Old 10-12-2015, 06:29 PM   #57
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
ST tires never last more than 3-4 years in reality. It's a good concept- stiff sidewalls that will stand up to sheer- but it only really looks good on paper. They are cheaply made and will have tread separation. Carlisle tires are junk, but hold up a little longer than Goodyear Marathons. I've had bad luck with both. There will not be a third time.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 10-14-2015, 11:37 AM   #58
2017 19' Flying Cloud
Madison , Wisconsin
Send a message via AIM to jtwind Send a message via MSN to jtwind Send a message via Yahoo to jtwind
Going to upgrade to 15" wheel and michelins on my 16' sport. Do I need to get a third to replace the spare. I know the slight difference in diameter won't matter and certainly not for the 100 miles or whatever I would drive to get a new tire. Even if I had 3 of the same I'd still do the same as I would not want to drive far without a spare. Am I missing somehing?
jtwind is online now   Reply With Quote
Old 10-14-2015, 03:47 PM   #59
Ron A's Avatar
2018 23' Flying Cloud
Huntsville , Alabama
I purchased a spare, however, think it is a matter of preference.
Ron
Ron A is offline   Reply With Quote
Old 10-14-2015, 05:46 PM   #60
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
You'd have to get a third rim if you are switching from 14" to 15". Just depends on your budget for another rim and tire.
Kelvin
Old 10-14-2015, 06:05 PM   #61
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I did also - I'm sure it would be fine to use a 15" temporarily as a spare, but I thought it might be worth getting five 16" rather than four in case I ever had a problem with one wheel and at that time could not buy an identical replacement, I would at least have one spare of the same design!
Bit of a long shot I guess, but that was my thought at the time.
Also, I could use it in rotation with the other wheels - not sure I ever will though, kinda lazy about that sort of thing!
Meanwhile it just sits in the back of our truck - being aluminum, it seems too nice a wheel to leave it under the trailer getting covered in road salt when we head south in winter!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 10-14-2015, 07:08 PM   #62
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
Originally Posted by KJRitchie View Post
According to Tirerack the 235/75R15 Michelin LTX M/S have a rim range of 6" to 8". Check the width of your rims. Maybe contact Airstream. On my 25fb 15" rims they were 6" rims so I was able to upgrade from the GYM 225/75x15 to the Michelin 235/75s.
Kelvin
Is there any concern with the load rating of the 235/75R15 Michelin LTX M/S tires on your 25fb?
Thanks!
Old 10-14-2015, 08:31 PM   #63
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
A lot less concern than running ST tires. One big advantage of running 16" rims is that you can run E rated LT tires, the same rated tires that 3/4 and 1 ton trucks run when towing. If safety is any factor to you vs price of tires, then no reason not to run 16" E rated.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 10-14-2015, 10:26 PM   #64
Plover , Wisconsin
Talking Larger and Larger! Where does it end?
Originally Posted by NavyCorpsman View Post
My tire guy tells me that 15" tire gave way to 16", and now the trend is 17 and 18".
Could it be that, in addition to other factors, a larger diameter tire does not turn as fast and, therefore, is not subject to as much wear and violence as a smaller diameter tire? And, imagine a small tire rolling through a sharp edged rut in the road compared to a larger diameter tire. A larger tire is better able to roll over the edge than into it.
Jer
Oxen is offline   Reply With Quote
Old 10-16-2015, 07:24 AM   #65
m.hony's Avatar
2013 30' Classic
The difference in RPM due to diameter shouldn't create that much more heat or pressure.
We drove cars with 13" or 14" wheels at 70 mph for 30 years.
TAC #MS-10
Airforums #70955
Old 10-16-2015, 08:20 AM   #66
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
For me it was a matter of doing the math. First iis my deductible cost in repairing the damage caused by a tire failure. Second the fact that both my Marathons and Maxxis tires failed at the end of year 3 or the beginning of year 4 of use telling me that 3 years is the max life for an ST on my weight Airsteam. So figuring I can most likely use 2 sets of LT tires in 10 years vs 3 sets of ST tires, and adding in the cost of damage, going to 16" wheels and LT tires is both cost effective and safer than sitting on the side of a highway with a blown tire.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 10-16-2015, 12:40 PM   #67
m.hony's Avatar
2013 30' Classic
I'm in Jack's camp.
TAC #MS-10
Airforums #70955
Old 10-16-2015, 05:03 PM   #68
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Ordered my new michelins 225/75/16 from Costco , wheels from king of wheels, will get mounted next week.. My marathons have 20000 miles and are at 50 per cent and they did good........
Old 10-21-2015, 04:58 AM   #69
MACINRIC's Avatar
1977 29' Ambassador
Richmond , Virginia
I am looking at some nice 16" wheel tire combos but I'm wondering if they'll fit my AS. They came off a different tow vehicle. Do I need to expect to swap out size up the hub where the wheel bolts are?
-Mac
MACINRIC is offline   Reply With Quote
Old 10-21-2015, 11:02 AM   #70
2015 27' FB International
mesquite , Texas
16 in/ wheels & rims
just ordered my new rims & wheels from performance tire in ca. nice folks to do business with {Stephen] saved a ton of $ state tax & free shipping.
airstream recommends 80lbs. pressure in this comb. [eddie bauer]
I typically tow at 60-65 and only exceed this if and when I have to pass.
any recommened pressures that anyone has to offer?
I assume factory lug nuts will fit?
if I knew how to post pictures I would ! any suggestuons as to how to do that? the pictures posted by those that made the switch helped convince me that new everything would look great!
moxie t. moto
moxie t. moto is offline   Reply With Quote
Is this a "Split Rim"? Studioman Wheels, Hubs & Bearings 30 03-16-2015 06:28 PM
16" rim substitute hertfordnc Wheels, Hubs & Bearings 2 04-03-2011 02:54 PM
Help with rim specs for 26" 1975 Argosy camper! antman Wheels, Hubs & Bearings 1 12-22-2010 10:31 PM
Centramatics -- 16" wheel rim size larry b Wheels, Hubs & Bearings 14 01-26-2010 04:38 PM
