Old 04-15-2016, 07:47 AM   #141
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
There are two part numbers for the SenDel T03-66655 wheels, one with black highlights = T03-66655BM and the plain aluminum = T03-66655T. I have the 15" T03-56545T wheels on the 23D with the five lug nut pattern for the 10" drum brakes. Both the 15" and 16" SenDel wheels re-used the factory stock stainless steel center hubs.
http://www.sendelwheel.com/wheels/t03sm
Old 04-15-2016, 09:00 AM   #142
2007 25' Classic
Hutto , Texas
Originally Posted by Searun View Post
Why did you have to modify the fender wells? This is the first I've heard of someone having to do that to get the 16s to fit. That being said, just started seriously researching the upgrade.
Also, curious why you went with balancers?
Jeff
See post #24 in this thread. I posted a photo of fender well mod.
Wanderer2604 is offline   Reply With Quote
Old 04-16-2016, 04:52 AM   #143
switz's Avatar
2014 31' Classic
Images: 8
Used Centramatic wheel balancers on my two Honda Gold Wings, my 2012 Ram 2500HD Cummins and both Airstreams. Drum brakes are NOT balanced on Airstreams so they get balancing from the Centramatics and the tires are balanced when mounted. They reduce the out of balance shaking to the vehicle.
Old 05-13-2016, 05:17 AM   #144
64airstream's Avatar
1964 22' Safari
1968 26' Overlander
Beaver County , Pennsylvania
I just ordered a set of 4 Michelin LTX MS2 tires for our 68 Overlander and a pair for our Ford Expedition (different size, of course). The trailer tires are due in Monday, but the Expedition tires are no longer available. I'm told Michelin is discontinuing the LTX M/S2 and replacing them with the LTX M/S2 Defender. Same load rating, but they are 50,000 mile tires versus 70,000 like the current tire. Apparently, the stock is already exhausted on the larger size.
Roy
64airstream is offline   Reply With Quote
Old 05-18-2016, 03:57 PM   #145
1965 22' Safari
Point , NW
So today, after reading this thread, I upgraded the tires on my single axle 1965 Safari from Carlisle ST225/75/R15 to Michelin LT225/75/R16 MS2. Last Fall I had a catastrophic failure at 60 mph on a Montana freeway causing thousands of dollars of damage. Not wanting to go through that again prompted the change. Wheels are aluminum Allied 870ís which were available locally today at Les Schwabs, $116 including hub and valve stem. Tires from Discount Tire, $179 minus $25 military discount each. The dealers are across the street from each other, so picked up rims drove across street to have the tires mounted balanced and installed. I used one of the 15 inch Carlisleís for a spare. Michelinís are about 1/2 inch taller so only 1/4 inch closer to front and rear wheel well, they fit very nicely. I had to lift the tongue up a little over an inch to reconnect to the truck after the change. I donít think I need to readjust the ball, what advice might you have? Discount filled tires to 70psi telling me 80psi was maximum and to fill as I see fit. I had to get this done today because of an impromptu fishing trip. Yep, back to Montana freeways, so peace of mind and all!
Ray, thanks for starting this thread and to all who contributed!! My confidence in freeway driving has been bolstered.
Sburg58 is offline   Reply With Quote
Old 05-24-2016, 03:37 PM   #146
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
Thank you to all the Airforums member who contributed to this thread.
I purchased a set of Michelin P235/75R15 LTX M/S2 for my 2013 25FB International. This was after one my Marathons delaminated this weekend. Tire date 28/12. Luckily it was the right rear and only did a little damage to the gray wrap in front of the step. Total cost for part to repair $30. I got real lucky.
Memorial Day sale at Discount Tire so $590.68 mounted and balanced for 4 baloneys. Less a $100 rebate for the holiday.
If you could have a superpower, what would it be?
I chose America
Bigventure is offline   Reply With Quote
Old 05-24-2016, 07:16 PM   #147
Ray Eklund's Avatar
2014 25' International
Boulder City , Nevada
Happy... happy... happy!
I could not be happier with the 'upgrade' to 16" wheels and tires.
There have been no issues towing 900 miles. No additional popped interior rivets that occurred with the Marathon stock tires. One cabinet screw backed out of the cabinet door under the sink. Found and reinstalled.
Next month we will be camped Off the Grid and see if the deeper tread toss up stones into the fender wells while traveling.
There is plenty of space for the Michelins purchased in post #1. To install I did have to use additional leveling blocks to gain height after removing the 15" Marathons to install the 16" Michelins/Wheels.
The amount of tread on the Michelins are worth the extra expense, as they will not wear out but will 'age out'. The Michelin rubber is closer to a rubber than the Marathon tires which are a harder rubber and slippery on pavement. You will immediately feel the difference of the 'rubber that meets the road' by touch. The Marathons feel like the bottom on my sandals. Hard and slippery and little depth to the tread.
I am ready to test these tires against all of the naysayers that predict the shell and interior will self destruct. If I avoided one Marathon from coming apart and damaging our trailer... it was WORTH every cent!
Human Bean
Ray Eklund is offline   Reply With Quote
Old 05-24-2016, 08:28 PM   #148
Tn Traveler's Avatar
2006 25' Safari
Signal Mountain , Tennessee
Ray, I think that we will have enough members doing the conversion to do a pretty good sampling. If we can accumulate enough miles towing reports the info could be very useful. I have only towed mine a few miles, but that will change very shortly. Filling the tires to less air pressure and more flexible sidewalls will have to be easier on the trailer. At least the little I've towed seems to be that way.
Don
'06 Safari 25 LS
'18 GMC 2500HD Duramax/Allison
TN, Greenest State in the Land of the Free
" America is not a place;it's a road." Mark Twain
Tn Traveler is offline   Reply With Quote
Old 05-24-2016, 09:09 PM   #149
2006 25' Safari
My thinking is to run the tires at 55 psi. The trailer weighs at 6000# or just slightly over. That's loaded weight. Here is the chart I am going by.
LT225/75R16 E
XPS
http://www.michelinrvtires.com/refer...tion-tables/#/
Don
'06 Safari 25 LS
Old 05-25-2016, 07:31 AM   #150
1976 31' Sovereign
Oswego , Illinois
sendell wheels
Lower air pressure in tires cause to run hot at speeds and this what causes tire failure. Lets here what tire experts say not some one that does this. If you read posts of marathon and carlisle failures most were in hot states. tire manf. spec. pressures for a reason not to make trailer ride smoother but to avoid failures. Over heated tires cause failures pure and simple
Old 05-25-2016, 08:28 AM   #151
DoublTrouble's Avatar
2015 27' FB International
Carlsbad , California
For sure, although this has been discussed elsewhere by many. There is the issue of sidewall stiffness. While I am 7200lbs camping ready with 1200 of it on the tongue (P3 hitch), I'm still running at 80psi. I have always run my 3/4 ton diesel trucks at max on truck tires over 300,000 miles, regardless of the truck being loaded or empty.
Tire experts, please .......
DoublTrouble is offline   Reply With Quote
Old 05-25-2016, 08:34 AM   #152
2006 25' Safari
Thanks featherbedder for your response. The logic there is sound. However, why would Michelin publish a tire load and inflation chart? Why would they not say that 80# is 80# period? I have load range E tires at 80 psi on my 3/4 ton truck. The tire pressure on the front is recommended by GM to be 50 psi. When the truck is under a load I inflate the rear tires to 80 psi. When not I run them at 50 psi. I travel in "hot" states with no noticeable uneven tire wear and no blow outs.
My "W" speed rated tires on my car is a different story. I pay very close attention to make certain that they are inflated to the recommended pressures.
Don
'06 Safari 25 LS
Old 05-25-2016, 09:25 AM   #153
1976 31' Sovereign
Oswego , Illinois
sendell wheels
Truck tires are entirely dif than trailer tires. I also run my load range E on pu at less than chev. recommendation when empty, when loaded run rec. pressure. The only blow out I have had in 67 yrs. of driving was when auto tire was low, ran at speed to not be late to work, bang went tire nothing left, so speed and low pressure will kill tires, IMO.
Old 05-25-2016, 09:36 AM   #154
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
You do not have to run max stated pressure that is a common mistake.You can adjust the tire pressure accordingly but too low and you will have increased the sidewall flex which with tandem axles is not good thing when doing a tight gas station maneuver etc..Just use a little common sense and you will be fine.I run 65-68 psi on my 28ft International and have for many miles with great success and even wear.
Michelin LTX M/S versus Michelin LTX M/S 2 - Which Would You Choose? doutterson Tires 40 10-23-2016 09:08 PM
16" SenDel/Michelin Combo sailorii Tires 28 01-28-2016 09:51 AM
4 Sendel S20T Wheels & Goodyear Marathon Tires WanderStream Airstream Classifieds 0 12-17-2015 01:42 PM
16" SenDel Wheels and Michelin LTX Tires Jcoop Airstream Classifieds 2 01-19-2014 08:37 PM
Michelin LTX M/S tires... Dwight Tires 7 01-14-2010 05:21 PM
