Old 10-08-2015, 06:52 PM   #43
2017 19' Flying Cloud
Madison , Wisconsin
Send a message via AIM to jtwind Send a message via MSN to jtwind Send a message via Yahoo to jtwind
Thanks, much I will double check but have the same trailer.
Originally Posted by Ron A View Post
Sendel T03-556545T 15x6 5/4.5 Aluminum T03 Trailer Wheel Silver Inlay. Ordered through Amazon (Ships from and sold by Recstuff).
Michelin LTX MS 235/75R15 purchased from local tire dealer replaced the 14 inch wheels on the 2015 Sport Bambi 16'.
Before I purchased I measured my wheel well clearance to make sure I was comfortable with the fit. Would encourage you to do the same before ordering.
jtwind is offline   Reply With Quote
Old 10-08-2015, 07:01 PM   #44
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Originally Posted by FishinHatteras View Post
And they look a whole heckuva lot better too. Doug/dkottum, you should bump your tire pressure up to 70psi. 80 PSI on the Michelins is a bit bouncy. IMHO, 65 is not enough. I had smooth sailing with mine at 70psi all the way out to Phoenix & back w/o issue. Numerous tows of under 300 miles since then, is very comfortable @ that PSI. Best addition I ever made to my TT. Love to see the Michelin man waving at me on all 8 tires. Best rubber on the road.
Before & after photos.
Keep its head up!
Gavin
You clearly have good taste as we have the same combo.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 10-08-2015, 07:36 PM   #45
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
I switched the stock 14" tires and wheels on the 2015 23D International Serenity for the 15" Sendel T03-56545T wheels (15x6 - 5/4.50" bolt circle - zero offset - 3.19 center bore - rated 2,150 pounds at 60 psi) and the Michelin LTX (P) 235/75R15 XL tires rated 2,183 pounds @ 50 psi but derated to 1,985 pounds for trailer use and 28.9" in diameter. I also installed the Dill 1506-453 TPMS system and used McGard lug nuts and lock nuts during the swap. I carry 44 psi in the 15" Michelin tires.
Since the factory did an uneven job of the sheet metal work for the wheel openings on the 23D, we did rework the leading edge of the curb side to match the street side opening which gave us more than adequate tire clearance.
I used these same 15" Michelin tires on my 2013 25FB International Serenity with no issues.
The stock 15" tires and wheels on my 2014 Classic were replaced with the 16" SenDel T03-66655T wheel rated 3,580 pounds @ 80 psi and 16" Michelin LT225/75R16/E LTX M/S2 tires rated 2,680 pounds @ 80 psi with a diameter of 29.2". The same model Dill TPMS and McGard lug and lock nuts were used o the Classic.
With no mechanical issues in Michelin tires for over 45 years, I elected to continue with this brand on the Airstream trailers.
There was no need to widen the wheel wells on any of the three Airstreams when the tires were upgraded to Michelins.
Old 10-08-2015, 08:23 PM   #46
Bend , Oregon
Michelin LTX MS 235/75R15 replaced the 14 inch wheels on the 16' Sport Bambi. I may have misquoted the year model of my Bambi, it is a 2015 model. I purchased it in 2014 do not think it will make a difference because it is the same size rim and tires on the 2014 & 2015 model year.
Ok great info but still sort of confused. My '12 Sport 22 came with 15" rims and 225/75 tires. Do I need new rims if I want to install 235/75R15 Michelin LTX M/S tires or will the OEM rims work?
chaeha is offline   Reply With Quote
Old 10-08-2015, 08:53 PM   #47
Ron A's Avatar
2018 23' Flying Cloud
Huntsville , Alabama
15" rim vs. 16" rim ?
I am not a tire expert and not qualified to give advice on tires to others. I do not mind sharing what I did. I had to go up from 14" to 15" tire size to make sure I had a tire to carry the weight of my trailer (have 3,500 lb axle). My guess is you will need to consider going up one rim size and pick a tire that will carry the weight of your trailer plus cargo as well if you are considering LT tires. Would encourage you to do your research before your purchase. Safety should always be priority one.
Ron
Ron A is offline   Reply With Quote
Old 10-09-2015, 09:17 AM   #48
dames7's Avatar
2015 25' Flying Cloud
GILBERT , Arizona
I got the SenDel 16" T 03
David & Nancy Ames
WBCCI # 9403 -- AIR # 95597
2015 FC 25' RB
2013 Chevy Tahoe LTZ
dames7 is offline   Reply With Quote
Old 10-09-2015, 09:31 AM   #49
dames7's Avatar
GILBERT , Arizona
LT225/75R16 115/112R
MAKE SURE OF DATE ON TIRES, mine were 2615
David & Nancy Ames
2015 FC 25' RB
Old 10-09-2015, 09:38 AM   #50
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
According to Tirerack the 235/75R15 Michelin LTX M/S have a rim range of 6" to 8". Check the width of your rims. Maybe contact Airstream. On my 25fb 15" rims they were 6" rims so I was able to upgrade from the GYM 225/75x15 to the Michelin 235/75s.
Kelvin
Old 10-10-2015, 08:20 AM   #51
Bend , Oregon
Kelvin
Looks like I have Sendel 15x6 rims in my 22' Sport so I think when I'm ready the Michelin 235/75's should work with the existing rims. Thanks for your help.
Old 10-10-2015, 10:10 PM   #52
Bend , Oregon
Kelvin
Did you replace your spare as well? Will the existing spare holder accommodate the larger tire?
Old 10-11-2015, 06:42 AM   #53
KJRitchie's Avatar
2008 25' Classic
Yes, I replaced the spare. it was able to fit in the under tongue carrier, it barely fits. I'm assuming this part is the same for all Airstreams.
Kelvin
Old 10-11-2015, 08:58 PM   #54
Ravenna , Ohio
Something to consider when shopping for tires.
- Many tires have essentially no warranty, others maybe 12 months and some years. IMO the length of time the tire company is willing to stand behind their products is one way to judge the real quality of what they make. Which would you consider a better deal: a hammer with a 30 day warranty for $5 or one with a 10 year warranty for $10?
- Speed rating molded on the tire sidewall to me indicates the manufacturer has made a real effort to exceed the minimum performance requirements from DOT. IMO tires with speed symbol are probably better than those without a speed rating.
- Here is a chart to convert the letter to a number.
- The speed symbol letter si part of the "Service Description" which comes right after the rim diameter in the tire size. Technically an "LT235/75R15 107/110 Q Load Range D" is a different tire than an "LT235/75R15 Load Range D" with the 107/110 being a "Load Index" for dual and single application and the letter Q being the speed Symbol
- I note that most LT tires made today have a speed rating but when applied to trailer application some companies say to consider 75 mph as a max.
- I also have recently seen a few ST type tires now being manufactured with a Speed Symbol which IMO would make then probably a better choice than tires without a Speed Symbol.
Tireman9 is offline   Reply With Quote
Old 10-12-2015, 01:29 PM   #55
switz's Avatar
2014 31' Classic
Images: 8
On the 25FB, I was able to bend the arms out to grasp the replacement 15" Michelin tire. The challenge was getting the locking pin in place as the Michelin was fatter. On the Classic going to the 16"Michelin, I did not need to bend the arms, but did lay on the ground to much the tire more rearward in order to get the locking pin in place. On the 23D, we fabricated some extension supports to get the 15" Michelin spare mounted in lieu of the stock 14" tire.
Old 10-12-2015, 06:17 PM   #56
2016 25' Flying Cloud
Holly Springs , Mississippi
Is anyone using the Carlisle Radial Trail trailer tire? This ST225/75R15 appears to have a load rating of 113T (2535 lbs.) when on tandem axles. This would be higher than even the 108T (2205 lbs.) of the passenger-rated Michelin LTX P235/75R15 tires, and the Carlisle is built for trailers.
Wouldn't this be a worthy substitute for the Goodyear Marathons that are OEM, and perhaps even for the Michelins?
What am I missing here?
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Is this a "Split Rim"? Studioman Wheels, Hubs & Bearings 30 03-16-2015 06:28 PM
16" rim substitute hertfordnc Wheels, Hubs & Bearings 2 04-03-2011 02:54 PM
Help with rim specs for 26" 1975 Argosy camper! antman Wheels, Hubs & Bearings 1 12-22-2010 10:31 PM
Centramatics -- 16" wheel rim size larry b Wheels, Hubs & Bearings 14 01-26-2010 04:38 PM
