Old 10-27-2015, 09:54 AM   #127
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Still Load Range D in a 15" and Load Range E in a 16"-
I guess I made the right move switching to 16" wheels and tires.
If I screwed up, I blame Airforums-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 10-27-2015, 09:59 AM   #128
Ravenna , Ohio
Originally Posted by Phoenix View Post
Tireman9, you keep repeating that "interply shear" is the primary cause of ST tire failures. Before switching to 16" wheels and LT tires, I had 3 of 5 ST tires fail with tread separation (two GYMs and one Maxxis).
Our 19' Bambi has a single axle, so interply shear is not a significant factor when towing, backing, etc.
We now have about 40,000 miles on our 275/75x16 Michelin XPS Ribs (LT, load range E, inflated to 80 psi), and have had absolutely no tire problems in 4 years.
How do you explain the difference between ST and LT tire reliability on our Airstream?
To answer your question it would help if I knew the size & LR of the ST type tires but I suspect it was a much smaller tire with much lower load capacity.
Its pretty hard to make a comparison across such large differences in tire size and type.
Tireman9 is offline   Reply With Quote
Old 10-27-2015, 10:01 AM   #129
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
15" rim vs. 16" rim ?
They work for me. I sit at about 6,600 pounds "ready to camp" on my trailer axles, leaving me about 1,500 pounds to full tire capacity.
Brevi tempore!
Old 10-27-2015, 10:05 AM   #130
Ravenna , Ohio
Originally Posted by jcanavera View Post
Here's the link to the site. https://www-odi.nhtsa.dot.gov/ivoq/Complaint.cfm
But understand the industry is stacked against us. From my own experience with a road hazard warranty on a claim, the dealer will use every trick in the book to throw the blame on you. I picked up a nail on my car tire and the tire deflated quickly. I got off the road quickly and got the spare on. Dealer confirmed that I had a puncture that was just outside of the tread. Not repairable due to the location. Hazard warranty claim denied due to debris inside the tire indicating the tire was rolling while flat. I noted that I was rolling when the tire suddenly deflated and yes it was rolled on as I was getting to the shoulder of the road. I protested to the manager and he made an "exception" and allowed the adjustment for road hazard damage. So much for tire forensics and my confidence in the industry to root out tire defects.
Most of us lack the proof or the facilities to prove the weight of our vehicles, tire pressures, and speed that our tires were at when the failure occurred. Without the forensics which are hard to provide, simply asking for an allowance from the dealer is like pulling teeth.
Jack
IMO if you had purchased Road Hazard warranty and the dealer admitted there was a puncture then the dealer should have made good on the warranty. It appears he sold you Insurance and is now trying to renege on the deal. This might even be worth a complaint to the local BBB.
The idea behind a RH warranty is that the tire will be repaired or replaced even if there is a puncture.
Old 10-27-2015, 12:49 PM   #131
m.hony's Avatar
2013 30' Classic
Brevi tempore!
My trailer is heavier, at 8,800# ready to camp.
I feel better with Load Range E. I feel like it was an upgrade from the Goodyear Marathon Load Range D 15" tires.
TAC #MS-10
Airforums #70955
Old 10-27-2015, 04:37 PM   #132
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
We should all look for our "Goldilocks" tires, not too hard and not too soft, but just right...
Brevi tempore!
Old 10-28-2015, 08:54 PM   #133
2005 19' Safari
GLENDALE , AZ
Originally Posted by Tireman9 View Post
To answer your question it would help if I knew the size & LR of the ST type tires but I suspect it was a much smaller tire with much lower load capacity. Its pretty hard to make a comparison across such large differences in tire size and type.
Below is info on the three failed ST tires:
  • Goodyear Marathon, ST225/75x15, load range D (original, factory-installed tires that came on our Bambi). These two tires were always inflated to 65 psi, were about three years old, and they had about 6-7,000 miles on them.
  • Maxxis, ST225/75x15, load range E (one of two tires that replaced the two GYMs). This tire was always inflated to 80 psi, was less than one year old, and had about 2,000 miles on it.
Old 10-30-2015, 12:39 PM   #134
MACINRIC's Avatar
1977 29' Ambassador
Richmond , Virginia
Thanks everyone.....Ordered up some addl 15's for now.
MACINRIC is offline   Reply With Quote
Old 10-30-2015, 06:32 PM   #135
Climber's Avatar
2012 27' Flying Cloud
Portland , Oregon
Question for those running 16" Michelins:
We just upgraded from 15" GYMs to LT 225/75/R16 M/S2 tires on our 2012 27' Flying Cloud. We have an Equalizer Hitch.
Is it normal for the trailer to feel a little more "lively" in tow. The trailer isn't swaying, it just feels "frisky" and I can definitely feel its presence back there.
I'm wondering if the extra 1" radius calls for a bit of hitch height adjustment.
We'll be on the weigh scales Sunday so I'll look for any deviance in tongue weight.
Thanks to all you experts out there for an opinion!
Cheers,
Climber
ps we're running at 80 psi
2012 27' Flying Cloud FB (Bella)
2014 F-150 3.5L Ecoboost
Climber is offline   Reply With Quote
Old 10-30-2015, 07:06 PM   #136
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
I typically tow at 60-65 and only exceed this if and when I have to pass.
any recommened pressures that anyone has to offer?
Here we go, the controversy begins.
I use the Michelin load rating chart to my 16" LT E rated tires are set around 60 psi. The E rated tires are really hard so jarring is an issue too. I started at around 50psi and have watched temp. increasing to the 60 psi.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 10-31-2015, 06:38 AM   #137
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
When I weighed the individual 16" wheels on the loaded for camping Classic, I had two that were nearly identical and the other two were one higher and one lower than the pair. Thus I had to consider the highest load for the setting for all four.
I currently run at 75 psi but may try 72 on the next trip and see what the Dill TPMS reports.
switz is online now   Reply With Quote
Old 10-31-2015, 06:38 AM   #138
CapriRacer
CapriRacer's Avatar
I'm in the , US
I am interpreting the word "temp." to mean temperature, but I think you mean "pressure".
And a pressure buildup from 50 psi to 60 psi is way too much. That's 20%, and you don't want to see anything more than 10%. You need to use more pressure - and I would suggest that 65 psi is where you want to be.
Oh, and the load charts are MINIMUMS, not recommendations.
CapriRacer is offline   Reply With Quote
Old 10-31-2015, 06:43 AM   #139
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Run our 16" Michelins at 73 Degrees F. 10,000 miles this summer, varied somewhat during driving, came down to 73 quickly - no issues at all and a surprise to me with our F350 and the 30' no popped rivets I could find and I checked all over the inside, under the trailer and outside. Just lucky I guess.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 10-31-2015, 04:22 PM   #140
TheCabin's Avatar
Liberty Corner , New Jersey
So it sounds like we can risk the damage to our wheel wells when a 15" GYM blows or switch and take the chance of shaking the trailer apart with 16" higher pressure LT tires. This is fun.
TheCabin is online now   Reply With Quote
Is this a "Split Rim"? Studioman Wheels, Hubs & Bearings 30 03-16-2015 06:28 PM
16" rim substitute hertfordnc Wheels, Hubs & Bearings 2 04-03-2011 02:54 PM
Help with rim specs for 26" 1975 Argosy camper! antman Wheels, Hubs & Bearings 1 12-22-2010 10:31 PM
Centramatics -- 16" wheel rim size larry b Wheels, Hubs & Bearings 14 01-26-2010 04:38 PM
