Old 10-01-2009, 03:18 PM   #29
_
Originally Posted by CrawfordGene View Post
... thus they believe that sidewall is equivalent to the stronger sidewalls ST tires have...
Perhaps an very good tire not exactly engineered for the purpose intended is better than a not so good tire engineered for the purpose intended...
gene
i'm not a tire engineer or expert from the RMA so i can't answer your questions and won't try.
but these two clips get to the core of MUCH of the problem and random UNtested solutions...
1. "thus they believe..."
unfortunately what folks believe may not be accurate. false beliefs CAN drive marketing or product changes.
and repeating 'beliefs' over and over don't make them any more true.
i can point out 100s of examples of this, but wont'.
2. "stronger sidewall"
my post doesn't suggest the sidewalls are STRONGER on st tires, but are designed to handle the stress of side rolling and squirm on the rims.
it might be because of the shape, suppleness, GIVE in the carcass, materials used, BEAD or some other issue that is NOT strength related.
3. "a not so good tire"
again repeated OVER and OVER it's just an opinion.
usa and CANADIAN made gyms had a bunch of failure reports YEARS ago...
chinese made tires were NEVER part of this blip of activity, but NOW seem to get ALL of the blame.
most 'bad tires' were canadian made and PRE 2004. this is well documented and beyond dispute, really.
have there been failures on tires made AFTER 05 ? sure.
but there are also carlise failures, greenball failures, towmax failures, maxxis failures, mich' failures, st/LT/p failures and so on...
and none of those are connected to the canadian made st tire failures from 2001-2004.
_______________
a LOT of harmful INfcorrect misleading and incomplete reports have been posted here.
often ONE single tire or set of RELATED tires gets reported and REposted over and over.
just like tire threads start again and again with the SAME people posting into them.
i've read a bunch of posts recently that go like this...
"my trailer has gyms and for 2-3 years of towing they've been fine, no troubles, no issues, no failures. BUT i don't trust them now because of reading here..."
so apparently intelligent people are REJECTING there own experience, based on UNCONFIRMED or incomplete reports by strangers...
and MANY who leave a tire UNDER inflated for years, ONLY report problems when the tire fails, WITHOUT declaring the past abuse.
many folks don't KNOW that they are mistreating a trailer tire. these tires get regularly abused and ignored in ways the tires on a car do NOT.
we'll never know how many tires ROLL of the wheel or bead. zep didn't have to report this LT tire failure, but did.
photos and accurate reports take TIME AND EFFORT to post, satisfied gyms uses SELDOM report their trouble free experiences.
____________________
do i whole heartedly trust gy or ANY tire make? no of course not.
does a/s offerring a few other options AT the service center (not on the production line) mean NEW EVIDENCE supports these offerings ?
no, it is just a vendor response to customer requests.
and i can point to MANY industries with product offering driven by customer request...
people want what they want EVEN if the want is unrealistic or a better solution already exists.
cheers
2air'
Old 10-01-2009, 05:30 PM   #30
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
2air,
Neither of us are tire engineers, though I'm not sure that would qualify us if we were.
Of course what people believe can and all too often is wrong. Humans are experts at rationalizing and justifying. But…
Opinions are what we have to go on and some are well thought out and some are not. That is a major challenge of Forums—sorting out noise from good stuff. Sort we must and my admittedly subjective belief is that Marathons seem to get more bad reports. It has been posted that the Maxxis is built better than the Goodyear and how it is built, so that may be a fact. Yes, some of the reports are repeated over and over on myriad tire threads. Hopefully I've mentally sorted well, maybe not.
It may or may not be that is the sidewall that is stronger or some other factor, but the question remains the same. The Load Range indicates how the tire responds to horizontal stresses (that would include sidewall strength, bead, lettering, etc.), thus isn't an E tire the same regardless of whether it's an ST or an LT?
Other than Zep's LT tire failure, I don't recall other LT failure reports though I'm sure there's some somewhere. Zep's tire was a Firestone produced in 2005 or so. I have a vague memory of one or two Maxxis failures, no Michelins.
None of this is a objective, double blind study. I wish there were one.
Airstream's selling of 16" wheel and Goodyear LT tires may or may not be a response to customer requests. The tires are Goodyear because that's what their wheel supplier sells if my information is correct. The Marathons do not come in 225/75R16, the Goodyear LT's do.
Here's something else I wonder about: If psi has a direct relationship to load bearing (vertical), shouldn't LR E tires be inflated to 65 psi to be equal to a D tire?
Gene
Old 10-01-2009, 08:54 PM   #31
_
...thus isn't an E tire the same regardless of whether it's an ST or an LT?...
basically no they aren't the same. you can explore for the distinctions.
we don't need double blind studies but folks do need to understand statistics and risk analysis.
millions of gyms, a few 1000 maxxis and a few 100 LT tires...
so IF there had been 1000s of gym failures, we would expect to see only 3-10 maxxis and MINUS ZERO LT failures...
if the RATE/risk of failure is similar across the brands.
we read about a shark attack and translate that to fear of swimming in a mountain lake.
IF folks understood the statistics there would be almost NO one using casinos even with the glitzy ads featuring winners.
the gym thing is this process in reverse.
for example, the MOST common tire failure ALL of us towing on the highways observe is...
18 wheeler tires, and the bones are ALL along the roadways to prove it.
does that mean the big tires have a higher failure rate
OR does it just reflect the % of tires rolling on highways OR the miles PUT on these tires or the issue of retreading?
gyms DO have nylon perimeter bands (now) that function in the same way as the nylon caps on maxxis,
and gy does make ST tires in 16s. who knows what sizes MAY become available now that production is domestic again.
as for failures i've had 2 maxxis sidewall blow outs, both while traveling less than 30 mph. i've covered this is other threads.
we've also covered inflation tables and load related issues, so no need to repeat that info.
there isn't much new on ANY of this, since it is NOT the original thread theme.
i'm all for improvements but the idea that a different choice IS an improvement doesn't automatically follow.
cheers
2air'
Old 10-02-2009, 06:48 AM   #32
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
Air, Gene-- seriously, I could register your posts for college credits... but with no ACTUAL data, EVERYBODY is making decisions with anecdotal evidence.
For me, it's 8+ years of my Dad's A/S on Michelins (not ST), with never a blowout... and 3 BO's on my 1 year old, ST-rated GYM's
ID:	88075   Click image for larger version
A family of eight, blogging all things camping from our Airstream
https://boondockdad.com/
boondockdad is offline   Reply With Quote
Old 10-02-2009, 09:40 AM   #33
_
dead tires tell no lies...
hi fc'
WICKED looking!
and the collateral damage, expense of travel 4 repairs and 'time out' for this only add to the pain and cost.
a 30 slide is the heaviest thing on 2 axles that a/s builds.
imo it should wear E rated st tires at birth, with PROPERLY rated rims.
a/s has switched to higher rated rims on these, now they need to uprate the tires or stop building them.
the following may NOT apply in your situation, this is a generalized statement...
here's how i envision the dominos falling on many 2 axle rigs...
1. a low pressure event happens on ONE tire while towing or in storage.
2. without tpm the owner will be UNaware of this until manually checking pressures, or only after the tire is VISIBLY low.
3. so the under inflated tire may be in service for a day or 2 (couple of 100 miles) at a MINIMUM and often longer.
4. the owner now INFLATES or corrects the low pressure tire, OR mounts the spare and goes back to towing.
the PROBLEM is BOTH of the tires in this scenario SHOULD be REPLACED as soon as possible, not used.
because BOTH tires on that side should be considered OVER loaded, OVER stressed and pushed beyond the service description.
and it's possible the OPPOSITE side tires may be OVERloaded on some trailers or stressed beyond service design.
________________
most of us who check pressures and find a low tire simply top it off and watch it for a few days.
IF the pressure holds, it's back to normal operations and that might be OK for lighter trailers or 3 axles or LT and P tires...
but with ST tires and a trailer at the TOP of the weight chart,
that choice is gambling on the hope no internal damage was done to the low tire OR other tire...
and the odds favor the house. in this game we will lose.
________________
jack went to 15 inch E rated maxxis st tires on the 30 slide, AFTER a chunk of tread block was lost on a 3-4 year old gym.
i think that was a good choice for that model stream and the D rated tires survived so long because of very very careful monitoring.
i've camped with a lot of folks and seen a few dozen nasty looking tires like your pictures,
on ALL decades of trailers and from all tires makers.
many of those trailers had collateral damage involving wheel wells, skin, plumbing, belly pans and so on...
so it is NOT uncommon, can be traced to many issues from old tires to road hazards, to neglect, and to OVER loading...
and it also happens when everything is maintained PERFECTLY and within load parameters.
but HIGHER load rated tires should improve the odds for the heavier trailers...
and adopting the proactive attitude that one tire issue OFTEN means replacing both might prevent some tire disasters.
cheers
2air'
Old 10-02-2009, 09:45 AM   #34
Master of Universe
Gene's Avatar
finalcutjoe, credits in what? At least a BS from the Technical Institute of Retread Elucidations.
I agree anecdotal evidence is a large part of this ongoing series of threads. Unfortunately it is most of what we got.
As to why isn't an LR E tire the same across the board, "basically no they aren't the same. you can explore for the distinctions", does not contain the usual links so I could explore on the Forum or elsewhere. So the information must not be on the Forum, Wikepedia, or somewhere else in the usual syllabus.
There's more to these ratings than I understand and I keep hoping a real tire engineer shows up. Until then I hope to get knowledgeable answers from fellow students.
"Millions" of Marathons? Certainly a lot of Marathons, but this is a Forum with hundreds of very active members and maybe a thousand or so less active. The analysis (if I dare call it that) could be restricted to what we see here. It seems to me there are a "lot" of Marathons and a bunch of other tires, a fair amount of Maxxis and LT's. I wish I had an intern or a graduate assistant who go over all the tire threads and count all the reports and see how many are repeated. Some people do report they have had no problems so that could be included. Not a very good study, but slightly better than impressions.
We are going over this again and again. I keep hoping something new will come up and sometimes it does. Is it frustrating to see the same stuff? Yes. Inflation of E's? I was hoping for a simple answer so I wouldn't have to try to find it, alas.
Gene
Old 10-02-2009, 10:19 AM   #35
redstart's Avatar
1998 34' Limited
ont , Ontario
Hello! Grad student in statistics here... i know nothing about tires.... but joe is right, without actual data we got nothin.
the problem with using the information posted on this site is VOLUNTEER BIAS. Anyone who posts here does so voluntarily, and volunteers have more of an interest in the subject matter, possibly because they have had problems... or they work for goodyear...or something...they don't represent the true population and so making inferences from this data can be misleading...
Do I get an A?
redstart is offline   Reply With Quote
Old 10-02-2009, 11:48 AM   #36
rluhr's Avatar
1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
Bravo, gentlemen!
Good posts here lately. 2air's opinions echo many of my own opinions on this subject. In particular, we agree that there is a serious dearth of statistically valid evidence. But there is good industry knowledge of the many causes of tire failures. We can do well just by heeding what the real authorities (Rubber Manufacturer's Assoc among them) tell us from their research.
I feel the pain of those who have had repeated tire failures, because I have too. Fortunately, we've never had a blowout, only numerous flats and tread separations (over about 80,000 miles of towing). There is a good reason for that: we've always caught tire problems before they led to a complete failure.
There are many causes of tire failures, but the big ones seem to be underinflation, excess stress, and improper patch technique. I don't buy into the theories that Goodyears are inherently bad, because statistically valid evidence is just not there. My own experience has been very good with Goodyears compared to other brands, and that means exactly nothing.
So what to do? I wouldn't run out and swap a whole set of tires and wheels that are perfectly good. First, get a tire pressure monitor. Everyone who is towing a trailer should use one, in my opinion. Nothing else will let you know when one trailer suddenly goes low while towing. Remember, loss of air pressure can happen because of road debris and rotten tire stems, and no brand or load rating is immune to those problems.
Second, if you have a flat repaired, be sure to always get a patch plug, which both fills the hole and seals the tire from the inside. Otherwise, you've created a ticking bomb.
Third, inspect your tires at every fuel stop. It's easy and takes just a few seconds while you are waiting for the pump. A broken belt problem will manifest itself suddenly and without prior warning. It looks like a bulge or an irregularly worn patch. In just a couple hundred miles, a tire with a bad belt can wear bald in one spot -- and the next step is a blowout.
Fourth, replace the tires following industry recommendations for time and treadwear. If a tire is severely stressed, as described by 2air above, or damaged, get rid of it. Don't try to make a tire last longer than it should, just because "it looks okay".
Fifth, weigh your trailer and make sure you aren't overloading your tires. Most people never weigh their trailers and that's a big mistake. It costs just $9 at a CAT Scale. Check the load inflation table to ensure you are inflating to the proper pressure.
Take those simple five steps and you may find you are replacing tires more often than you did before, but you'll also lower your chances for an expensive blowout with the collateral body damage that almost always occurs.
Finally, if your tires are wearing oddly (at one edge or another), and you've been running proper inflation pressure, have your axle alignment corrected. The mothership can do it (about $250 for a tandem) and some Airstream dealers can do it too.
Former full-timer | AIRSTREAM LIFE magazine | Tour of America (old blog) | Man In The Maze (current blog)
rluhr is offline   Reply With Quote
Old 10-02-2009, 12:14 PM   #37
Master of Universe
Gene's Avatar
Do I get an A?
We got no professors here, so no grades.
Statistics aren't always available, so we have to use thinking instead.
Gene
Old 10-02-2009, 12:40 PM   #38
Master of Universe
Gene's Avatar
Rich, all of those are good suggestions.
I used to use plugs years ago when I repaired some tires myself, but then tire repair shops started using the internal patches claiming the plugs could pop out. I still carry plugs for emergencies. I've never had problems either way.
Thanks for inflation tables. I was looking for them yesterday and couldn't find them in the time I had. The ratings for LT's are close, but not the same as ST's. The numbers that interest me are both for 225/75 tires at 65 psi. The ST 15" is 2,540 lbs. and and LT 16" is 2,335 lbs. Either is much more than my trailer weighs. If you go up to 80 psi in an LT LR E tire, it will be rated at 2,680 lbs. I see Terry says (Post #1) he inflates the 16" LT, LR E tires to 45-50 psi and that would mean each tire was rated at 1,790-1,940 lbs.
When we are told to not run underinflated tires, I often wonder what is "underinflated". For ex., a trailer weighing 7,000 lbs. with tandem wheels, would only need to have ST 15" tires inflated to 35 psi according to the tables (total 7,040 lbs.). But no one would do that even though the tables seem to say it's ok.
Lots of questions, few answers.
Gene
Old 10-02-2009, 04:37 PM   #39
redstart's Avatar
1998 34' Limited
ont , Ontario
Gene
You know, you sound just like my supervisor!
.....me scurrying away from this thread....
Old 10-02-2009, 07:00 PM   #40
Master of Universe
Gene's Avatar
He must be very, very smart.
Gene
Old 10-04-2009, 04:47 AM   #41
Dearborn , Michigan
Images: 21
these look like what I have now, but in 16"
Aluminum Trailer Wheel Style: SERIES #04 Size: 16 x 7 Bolt Pattern: 6 x 5.5 Bore Size: 4.25 Load Rating: 3200 lbs @ 85 PSI Offset: +5mm Hispec
although, there's a +5mm offset...
Old 10-06-2009, 04:33 PM   #42
Master of Universe
Gene's Avatar
I've been talking to a lot of people to get more information on the tire and wheel questions.
I had a long conversation with a guy who appeared to be quite knowledgeable at Michelin. First, using a LR E tire to replace a LR D tire on my trailer requires 75 psi to have an equivalent weight rating. Anything less is underinflated.
I asked about whether the Michelin 16" RBS Rib or the LTX would be the better tire to replace the 15" ST tire. He said the RBS has a firmer sidewall and would not provide as smooth a ride as the LTX and thus the LTX would be better for towing. The RBS would have less sway, but if sway isn't a problem, the LTX should be ok.
We discussed at length the differences between ST sidewalls and LTX sidewalls and whether that would be a problem. He did not believe so. We went back and forth on this issue at length.
I spoke with Jim Parrott at Airstream. He gives technical advice. I asked whether the increased weight of a 16" wheel and tire would cause too much added stress on the bearings, seals and spindles. He did not think so.
He confirmed the offset on a wheel should be 0˚. I didn't discuss this with him, but if the offset is either positive or negative, I would think that would create a lot of stress on the running gear as the weight of the wheel and tire is not properly distributed on the hub (brake drum).
If you are looking for new wheels the specs for the 15" wheels on mine are 7" width, 6 bolt, 5 1/2" apart, 4.28 bore.
Make sure a 16" tire fits in the tire carrier—I haven't checked mine yet, but I could throw (maybe push) it in the pickup bed.
Gene
16" 5 on 5 1/2 wheels - What tires? Benjo Tires 10 02-15-2010 07:41 PM
New wheels and tires upgrade to 16" & Michelin Tin Diesel Wheels, Hubs & Bearings 9 04-23-2008 10:48 AM
Region One Rally 2007 "Simply Camping" myboyburt WBCCI Rallies & Events 76 08-15-2007 10:37 AM
New Members: "Andy & Roberta" (July 4th 2007)... Where's The Rallies in Iowa? Andy Harris Member Introductions 9 08-11-2007 08:10 AM
