Old 11-08-2015, 11:32 AM   #29
Longboard6's Avatar
2015 23' FB Flying Cloud
Sacramento , California
As a non-functioning gearhead, where would I go to get this done for me?
Longboard6 is offline   Reply With Quote
Old 11-08-2015, 11:58 AM   #30
Refugee from Napa, CA
Photobum's Avatar
2015 25' FB Flying Cloud
Madison , South Dakota
Try Orange County Airstream in Westminister. You could go to Fairfield but I don't like those folks. Your mileage may vary....
www.vincentgoetz.com
Instagram. Alluminator
Photobum is offline   Reply With Quote
Old 11-08-2015, 02:59 PM   #31
PKI
PKI's Avatar
Walnut Creek , California
What is normally used for the center hub cap with the new 15in wheels? Does the 14in cap fit the new 15in wheels, or do you just mount the wheels without a center cap?
Centramatics - $199 for a pair or each?
Old 11-08-2015, 04:58 PM   #32
2017 30' International
Woodland , California
PKI, I recently purchased a set of Centamatics for my 25FB with 6 bolt hole 15" wheels. Cost was $199 plus $14.95 shipping for a total of $213.95 for a set of 4. I bought from Centramatic directly through their web site. I also called them with a question and they are a pleasure to deal with. Jim
Jmacd is offline   Reply With Quote
Old 11-08-2015, 07:00 PM   #33
PKI
PKI's Avatar
Jim . Thank you very much. Appreciate the pricing. Kind of makes it easier to add to the upgrade list. Pat
Old 11-09-2015, 04:39 AM   #34
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We reused the Airstream center hub from the original Airstream wheels on the SenDel wheels for both the Classic and the 23D.
We have 44 psi in the 15" Michelins as that's the suggested number from CanAm we used for the 25FB and the 23D is 1,300 pounds lighter in GVW.
Also, due to a memory misfire in my prior post, the bars on the Hensley are actually the 1,000 pound bars.
On the way home from CanAm with the 23D, I did have to stop at a farm implement store to get a good grease gun for the Hensley. It had started to complain about lubrication for the weight distribution arms.
I carry a grease gun in both trailers so can lube as necessary when on the road.
Old 11-09-2015, 07:46 PM   #35
PKI
PKI's Avatar
Switz - thanks for the cap info. Really appreciate your sharing. Pat
Old 02-07-2016, 04:03 PM   #36
Vashon , Washington
I ordered 15" Sendel wheels and Nokian cCargo tires in 225-15 for my 2015 Airstream 23 FB. From Discount Tire. Picking them up Wednesday. Size difference is minimal, about .25" larger for the Nokian/15" Sendel setup. Only concern is that the cCargo may be a little stiff.
guillaume is offline   Reply With Quote
Old 02-07-2016, 04:09 PM   #37
Vashon , Washington
... actually the name is cLine Cargo, 225/70R15 C 112/110. they are 6 ply rated as is the original equipment GY Marathon. I believe the Michelins are only 4 ply rated. cLine Cargo rated at 2464# vs Marathon's 1870#.
Old 02-07-2016, 06:16 PM   #38
PKI
PKI's Avatar
The 14in center caps did not quite fit the new Sendel 15in rim center holes. They were a bit small and required a wrap of tape to make up the void. An easy fix, but worth the time to correct. Pat
Old 02-08-2016, 06:02 AM   #39
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Actually, the Nokian cLine Cargo 225/70R15C 112/110 (115N) S Cargo is closer to a Load Range D (LRD) tire. It is a Euro Commercial tire, and as such it has its load expressed with a load index. In this case the load index of 112 equates to 1,120kg (2464lbs).
The "ply ratings" are no longer used. They were outdated in the 70s when radial tires replaced bias ply tires. Although it may make the old crowd feel comfortable, "ply ratings" are not any good way to describe a modern tire's load carrying capacity.
The 15" Michelin tire commonly used is a passenger P type Extra Load (XL) tire.
Lance
Top is offline   Reply With Quote
Old 02-08-2016, 11:10 PM   #40
Vashon , Washington
I think some people write just to see their words in print.
I stand by my (re)printed specifications exactly as written.
Your "amendments" are in fact misinterpretations of almost all current tire manufacturer's stated specifications.
Old 02-09-2016, 06:30 AM   #41
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
I write to attempt to help other people learn what I've learned here on this forum. First tier tire manufacturers do not use "ply ratings" to express load capacities for radial tires. They use Load Index on P type tires and Load Ranges on LT and ST type tires.
http://www.barrystiretech.com/loadtables.html
http://www.barrystiretech.com/sttires.html
Lance
Old 02-09-2016, 08:16 AM   #42
switz's Avatar
2014 31' Classic
Images: 8
I got the energy together yesterday, (still fighting a cold for over a month) to get some real exercise and setup my scales to weigh the camping ready 23D with all of the mods except the refrigerator that will add about 15 pounds directly above the street front tire.
.........928
1,280.........1,246 - total on axle 2,526
1,376.........1,233 - total on axle 2,609
With all the electronics installed for the solar system under the street side dinette and sofa, I expected the street side to be heavier. The street side rear will be the heaviest loaded tire sine the black tank is on the left rear of the trailer.
Name:	23D Curb side.jpg
ID:	257064   Click image for larger version
Name:	23D Street side.jpg
Name:	23D Street side 1.jpg
ID:	257066   Click image for larger version
Name:	23D Scale Display.jpg
15 inch rim for 1974 Argosy 22 VtTim Wheels, Hubs & Bearings 6 04-19-2014 05:32 PM
Upgrade to 16 inch Wheels and Tires ddruker 1999 Safari 3 03-04-2013 04:18 PM
Microwave upgrade for Sport 16 Rich of SCal Stoves, Ovens & Microwaves 9 10-25-2012 11:55 AM
3.5 inch curved sewer adaptor JosephVlcek Waste Systems, Tanks & Totes 6 12-16-2011 08:11 AM
1 inch off and tree wins! stefario Exterior Restoration Forum 5 07-09-2011 01:54 PM
