Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 01-13-2009, 08:01 PM   #1
Benjo
Profile:  1949 18' Trailwind
Huntsville , Alabama
Images: 11
16" 5 on 5 1/2 wheels - What tires?
I've got these old wheels for my 49 single axle trailwind. they are 16" 5 on 5 1/2 lug pattern with the baby moon hub caps. I am having them sandblasted and painted. Has anyone heard of using truck tires with size rim? Perhaps it is a Dodge of Ford pattern. What size tire would i be looking for?
Benjo is offline   Reply With Quote
Old 01-13-2009, 08:31 PM   #2
vswingfield
vswingfield's Avatar
Profile:  1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
If they are 16”, wouldn’t they be 16”?
Vaughan
A sixth sense (I lack the other five) tells me that I am in serious difficulties. Oscar Levant
Old 01-13-2009, 08:48 PM   #3
SteveH
SteveH's Avatar
Profile:  2001 25' Excella
San Antonio , Texas
I think the original size was 700/16.
Old 01-29-2009, 11:31 PM   #4
Camp Kilgore
U.T and Texas A&M
Profile:  Dallas , Texas
5 on 5.5" in 15" and 16" was Jeep and GM, as I had both. I would prefer to roll 235-85x16" on AS instead of the modern 15".
7.00x16 was skinny.
Camp Kilgore is offline   Reply With Quote
Old 01-30-2009, 07:38 AM   #5
Melody Ranch
Melody Ranch's Avatar
Profile:  1966 17' Caravel
1947 22' Liner
Valley View , Texas
Images: 42
check ther width
The 235's will not fit the wheel wells on my older Airstreams. I do have replacement Henchens, so that my compound the fit.
Old 02-11-2009, 08:10 AM   #6
Ganaraska
1972 Travelux Princess 25
Profile:  Cobourg , Ontario
Trailers of that vintage usually used truck tires. I don't think trailer tires were made back then.
Bias ply truck tires are probably your best bet. Be careful of the width. Today's 16" tires are much wider than the old ones and are too wide for your narrow wheels. They will not work correctly. You need the old skinny straight sided tires.
If this trailer is to be used and not a museum piece you might be better off getting 15" wheels and radial tires.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 05-03-2009, 09:31 PM   #7
Pillow
Pillow's Avatar
Profile:  Currently Looking...
Warrenton , Virginia
There is a 7.00R15 available that is a radial from Yokohama. Check Tire Rack.
But unless you want to go back to bias ply I have not found a radial "bias" size.
Tire Rack carries a biasply tire in a 7.5R16 from Yokohama Y785R... It says tube on the description, but really I think it is a radial???
Or try this: 700-16 TORNEL LITE TRUCK 6 PLY - Coker Tire
I have some vintage 7.00x16 tires/wheels in the back of my truck right now that are headed to the dump so I know they were made for trucks in that size back in the day. And off of 5-5.5 wheels no less.
For a Spartan in the 40s it came with 7.50x16s. So I plan on switching to 235/85R16-Es.
Hopefully that is possible help. It is hard very hard! I am still stumped on how to get rid of the split rims and make it look right...
I would love to see you wheels setup if you have a picture to share!
Adrian, Heather, Susan, Maxwell, Ava, and Georgia (the dog)
1949 Spartan Manor 25'
Tow rigs: 1971 Chevy C-10 5.7, 1996 GMC Sierra K3500 6.5TD, 1999 GMC Suburban K2500 6.5TD, 2005 Cadillac Escalade ESV 6.0
Pillow is offline   Reply With Quote
Old 05-03-2009, 09:38 PM   #8
Pillow
Pillow's Avatar
Sorry, the bolt pattern is off of old trucks. Ford and Jeep. Also the 07+ Jeep Wranglers have the same bolt pattern in a 16" stock steelie wheel, good for a quick fix... But not vintage looking at all.
Also you can have wheels custom made for vintage steelies. I got a quote for 16x7 custom made for about $100 each. Then add the cost to powder coat and add caps + beauty rings. It gets pricey.
If you do not need steelies try the American Eagle 058 line of wheels PN#0589-7757. 16x7 8mm ET 5-5.5. This is what I ordered but not sure how it will look in the end. Might change it later. Made in the USA
Old 05-03-2009, 09:40 PM   #9
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
Riverside , California
My 1950 F1 had 16" wheels, and they weren't split rims, either. I think they were 5 lug, but after nearly 30 years, it's getting a little fuzzy. Maybe you could run that question by the people on the Ford Truck forum. Somebody may even have some surplus 16" tubeless (non-split) wheels.
Old 05-06-2009, 07:21 PM   #10
Pillow
Pillow's Avatar
Update: Check out a tire in this size 215/85R16-D Should be a little more narrow for your fitment.
Also I found a set of International truck wheels that should work, going to the junkyard tomorrow and getting them.
Help re wheels and tires. RickBooth Member Introductions 9 09-21-2007 08:31 PM
Need wheels and tires for my 65 GT? TERRY INMAN Tires 4 06-13-2006 08:45 PM
Wheels and Tires Fordstream Tires 4 01-12-2006 09:51 PM
New Wheels and Tires HELP Craftsman Wheels 5 10-27-2004 03:32 PM
Motorhome tires and wheels RichardT Airstream Motorhome Forums 2 04-06-2004 04:35 AM
Forums Directory
