Old 01-20-2016, 07:30 PM   #1
Kittyfeet's Avatar
2016 23' Flying Cloud
Dallas , Texas
14" to 15" on AS 23.
14" to 15" on AS 23. Anything I should be especially cautious of in increasing?
Kittyfeet-
I hope this day to have the opportunity to help someone in need.
Kittyfeet is offline   Reply With Quote
Old 01-20-2016, 08:06 PM   #2
field & stream's Avatar
2008 23' Safari SE
2007 Base Camp
Santa Ynez , California
We did not have any clearance issues at all on our L-lounge version of the 23'. But on one of the threads on this subject someone stated that they had to trim one wheel well opening a little -- can't recall if it was the FB or the Dinette model. Did not stop the conversion, just caused a little bit of modification.
Maybe they will respond here, or you could use the Search feature on this website and try to find it.
field & stream is offline   Reply With Quote
Old 01-20-2016, 08:29 PM   #3
Kittyfeet's Avatar
Dallas , Texas
Thanks. I wondered about the rear of the wheel well. It was recommended to go to the larger wheel, but before I tried, wanted to see if anyone has had any problems. Appreciate it.
Kittyfeet-
Old 01-20-2016, 08:32 PM   #4
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
23FB converted to 15in and no issues. Refer to previous threads for wheel and tire recommendations.
Steamy1 is offline   Reply With Quote
Old 01-20-2016, 08:42 PM   #5
2008 23' Safari SE
2007 Base Camp
So, by elimination it seems it is the Dinette model with the issue. Which model do you have?
Old 01-20-2016, 10:14 PM   #6
interstateflyer's Avatar
2017 25' International
Los Osos , California
Theoretically there should not be any lateral movement in the wheels. I filed the wheel well trim back to 1+ inch just to be safe. 10K miles and no problems.
Going to 15 inch Michelins and T03 Sendel wheels made a "happier" 23D. The ground clearance is increased, more cushion for the trailer and greater footprint for better braking. BTW....the 10 inch brakes do a great job with the larger wheels.
The only issue may be a tendency for snow to get packed into the smaller space. I don't intentionally tow in the snow so not an issue.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 01-21-2016, 04:17 AM   #7
Kittyfeet's Avatar
Dallas , Texas
Thanks all. Have the 23FB. If I end up towing in snow, it is going to mean I am way off course and I have a lot more problems than snow pack. Happy camping.
Kittyfeet-
Old 01-21-2016, 06:44 AM   #8
CapriRacer
CapriRacer's Avatar
I'm in the , US
Originally Posted by interstateflyer View Post
Theoretically there should not be any lateral movement in the wheels ..... .
CAUTION: Tires deflect sideways, so while the wheels may not have significant lateral movement, the tires will - and rubbing may be possible under driving conditions.
CapriRacer is offline   Reply With Quote
Old 01-22-2016, 09:38 AM   #9
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
The curb side wheel well on our 2015 23D International Serenity had more sheet metal in front of the 14" tire than the street side (another manufacturing defect) wheel well.
Going from the stock GYM ST215/75R14C tires with a diameter of 26.7" to the Michelin LTX (P) 235/75R15 XL tires (mounted on SenDel T03-56445T wheels) with a diameter of 28.9" meant these tires were about 1.1" larger in diameter. We trimmed the front edge of the curb side wheel opening to have the same dimension of skin behind the vertical plastic wheel well as the street side and the tire fits fine.
The trailing arm suspension Airstream uses means that the wheels travel up and back when a bump is hit.
switz is online now   Reply With Quote
Old 02-04-2016, 11:42 PM   #10
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Installed the 15in on a '15 FC23FB today. Clearance looks good.
Switz - what did you do to lower the spare tire carrier? I thought I read you drilled a new hole about 1/2in higher on the rack mounts, but it looks like at least 1in additional clearance is needed and there is not enough material to do that. Considering using an extender tab with a hole to connect the mount and another to attach the assembly to the frame. Your help is appreciated. Pat
Old 02-05-2016, 07:03 PM   #11
PKI
PKI's Avatar
Added about 2" to the spare tire rack rear brackets. That is more than what is needed, but the configuration of the front arm makes it hard to get the tire up into the locked position with less rear clearance. Got a feeling my rack needs additional review, but the spare is up and locked.
Old 02-05-2016, 10:11 PM   #12
switz's Avatar
2014 31' Classic
Images: 8
We fabricated a completely new carrier for the 15" tire.
Old 02-07-2016, 07:55 AM   #13
PKI
PKI's Avatar
Switz - I can understand that approach. Thanks for the clarification. Pat
Old 04-14-2017, 01:01 PM   #14
GettinAway's Avatar
2011 23' FB Flying Cloud
Chesterfield , Missouri
Ordered the T02s from ETrailer today. Couldn't get the price any lower that $98 with free shipping. Will order tires in a few weeks. Zero offset, correct?
Thx
Jeff
2011 FC 23FB
2012 Toyota Tundra Dbl Cab, 5.7 4x4
GettinAway is offline   Reply With Quote
"silver avion" avion C11 airstream "truck camper' "slide-in" aluminum eBay Watch Airstreams on eBay 0 09-14-2013 06:20 PM
I want "Today's Posts" when I'm "logged in"! 66Overlander Forum Admin, News and Member Account Info 10 06-08-2004 07:32 AM
To "file" or Not to" file" Raptorrider2001 Our Community 3 04-14-2003 08:20 PM
