Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 10-02-2003, 11:14 AM   #1
Profile:
1/2 ton tires- load C to load E
I had 65,000 miles on my Firestone SteelTex AT load C and prior to coming back from NM, I put on 4 new Firestone SteelTex Radial R4SII load E and what a difference.
With the load C, I felt the semi's sucking me in and pushing me out while being passed on the hwy. Now with the load E, I get none of that.
Just thought I'd past this along.
John is offline   Reply With Quote
Old 10-02-2003, 11:33 AM   #2
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 41
John,
I feel a lot of this semi-induced sway as well, with my Suburban and the load range C Michelins. Much more so than when i used the van with load ange E tires. There must be a point to this, i guess. Stiffer sidewalls?
I had a difficult time finding Load Range D or E tires for the Suburban. It's a 235/75R15 size. Went with the LR C because 2 tires were still good.
Uwe
www.area63productions.com
Old 10-02-2003, 11:46 AM   #3
Profile:
Uwe,
Stiffer sidewalls is the key.
I have the LT245/75R16 on mine.
I paid $95 per tire.
Old 10-02-2003, 04:48 PM   #4
dinoburb's Avatar
Profile:  1982 34' Limited
Tidewater , Virginia
Stop that sway!!
I have a 3/4 ton Suburban that never seemed to tow without some apparently induced sway. I have SteelTex's as well, E load range. The size is 235/85x16. The sway was because I did not read the inflation requirements on the sidewall. I was running 45/50psi which I thought was fine. The proper inflation is 80PSI!!!
What a difference! Sway is a thing of the past. Since the truck was designed and delivered with this same tire the ride is tolerable. It's an older truck so some of the modern comforts are lacking, but with less than 120K on a strong 454 which was paid off 18 years ago, I'm quite happy.
Bottom line: read the inflation requirements, believe them and buy the correct size and ply rating for your application. It just makes life a little easier, and who doesn't need that?
Take care
Old trucks and old trailers . . . a comfortable combination!
AIR 1446
W5CDR
A-6E All Weather Attack Driver, BUFF
USN Aircraft Maintenance Officer, Ret.
'91 Suburban R-2500 w/BBC
'78 Honda GL-1000
'72 Triumph T-100R Daytona
dinoburb is offline   Reply With Quote
Old 10-02-2003, 09:03 PM   #5
Profile:
I also have the 245/75r16 SteelTex E on my 2003 GMC 2500HD.
I have been running 65psi front and 80psi back when towing and the truck, tire, trailer combo works great. Absolutely minimal sway from the big trucks. The only trucks that cause any sway are the old square front trucks pushing alot of air as they come up on the rear of the trailer.
Tires with an E rating have much heavier beads and a longer carcass turnup around the bead with a filler inside the turnup. With 80psi to hold the envelope rigid, the movement in the sidewalls is minimal.
That's why I just smile when people try to tell me some old cars will tow an airstream better than my 2500HD.
wingfoot is offline   Reply With Quote
Old 10-03-2003, 06:41 AM   #6
85MH325's Avatar
Profile:  Tipton , Iowa
Images: 37
Tire inflation...
Ok, guys... a question... In June, I replaced the "D" range Steeltex tires on my Excursion with "E" range 245/75R-16 Steeltex also. I have been running about 60psi front and 70 rear with the trailer, but it sounds like I need to go a little higher to the 80psi; although 70 seemed to be fine with no induced sway, and I was under the impression that 80psi was the MAX inflation... BTW, I have towed it short distances (40 miles or so) a couple of times with the tires at 55psi (mostly 'cause I was too lazy to go get them inflated properly) and DO have sway at 55psi... go figure! Underinflation causes sway? Whoda ever thunk it?
Anyway, what do you guys run them at when you're NOT towing and loaded? I've got mine currently at 55psi, which seems to work OK, but I don't want to wear them prematurely either or potentially have a sidewall failure. The tire sticker on the Excursion actually recommends 35psi (unbelievable to me)! Firestone wasn't much help; they just say you can run them up to 80psi, but won't give a recommended psi.
Roger
AIR 2053 “A generation which ignores history has no past and no future.” Robert Heinlein
1994 Airstream B190 & 2006 Bigfoot 25B25RQ
Old 10-03-2003, 07:50 AM   #7
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
85mh325
I run 55 psi front and back when not towing. I recently had tires rotated and balanced and the guy put 65 in the rear "in case I had to tow something." You can sure tell the difference in the '01 2500HD with the Steeltex E rated LT245-75-16 tires when going over bumps. The tongue weight of my 31' Excella 500 '77 model is around 1100 lbs. so I air the rear tires up to 70 psi and have not had any problems with sway at that level. You are correct when you say that the 80 psi is MAX so do not go over that.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 10-03-2003, 10:00 AM   #8
uwe
418
uwe's Avatar
Images: 41
I had 245/75/16 "E" GoodYear Wrangler HT's on my 1 ton van. I would run the factory recommendet pressure when empty, and i would go to 55 in thefront and 70 in the rear when towing, or when hauling heavy loads. Max pressure on these tires is 80lbs.
Now I use a 1/2 ton Suburban to tow my Tradewind. (235/75R15) So far I have towed about 2000miles with it. The "C" rated Michelins that are on it ( still new) are definitely looser in corners, and do feel looser when towing.
I can hear the rear tires howl, and i can feel the back end drift when taking mountain roads at similar speeds as i would when i drove the 1 ton van.
Uwe
Old 10-03-2003, 10:19 AM   #9
Profile:
As stated, 80 psi is the maximum for when the tires are loaded to their maximum. The correct tire pressure for the load on each tire (you can have this measured at your local scales) is given for LT tires rated E at http://www.trucktires.com/library/te...infl/index.asp
These figures have been agreed by the tire manufacturers. You will find the Light Truck figures at the bottom of the menu, and you can print out the three PDF files for reference. You will be able to see precisely what pressure you need when towing, and what lower pressure you need when not towing. Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 10-03-2003, 10:36 AM   #10
85MH325's Avatar
Images: 37
Thanks!
Nick, it amazes me what resources the folks on this forum possess. Thanks for the link, it's VERY helpful!
Roger
Old 10-03-2003, 06:54 PM   #11
Profile:  1986 31' Sovereign
jonesboro , Arkansas
Wink Steel tek tires
I found out about a year ago that bridgestone makes the steel tek .my firestone dealer decided to be nice to me when I went in to buy 3 sets of tires for 3 vehicles at one time. They have a line of tires called lemans a/t that come off the same line as the steel-tek They just have different logo's on the side. Same wt rating etc.The kicker is they are 1/2 to 2/3 the price with the same warranty. I have them on my 1/2 ton and my 3/4 ton with e rating. He even showed me his 32' TT with 13,000 miles on the same tires that I put on my 1/2 ton. Most of the miles were put on pulling to and over the rockies twice a year. Don't know about putting them on a trailor but he likes them.
joel is offline   Reply With Quote
Old 10-03-2003, 10:10 PM   #12
davidz71's Avatar
Stay with ST rated tires for trailers and keep the LT for the truck.
Craig
AIR #0078
3.73 rear end
Old 03-16-2004, 09:26 PM   #13
Profile:
As an update to this thread, the LT tire inflation tables (3 PDF files) referred to previously, have been moved to http://www.trucktires.com/us_eng/technical/index.asp
About one third of the way down the page is the link for light truck tires. Nick.
Old 03-16-2004, 09:35 PM   #14
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Just an FYI
Many of the manufactures have a max inflation pressure on the wheel itself. Especially the aluminum ones. if you go to a higher range tire than the wheel can hold the pressure of you may be in for a problem later. cracking or failing wheels. Before you change to a higher load rating you may want to verify that the wheel can take the tire's max inflation.
Brett G
WBCCI #5501 AIR # 49
Logic is the one way you can go wrong with confidence - Charles E. Kettering
Surburban 1/2 ton as a Tow Vehicle dmreilly10000 Tow Vehicles 3 12-10-2003 11:45 AM
Broke the frame of 1/2 ton Chevy qqq Tow Vehicles 11 11-16-2003 09:58 AM
1/2 Ton Truck Tow Capacity. Real? CanoeStream Tow Vehicles 1 11-02-2003 03:36 PM
Hmmm...Chevy Burban 1/2 ton and 27' Safari. docbluedevil 2000 Safari 3 10-05-2003 09:46 PM
Hmmm... 2003 Chevy 1/2 ton burban & 27' Safari docbluedevil Tow Vehicles 7 10-02-2003 09:11 AM
