Old 03-22-2012, 07:23 AM   #113
2008 19' International CCD
Spring , Texas
Originally Posted by jdalrymple View Post
Wow. I did not know pulling a travel trailer could be so dangerous. Maybe if I sell everything and just by a very small tent and backpack stove I can still go camping and not be in peril. If I just don't overload my vehicle.
Come on guys, you are scaring the noobies.
JD
Jeff:
The nice thing about the trailer; if nature calls in the middle the night; you don't have to get out the tent and deal with "nocturnal animals" of the night.
Ed
eleighj is offline   Reply With Quote
Old 03-22-2012, 11:41 AM   #114
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
The noobs can just go back to Smith's link to a conversion chart. The reasons why are for those who've an interest otherwise.
Old 03-22-2012, 12:03 PM   #115
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Originally Posted by eleighj View Post
Jeff:
Ed
Depends on your personal hygiene standards.
But back to tires….
Rednax,
The question that never has been answered and I ask it every couple of months on one tire thread or another: why do auto and truck manufacturers always recommend less pressure in the OEM tires than is stated as maximum on the sidewall? Or, another way, why wouldn't they recommend maximum sidewall pressure if it is safer?
I am assuming (because I didn't read the linked thread) that recommending maximum psi stiffens the sidewalls and that is why we should run a maximum. Is that correct?
I don't know if I ever looked at your older Silverstreak so I clicked on the link. It was beautiful! It must have been very hard to part with it. Did you get all the work done around the house when you removed the SS temptation?
Gene
Old 03-22-2012, 12:56 PM   #116
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
JD
Hey, those backpacking stoves can explode, start fires, you can scald yourself with your coffee.... it never ends!
— David
Old 03-22-2012, 02:54 PM   #117
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Oh man. Where is Ralph Nader when we need him? First the Pinto, now just look.
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 03-22-2012, 04:09 PM   #118
Master of Universe
Gene's Avatar
We'll never see Nader out in the wilderness. He couldn't get to the trailhead—he doesn't drive.
I don't know how we survived tent camping years ago with the bears, coyotes, mountain lions, skunks, snakes and other wildlife. I'm going to go hide under the bed—wait, I can't do that, the dust will trigger my allergies. We're all doomed! Might as well tow the Safari somewhere as the end is near anyway. I am getting solid rubber tires.
Gene
Old 03-22-2012, 04:54 PM   #119
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
This may be the solution to all of the tire issues!
Name:	Michelin Airless Tire.jpg
Steamy1 is offline   Reply With Quote
Old 03-22-2012, 06:19 PM   #120
jdalrymple's Avatar
Jay , Oklahoma
Not so fast.
What is the:
Weight Capacity?
Speed Rating?
Acceptable Side Slip Angle?
Too many unanswered questions here.
Just making a point. I'll quit.
Jeff & Cindy
'91 350 LE MH
Old 03-22-2012, 09:45 PM   #121
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Not so fast.
What is the:
Weight Capacity?
Speed Rating?
Hi, at least the tire pressure problem/debate would be over. And you can save by not having to buy TP monitors too. [not that I would ever buy one]
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 03-22-2012, 10:56 PM   #122
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Originally Posted by CrawfordGene View Post
Rednax,
Gene
My understanding about tires has always been the load/pressure relationship. For a tire to have the longest life, greatest reliability and best performance in braking & handling, then a tire properly rated for the GVWR (and a bit more; why axle WR combined is higher than GVWR) must have an adequate reserve capacity, first. Second is that to find the best pressure was to weigh the vehicle and use axle averages to set pressure against the manufacturer Load & Pressure Table (not ever going over or under the Vehicle manufacturer recommendations) and adjusting for changes in climate & terrain as necessary; hot weather to cold weather.
The vehicle manufacturer doesn't want you to have an unnecessarily hard ride, nor to transmit extra shock to the vehicle. Shock absorbers have their [important] role, and chassis bushings theirs. It is all supposed to work together. We change the pressure mainly when we change the load, and that's the only "good" reason (is a way of seeing it).
Trailers, mainly at low speeds, experience sidewall deflection differently than cars or trucks. They can wind up with one or more tires really pushed hard into a position. Certain kinds of turns, and a heckuva lot of parking. Sometimes it is not obvious. On tandem and tridem axle trailers this is more of a concern.
Going down the road the TT is never master of its' fate, so to speak, as is a car or truck. It is always being pulled (it could be pushed, also) and the forces that allow a car, say, to "relax" don't work out for something at the end of a 20' pole pushing or pulling it (as it is almost not ever perfectly aligned with the force pushing on it). And then it sits having been levered into that position. Days, weeks, months.
And the transient thing I tried to do above. Sideslip angle is when we get into the forces acting against the trailer to lose it's grip on the road. Markdoane made reference to one of Bundorf's SAE papers [1965] in a post/thread a few years back (that is good reading). Stiff sidewalls make for longer life and predictable road manners is, again, my understanding (even if it is only information posing as knowledge).
Philosophically, I'm interested in the worst-case scenario: tired, ill, injured driver on dark night, in rain, inadvertantly at too high a speed. Broken or potholed pavement coming up (unawares) with a-hole drivers around the rig and the need for hard maneuvering coming up. Braking. Downshifting. All the dice rolled. So, hitch, tires, vehicles are not what I want to worry about having made compromises upon, and am now reliant on driver skill to get me out of it. Confidence cannot be overstated, and it is my experience (personally and professionally) that this confidence in the rig itself that gives the margins one needs (for lack of a better term) when the moment is upon us.
I may say that I will not ever drive under any one of those circumstances, but it is my preference that rig and driver perform admirably if called upon to do so.
So if the tire engineers are adamant, I'm fine with it. Tire quality via brand is more my interest now (as a method of determing size and load has better tools available). Henceforth I want to ask my questions from established baselines, hitch rigging or tires. Numbers. No different than in engine performance parameters.
That's the best of my understanding. Jammer would do a better job.
I got as much work done around that house as budget allowed. And a bit more. Things changed quite a bit for us over just a few years. I did repaint the exterior in a job I was quite proud of (revealed details formerly hidden). Letting that trailer go hurt to some extent, but a rear bedroom model was greatly desired, so a combination of circumstance, opportunity and different responsibilities made selling it a fairly easy decision.
Glad you liked it. A nice one for condition when we bought it, and the renovation showed it off nicely. Thanks. They're an excellent choice when an otherwise original one can be found.
Old 03-23-2012, 07:45 AM   #123
Spring , Texas
I e-mailed Barry (tiretech) regarding ST Tires and his chart and provided him with the following parameters:
"After reading your comments on the RV Forum and studying your spreadsheet for ST tires, I wanted to say thanks.
We have a 2008 19’ Airstream single axle with the following dimensions:
GAWR – 4300#
GVWR – 4500#
The trailer came with Goodyear Marathons ST225/75R15 LRD (2540#)."
Here is his response; straight forward and concise (good engineer):
"If you followed along at the beginning of my web page, I said you needed to weigh your trailer - and that you should pick the worst tire as the one you need to determine the tire load needed.
Your email below reports the tire loads as axle loads - and in that case, I said to use 110% of that value. That means the tire load your are trying to match is 110% of the GAWR = 4730# or 2365# per tire.
The maximum load carrying capacity of an ST225/75R16 LR D is 2540 and I'm recommending using no more than 85% of that = 2159#. That's smaller than 2365# so you need to move up to a Load Range E and use 80 psi, if the rim will handle it. That will give you about a 20% reserve capacity."
Serious "margins" (reserve) built into his logic and calculations.
Ed
Old 03-23-2012, 09:28 AM   #124
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
And the point should not be missed -- as in several posts back near the beginning -- that individual tires may be off from off others by as much 30%. So one needs to find that out. Wheel-by-wheel.
Old 03-23-2012, 09:51 AM   #125
Master of Universe
Gene's Avatar
Rednax,
First of all, the SS you had was a classic trailer that made me wish I had been looking for it when it was for sale and it was in my driveway right now. But I already had a trailer. The interior is warm and homey and I like that feel. Of course, as soon as I got it, I would be remodeling. The big difference in feel is that all the cabinets and partitions in ours are a light colored Formica that looks like fake wood—there's no warmth in that. But we keep working on it.
But I digress, as usual…
Your answer to my question, as I dissect it, seems to boil down to this: "Trailers, mainly at low speeds, experience sidewall deflection differently than cars or trucks." Thus, higher pressure is safer. I'm unsure it would be any different at high speeds, but maybe more noticeable at low speeds and especially when backing. And, basically, tire engineers say that and they should know. I am something of a skeptic and believe experts aren't always right, maybe less wrong than the rest of us. I can see the point for higher pressure, but am not sure it matters not I am sure it is correct. It is best to rest this question for a while.
I like the worst case scenario except that oil on black ice on a blind curve would be even worse. I think someone had a thread last year where that's what happened and they crashed. But in that situation no tire could help. Of course, your point is that you want a big margin of safety and I concur. Everyone has moments of non-attention, tiredness, and we may come to a bunch of vehicles going slowly or not at all on a blind curve, perhaps in bad weather, and we have to use all of that margin. So overdoing it is a good thing because the moment may come when we need everything we can get.
Thanks for your explanation. Because you look at numerous factors when you analyze a problem, your posts are always complex and require some thought. I like the intelligence that goes into them. I think I would feel very safe as a passenger in any vehicle you were driving and I can't say that about a lot of people.
Gene
Old 03-23-2012, 10:41 AM   #126
DKB_SATX's Avatar
1976 Argosy 28
Re: tire deflection vs. speed... I think the assumption is that at higher speeds one is generally going in a straight line or only making gradual turns for lane changes and following curves.
— David
She's Cheap and Trashy Bambified 1961 - 1963 Bambi 85 05-16-2017 03:20 PM
'75 Argosy for salvage and parts drauchenberg Argosy Motorhomes 9 02-01-2013 10:48 PM
Tambour On Kitchen Cabinets Hard To Open and Close JillyBean63 General Interior Topics 6 02-25-2012 07:55 AM
Problem w Gaskets on rear door storage access starcraft Exterior Storage Compartments & Access Doors 5 02-23-2012 04:16 PM
Fridge not running on shore power bike_addict Refrigerators 7 02-21-2012 01:48 PM
