Old 07-11-2014, 05:30 PM   #1
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
15" Tire Recommendation Please
I want to mount this old Western Wheel 15" aluminum wheel on my son's 69 Globetrotter. The wheel says 2200lbs max load.
I want to mount a load rating D tire to the wheel and run it at 65 psi. His trailer weighs about 3500 lbs. It is single axle of course.
What would you experts purchase for new tires?
David
Name:	1407 Airstream Wheel.jpg
Old 07-11-2014, 06:06 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
225x65x15 Mich.
Old 07-11-2014, 06:13 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Okay. A light truck tire. Or is that an extra load passenger car tire. LTs aren't plentiful in 15". Michelins are soooo expensive. I know they are premium, but for 3000 miles a year I wonder if they are worth it. We'll see.
I was thinking 225 75 15. I'll check overall diameters.
David
Old 07-11-2014, 06:57 PM   #4
truxpin's Avatar
2001 34' Limited
Tucson , Arizona
How wide is the rim? That will certainly make a difference. That Western rim LOOKS a lot like the Alcoa 15" rim that came on our '01 Limited, but width will make a difference in which tire you go with. I'm in the process of replacing our tires, and I wish I could recall the width of our 15" Alcoa rims. 225/75/15 are the size of the current tires, and they're being replaced with the same. What is the size of the tire on that Western rim?
2013 Ram Power Wagon 2500 4X4 5.7 Hemi
2001 Airstream '34 Limited
Hensley Arrow
Fulltime in 2013 and LOVING it !!
truxpin is offline   Reply With Quote
Old 07-11-2014, 07:51 PM   #5
r carl's Avatar
Lin , Ne
At only 3k a yr if you buy a ST tire, buy a bias ply one. No need for a radial on that camper.
Old 07-12-2014, 06:48 AM   #6
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I should have said the wheel is 6" in width. Pretty much standard fare for Airstreams. The wheels came off our 86 Limited as I upgraded to 16" and LT load E tires. So my Trade Wind and my son get the hand me downs. We have steel wheels and bias ply tires on the Globetrotter now. I feel they are heavy, like over 50 lbs, and rigid. His axle isn't in the best shape. I figured the aluminum wheels and radials would reduce weight and offer a slightly smoother ride.
David
Old 07-12-2014, 09:36 AM   #7
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Pirelli Scorpion LT 235/75/15 LR D
Lance
Top is offline   Reply With Quote
Old 07-12-2014, 10:34 AM   #8
1981 31' Excella II
New Market , Alabama
If it will fit, I would go with a Michelin or BF Goodrich in 235/75-XL15. This is a little wider and taller than the 225/75-15. That looks like a standard Airstream alloy rim. My trailer has those and I have the 235/75 -XL15 Goodrich TA Longtrail and they seem to be fine. Probably have at least 5000 miles on them. I can't find the odometer on my trailer. How do folks get their tire mileage down to 1/4 mile?
Perry
Old 07-12-2014, 11:05 AM   #9
1966 24' Tradewind
2005 22' Safari
Bastrop , Texas
There is a multitude of 235/75R15s available from virtually all manufactures, and even the P rated tires have a load rating over 2000 pounds .
I have used these tires for many years without ever having one fail for any reason , other than a picking up a nail. The trailer tows perfectly at highway speeds , 75 MPH in the Texas heat , and no problems at all with tight u-turns on pavement or anything else. They have no 65 MPH speed limitations and with the lower pressure they run , they deflect and absorb a lot more road imperfections that otherwise would be transferred to the trailer .
Last summer we drove from central Texas up through Canada , all over Alaska and back home down the Cassiar route with absolutely no problems whatsoever out of the 235/75R15 Cooper Trendsetter tires on the trailer .
Ran the same size tires on the 66 Airstream with the stock steel wheels with baby moons all over the Southwest United States for years with the same results.
dannydimitt is offline   Reply With Quote
Old 07-12-2014, 11:06 AM   #10
1966 24' Tradewind
2005 22' Safari
Bastrop , Texas
We had the right rear go flat on our Safari near Pie Town , New Mexico about a month back . A nice young lady that had been following passed and signaled that there was a problem back there , we pulled over and she told us the tire had been down for several miles "towed perfectly with no apparent problems " the weight of the trailer had been carried by the right Front tire and wheel allowing the assembly to the rear of it to roll along without the wheel ever making contact with the road surface . This was a new first time on the road p rated 15 inch tire and did not come apart or do any damage whatsoever to the trailer, although it was run deflated long enough to inflict fatal damage to the outside sidewall of the tire , while the inside was perfectly fine . The tire that had been carrying the entire weight of the right side of the trailer was no warmer than the tires on the left side of the trailer .
Hats off to the young lady who stopped to tell us of the flat , she offered to help us put the spare on !
Old 07-12-2014, 07:13 PM   #11
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Thanks everyone for your experiences. When I went looking for a 15" LT tire 225 75 15 I didn't happen to see very many available. I probably searched wrong. Maybe they are more common at 235 75 15.
David
Old 07-19-2014, 11:38 AM   #12
KYAirstream's Avatar
Northeastern , Kentucky
How about the Cooper AT3s or HT3s in a 235 75 R15?
KYAirstream is offline   Reply With Quote
Old 07-19-2014, 01:38 PM   #13
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
Question
Perry
Any issue from putting a wider tire on a newer AS? I'm wanting to go to a 15 inch rim and a Michelin tire, but can only find the 235 in a 75/R15.
tsunami is offline   Reply With Quote
Old 07-19-2014, 07:46 PM   #14
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I actually purchased a 205 75R 15 E rated trailer tire. It fit well in the wheel well, but a little struggle getting it between the brake drum and body. I'm running them at 65 psi. I think they will be plenty of tire for the 69 Globetrotter.
David
"silver avion" avion C11 airstream "truck camper' "slide-in" aluminum eBay Watch Airstreams on eBay 0 09-14-2013 06:20 PM
Insurance Recommendation Please - bugnot1 Full-Timing 20 01-25-2011 10:32 PM
Water heater recommendation for a "landed" Sovereign? davida Water Heaters, Filters & Pumps 3 07-22-2006 07:50 PM
