01-17-2017, 01:50 PM
#141
2012 30' Flying Cloud
San Antonio
Originally Posted by 2012FB
My guess the 30' and up had to many GYM failures reported. Perhaps a few angry customers demanded they fix the damage caused by tread separation on their new trailers. I am sure it is based on money/risk ratio not just because they are better for the customer.
I'm truly surprised that AS is mounting original equipment tires in anything other than ST tires. To my knowledge Michelin states they do not recommend their passenger or LT tires for use on trailers. If that is still correct, seems like AS is trading one legal liability for another.
Maybe AS has something from Mich, in writing, that allows, or recommends, the use. Would be interesting to know.
01-17-2017, 10:49 PM
#142
2004 30' Classic
San Antonio
Originally Posted by Barbieri
Did they modify the suspension? What changes did they make compared to prior years? Mine is 2004. Changing tires to what they show in the 2017 catalog is wrong.
It all come down to load range. What is the load bearing capacity of the tires your putting on the trailer. Are the tires capable of handling the load your asking them to carry and at what speed. Is it greater than and what is the safety margin?
01-18-2017, 07:13 AM
#143
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
If the 2004 Classic has the stock GYM ST225/75R15D tires rated 2,540 pounds @ 65 psi and are 28.3" in diameter, then the Michelin LT225/75R16/E LTX M/S2 tires rated 2,680 pounds @ 80 psi and are 29.2" in diameter will raise the coach less than ½" and the should clear the wheel well trim with no issue, as the suspension moves the tire up and back when a bump is hit. The Michelin is not speed limited per the sidewall to 65 mph max speed like the GYM and holds air all the time.
However, one does have to acquire 16" wheels as well. The average cost is in the $1,600 rage for the Michelin tire and the SenDel T03-66655T wheels the factory installs on the 2015 and later Classics, the Eddie Bauer models and the Pendleton limited edition. There is that tire and wheel on display at the entrance hallway into the factory service center in Jackson Center, Ohio and they will, for a price, install them on any 25' or longer trailer.
The 16" Michelin tires would NOT fit on my 2015 23D International Serenity that came with 14" GYM ST215/75R14C tires rated 1,870 pounds @ 50 psi and are 26.7"in diameter on the stock 14" wheels. We were able to upgrade to the 15" Michelin LTX (P) 235/75R15 XL tires rated 2,183 pounds @ 50 psi (derated to 1,985 pounds for trailer use per federal regulations) and are 28.9" in diameter mounted on SenDel T03-56445T wheels (which have the five lug bolt pattern of the 10" brake drums. For 2017, Airstream now installs 12" brake drums and the 15" GYM ST225/75R15D tires since the 14" tires are going out of production.
01-18-2017, 08:17 AM
#144
2004 30' Classic
San Antonio
15" Michelin tires recommended?
The tires I use are rated load range E and more than the Michelin and dedicated for trailers. The sidewalls flex where as the Michelins don't. Mine are rated 80psi at 80mph. All without having to change rims. I would say that cost effective ratio is on my side. You also use load range D and that is the problem.
01-18-2017, 08:37 AM
#145
Anna Maria
Originally Posted by gypsydad
OK; I'll bite: What is "wrong" with swapping out the tires on your 04' rig to 16" wheels and Michelin tires? I hope your not offended, but many of us have made this switch and are happy. If AS is offering as an "option" now as many have said, not sure the issue? But, we are interested to know what we may be missing?
On our 2013 30' International I changed to 15" Michelin LTX 275/R/15 tires after the GYM failed.
The best decision ever. The ride is far superior as is stopping not to mention the luxury of not having to constantly fiddle with the tire pressure, even though I monitor it religiously having gotten into the habit.
01-18-2017, 08:45 AM
#146
2004 30' Classic
San Antonio
I just feel that it is to me money wasted and I just upgrade to a better tire. Besides I don't notice any ride difference since I have a trailer not a motor home and I don't sit inside going down the road. .
01-18-2017, 08:57 AM
#147
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
, Texas & Wyoming
Hope your not going "80MPH" with that 30' Classic! With your 30', likely you may not notice any difference in ride. With my 25', it is a smoother ride for sure over the GYM which came with the unit. Wife noticed it also. But that's not only reason we switched. We have had great luck with all the Michelins we ran on our passenger vehicles and AS over the years. They preform well, no structural issues to date, achieve good mileage on tread, and as I mentioned, seem to ride better. But, doesn't mean everyone needs to be using Michelins...there are other choices, for sure.
01-18-2017, 09:37 AM
#148
2004 30' Classic
San Antonio
When I go down the road in Montana and other northern states I have people passing me while driving at 60-65mph. It is amazing how people have total disregard for safety. I did have problems with the GYM tires but equate that to not understanding the limitations of the tire. Happy trails guy. Be safe.
01-18-2017, 01:18 PM
#149
2013 31' Classic
billings
, Montana
I had no problem with the gym's, 3.5 years and 22,000 miles, some of the replacements were junk ,green ball for one, replaced with the michelins, they cost a lot more, you get what you pay for, there is no bargains out there..and they weren't made in China.i like Costco , and that is one that they sell..
01-18-2017, 02:55 PM
#150
2008 22' Safari
Spicewood (W of Austin)
Originally Posted by louaxtjr
Have run P235/75r15 Michelin LTX XL's for 4-1/2 years of full-time ...
These tires were chosen (back when we were preparing for full-timing) as the same tire could also fit our tow vehicle (1969 Chevy C-10.) This allowed us to carry just one spare.
Will likely replace with similar Michelins.
That's an interesting idea, carrying only one spare. But I don't/didn't realize the Chevy C10 had 6-lug wheels.... or were the wheels actually interchangeable?
01-18-2017, 03:25 PM
#151
Lin
, Ne
Well if you don't know, how did you know it was wrong before?
01-18-2017, 03:37 PM
#152
Lin
, Ne
Think about this, it would be suicide to put ST tires on a truck.
01-18-2017, 08:32 PM
#153
2013 31' Classic
billings
, Montana
Who says? No difference between steer tires and trailer tires on my big truck..been doing it for over 50 years....16" michelins on my 31' classic also...they are good if worried about the weight rating..
01-18-2017, 09:46 PM
#154
2004 30' Classic
San Antonio
Guys. I am lost on some of these posts. Like NO DIFFERENCE, in reference to what.
01-19-2017, 08:56 AM
#155
Anna Maria
Running with the GYM over concrete pavement usually left the inside of the trailer a mess. Cushions on the floor etc.etc. Following one nightmare trip to Colorado on I-76 the shower door came crashing down. And no I wasn't ripping along at 70 MPH.
That was 3 years ago. Last year we did the same run with the Michelin's the ride was still a bit rough but everything stayed in place. I have to note that I also got rid of the Trunion Bar hitch and installed a BlueOx. That also improved the ride significantly.
01-19-2017, 09:11 AM
#156
2017 25' Flying Cloud
Florence
, Alabama
Swapped my new tires and rims out after 2K miles after hearing and seeing gym disasters. Over 6K on my 16" TO2s and Michelins and all is good. For those who stand by the gym, that's fine with me. This was my decision and I'm good with it.
DBLee and Southern Belle on the road
The Colonel and Southern Belle
01-19-2017, 11:45 AM
#157
, Texas & Wyoming
Have to agree with this experience on our 25'. We replaced GYMs with Michelins this summer and on same camping trips to Glacier late in summer/fall, no cushions on floor either. Michelins do have smoother ride from my experience.
01-19-2017, 12:02 PM
#158
2022 25' Flying Cloud
2015 30' FB FC Bunk
2012 25' FB Flying Cloud
Golden
Trailer ride is based more on tire pressure matching specific weight per Michelin's weight/PSI chart. A Michelin will give a stiff ride if at maximum pressure on a 25' for sure. Dial it in. On my 30' with 15" Nokians I am running between 65 and 70 depending on gear and temps.
2022 25RBT FC, 50A Dual AC, Awning Package, 270W Solar, Convection Microwave. Ceramic Coat, Grand Lounge, 3" Lift, 16" Michelin RIBs, Multiplus II, Battleborn 400A, MPPT 100/50, Orion-TR 30, EasyStart (2), Easy Touch, AirKrafters jenRack, Onan 2500i, Truma Aquago Confort, Starlink, Pepwave, Parsec
01-19-2017, 09:29 PM
#159
2004 30' Classic
San Antonio
Your not supposed to be in a trailer while going down the road. So the question that begs to be asked. How do you know what type of ride you have? Please let's start getting serious.
01-19-2017, 10:17 PM
#160
2007 22' International CCD
Corona
Stuff on the floor that started off put away is a good indication of a rough ride. The other is popped interior rivets.
