Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 10-06-2015, 07:02 AM   #1
1989 32' Excella
Sharon Springs , New York
15" rim vs. 16" rim ?
Maybe I missed this discussion, but why do folks change their AS's rims from 15" to 16"? Is it a ground clearance issue, better weight carrying capacity or better choice in tires? I've seen a few sets of tires/rims that folks have taken off their newer AS's and are selling. I would like to upgrade both the tires and rims on my 1989 Excella but not sure if I should go to 16" rims or buy newer style 15" rims. Any thoughts?
Regards,
James
Easyrider06 is offline   Reply With Quote
Old 10-06-2015, 07:37 AM   #2
2016 25' Flying Cloud
Holly Springs , Mississippi
It's so they can use LT (light truck) tires rather than the ST tires that come on new trailers.
I've always wondered why not just replace the Goodyear Marathons with a higher quality/rated tire and keep the 15 inchers. Maybe someone can educate us both.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Old 10-06-2015, 08:00 AM   #3
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Bob,
If you mean a higher quality/rated ST tire, some people do just that on the assumption that it is at least better than using the Marathons that have such a bad reputation
I did that initially.
But then, after hearing so many recommendations of LT tires I decided I would go that route.
For our particular trailer (30' Classic") there was no LT tire available that had the necessary load capacity - at least as far as I aware - so I had to switch to the 16" wheels in order to get an LT tire with the appropriate capacity.
As well as the reported better performance of LT vs. ST, the LT tires are not limited to 65mph as I think all ST tires are.
I don't generally drive much faster than that but probably wind up in the 70-75mph range when driving the long straight interstate across Texas and similar.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 10-06-2015, 08:09 AM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Here is a link to a real, honest to goodness TIRE ENGINEER website specializing in RV tires
RV Tire Safety
I am running 15" Goodyear LT tires and am very pleased.
When I am ready to replace the wheels, I will upgrade to 16" as that gets you into higher tire loading capacities and speed ratings.
I do not drive over 65 MPH. There are a couple times I had to run 70 to "merge" safely or I was watching scenery more than the throttle....and no issues.
Peace and Blessings..
Channing
WBCCI# 30676
Old 10-06-2015, 08:19 AM   #5
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I used Yokohama LT tires on my 15" wheels. They are rated at over 2,000 lbs each.
So far so good.
Brevi tempore!
Old 10-06-2015, 09:25 AM   #6
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Greater tire selection however with 16 inch wheels. More manufacturers are switching to 16's anyways. And there are infact 16 inch ST tires too, so you can't just claim it's to only run LT's. Although that's what most here on this forum do.
16 inch Trailer Tires - Bias Ply and Radial ST Trailer Tires
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 10-06-2015, 10:20 AM   #7
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
I have the Michelin 235/75x15 on my 2008 Classic 25fb. If I switched to 16" rims the distance between the two tires would be at least 1" less. I'm not sure I could put 2 Lynx blocks on the ground with one on top of them between the two 16" tires. This is my typical Lynx block configuration for leveling. I'd probably have to switch to the Anderson leveling system.
Kelvin
Old 10-06-2015, 10:48 AM   #8
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I like to keep an eye on what Airstream company is doing. They introduced 16" Michelin tires/Sendel wheels on the low production Eddie Bauer model a few years ago. Then it was offered as an upgrade at the Service Center. On 2015 Classics is became the standard tire/wheel.
There's different ways to read it but I think they have been uncomfortable with the reliability of 15" GY Marathons, gave the Michelins a production test on the Eddie Bauer, and now standard on their premium trailer. You can now order them as an option on any 25' Airstream and up.
They no longer have full confidence in the 15" Marathons so why should we. You can "get by" with the Marathons or other ST tires but an upgrade to 16" Michelins/Sendel wheels is not outrageously expensive compared to the cost of damaged railer repairs (TPMS may or may not save you). We followed Airstream's lead on this one.
There may be a downside. The 16" Michelin LTX tires at the Airstream recommended 80 psi may ride rougher than the 16" Marathons at 65 psi, causing slow long term damage to the Airstream. Watch for it.
We have decided to mitigate this issue by running our Michelins at 65 psi but there are plenty of arguments against that as well. Mostly "inter-ply shear" while making sharp turns from a tire engineer who frequents this forum. I have not heard of an Airstream tire failure on account of it though. Another is increased sway tendency; we haven't felt that through our ProPride hitch either.
Doug and Cheryl
Old 10-06-2015, 11:03 AM   #9
dames7's Avatar
2015 25' Flying Cloud
GILBERT , Arizona
I changed my to the 16", things I looked at was load, heat rating (live in AZ), and speed.
Michelin 225/75 ×16, made in Canada, the Marathon were made in China, had problems w/ two them.
I did get free replacement for them, but still replace/16".
Will put others up for sell, they are good tires, I have always like the Michelin tires
David & Nancy Ames
WBCCI # 9403 -- AIR # 95597
2015 FC 25' RB
2013 Chevy Tahoe LTZ
dames7 is offline   Reply With Quote
Old 10-06-2015, 11:04 AM   #10
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Regards,
James
You named 2 of the reasons in your post- better weight carrying capacity and better choice in tires.
Only 1/2" ground clearance is gained, so it is not really noticeable.
I have never been able to get more than 3 or 4 years from ST tires before a tread separation. LT truck tires will surely last longer.
2 bad experiences with ST tires is enough. I decided I didn't want a third bad experience.
Also, ST tires are limited to 65 mph.
I may never exceed 65 mph, but I can if I want to with 16' wheels and LT truck tires.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 10-06-2015, 11:24 AM   #11
2018 30' Classic
Mountain View , California
For those of us less sophisticated on the definitions and specs of LT vs ST I Googled up Tire Tech at tirerack.com for an excellent explanation.
JFRINALDI is offline   Reply With Quote
Old 10-06-2015, 11:41 AM   #12
z , North Carolina
Photos
And they look a whole heckuva lot better too. Doug/dkottum, you should bump your tire pressure up to 70psi. 80 PSI on the Michelins is a bit bouncy. IMHO, 65 is not enough. I had smooth sailing with mine at 70psi all the way out to Phoenix & back w/o issue. Numerous tows of under 300 miles since then, is very comfortable @ that PSI. Best addition I ever made to my TT. Love to see the Michelin man waving at me on all 8 tires. Best rubber on the road.
Before & after photos.
Keep its head up!
Gavin
ID:	249873   Click image for larger version
FishinHatteras is offline   Reply With Quote
Old 10-06-2015, 12:04 PM   #13
2017 19' Flying Cloud
Madison , Wisconsin
Send a message via AIM to jtwind Send a message via MSN to jtwind Send a message via Yahoo to jtwind
Any recommendations or experiences with upgraded tires and rims for a 2014 Bambi 16'?
jtwind is offline   Reply With Quote
Old 10-06-2015, 12:13 PM   #14
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Keep its head up!
Gavin
What do you use to level your Airstream with the 16" tires?
Kelvin
Old 10-06-2015, 12:23 PM   #15
1989 32' Excella
Thanks for info
Thanks for the info on the rim/tire choice... This leads to a few more questions.
1. Is there a potential for clearance issues when changing over to 16" rims/tires on a 1989 Excella?
2. Do folks go thru Airstream to buy their rims or is there a preferred aftermarket source?
Thanks much,
James
Old 10-06-2015, 12:47 PM   #16
m.hony's Avatar
2013 30' Classic
No clearance issues with 16" wheels and tires.
Some trailers come standard with them- first the Eddie Bauer and then the new Classic.
The 16" wheel/tire combo from Airstream is ridiculously expensive, like $600+ each before shipping. If you go this route you can get it done for a lot less money through other sources. I ordered the wheels, TPMS, and Centramatic balancers from the internet and bought the tires locally.
Name:	ImageUploadedByAirstream Forums1444157199.767672.jpg
Name:	ImageUploadedByAirstream Forums1444157228.257510.jpg
There is definitely peace of mind that comes with the new tires and wheels.
TAC #MS-10
Airforums #70955
Old 10-06-2015, 12:54 PM   #17
Wingeezer's Avatar
2005 30' Classic
Can't comment on the '89 trailer, but as for source of tires and wheels, I did get an estimate from Jackson Centre as I was going to by traveling by there - but a price I got locally from a tire shop was much much better! (Same Michelin tires, but different make of rims.
I just got the specs from the Sendel rims that Airstream were using and bought rims that matched.
I have now used them on three cross country trips with no issues at all. Very happy with them.
Brian.
2005 Classic 30'
Old 10-06-2015, 02:58 PM   #18
2012 30' International
Livingston , Texas
Cost
I upgraded from 15 to 16 today at the Airstream factory in Ohio and it was $2000 for 5 Michelin tires and the newest aluminum rims. (399.95 per wheel) I could have saved about $70 by going with a steel spare wheel but the cost wasn't too bad to go all aluminum. Also, another $90 for the non-plastic coated chrome lug nuts. FYI.. The labor rate at the factory service center is $125 / hr and the crappy authorized service dealer in Texas is $165 / hr. You get much better service at the factory and the people are much more pleasant to work with. You do need to make an appt. free full hookup camping is a plus, otherwise $10 per night. Can't beat it in Jackson Center, OH
glenrms is offline   Reply With Quote
Old 10-06-2015, 03:15 PM   #19
dcasr's Avatar
1990 29' Excella
Travelers Rest , South Carolina
I put 15" aluminum rims on my 1990 Excella 29' along with E rated Maxxis running at 70 psi. Had trouble with two tread separations in my third year, but my tire minders alerted me to air pressure loss and gave me time to stop before anything dramatic happened. I replaced them with 4 new Maxxis, but in consideration of the speed factor on ST tires, will probably upgrade to 16' aluminum rims and Michelins LT E rated tires. The reality is I like to cruise between 60-70 mph, and on long steep downhills the TV and AS want to roll at 70-75. Whether my previous driving on occasion at 65+ speeds led to the tread separation or not who knows, but I'm ready to run Michelin LT tires just like on my TV.
WBCCI 2456 Georgia Unit 32
1990 Excella 29' Centramatics
2016 GMC Sierra Crew Cab 2500 HD 4x4
6.6L Duramax + Allison, 3.73 axles
dcasr is offline   Reply With Quote
Old 10-06-2015, 03:38 PM   #20
Wise Elder
Jammer's Avatar
2010 30' Classic
James,
The usual reason that people switch to 16" rims is that they can switch from trailer (ST) tires to light truck (LT) tires and still have a tire with a rated weight capacity that exceeds the manufacturer's gross vehicle weight rating (GVWR) for the trailer. The overall goal of such a change is either to reduce the likelihood of tire failure or to have a wider range of tire manufacturers from which to choose.
Opinions vary on the actual effect such a change has on the chances of tire failure. There seems to be fairly widespread agreement that it is a worthwhile change for trailers that are close to the maximum load for the tires, particularly the largest of the single axle trailers.
Is this a "Split Rim"? Studioman Wheels, Hubs & Bearings 30 03-16-2015 06:28 PM
16" rim substitute hertfordnc Wheels, Hubs & Bearings 2 04-03-2011 02:54 PM
Help with rim specs for 26" 1975 Argosy camper! antman Wheels, Hubs & Bearings 1 12-22-2010 10:31 PM
Centramatics -- 16" wheel rim size larry b Wheels, Hubs & Bearings 14 01-26-2010 04:38 PM
