 30' Classic
Baked Potato's shoes have silver inlays rather than black inlays.
TAC #MS-10
Airforums #70955
Old 08-25-2016, 04:43 PM   #220
Rivet Slave
Rocinante's Avatar
Those are nice too! We just thought the black would be fun for a little "drama".
Old 08-25-2016, 05:18 PM   #221
Boxite's Avatar
2008 22' Sport
It may be a post I made to which Ray is referring.
I bought the Michelin LTX M+S 2 tires for my truck and when I got home perused the label which the installer had removed. I also checked online and found that the "winter triangle" or "mountain snowflake" symbol which genuine winter/snow tires should display is not on the tire.
From the MIchelin site, where they clearly are proud of this tire, and they also noted that the symbol is not applicable to this tire.
I personally bought this tire because I thought it would be a good snow tire, and perhaps it might serve that as well as other tires, but the LTX is NOT a severe snow tire, and I thought the M+S label was misleading. YMMV
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 08-25-2016, 05:35 PM   #222
m.hony's Avatar
2013 30' Classic
My decision was based on that the OE wheels on the Eddie Bauer with the wide black fender trim had the black inlays and the OE wheels on the new Classic have silver inlays.
I have a 2013 Classic.
TAC #MS-10
Airforums #70955
Old 08-25-2016, 05:38 PM   #223
CruizinDux's Avatar
Originally Posted by Rocinante View Post
Happy to say that Rocinante got new shoes yesterday, size 16". She also got Centramatic balancers. Attachment 269942
Rocinante looking sweet. Another 20-footer, Waldosgone I believe also went for the black inlays and they're starting to grow on me. A little contrast with the the AS seems to make a huge difference.
Old 08-25-2016, 05:45 PM   #224
CruizinDux's Avatar
Thanks Boxite, that helps. I think I need to do some homework re OR chain laws to see how this trigger chain requirements (when not towing). quite frankly if I need to chain up the TV and the TOAD, I'll be waiting at the bosom of the hill for clear AC
Thx
Michelin LTX M/S versus Michelin LTX M/S 2 - Which Would You Choose? doutterson Tires 40 10-23-2016 10:08 PM
16" SenDel/Michelin Combo sailorii Tires 28 01-28-2016 10:51 AM
4 Sendel S20T Wheels & Goodyear Marathon Tires WanderStream Airstream Classifieds 0 12-17-2015 02:42 PM
16" SenDel Wheels and Michelin LTX Tires Jcoop Airstream Classifieds 2 01-19-2014 09:37 PM
Michelin LTX M/S tires... Dwight Tires 7 01-14-2010 06:21 PM
