Old 01-10-2006, 04:08 PM   #1
1980 28' Excella II
bainbridge island , Washington
axles
Hello Andy: I have worn torsion bars on 28` excella. Will new axles fix my problem of all tires rubbing against inner wheel wells?
thanks, jerry
woodnhair is offline   Reply With Quote
Old 01-10-2006, 04:39 PM   #2
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
Jerry, what do you mean by "inner wheel well"? If the tire sidewalls are rubbing on the inside of the wheelwell toward the interior of the coach, then the tires you have on are too wide for your particular coach, and need to be switched off for narrower tires. If the tread is rubbing on the top of the wheel well, then an axle replacement is definately in order provided that the tires you have are stock size and height. You can usually tell whether or not an axle is worn out by the amount of tire sidewall visible between the top of the wheel rim and the bottom of the wheel well trim. There should be at least a couple of inches of sidewall showing. More is better.
Roger
Old 01-10-2006, 05:52 PM   #3
Woodnhair
Our computers have been down for 2 weeks, and they quite well may be down for another week.
If the rubber rods in your axles have deteriorated, that in itself will not cause the tires to rub on the wheel wells.
What size tires are on your Airstream? What year is your Airstream?
Old 01-11-2006, 12:30 PM   #4
1980 28' Excella II
worn torsion bars?
I LOVE this forum, what a great community. Coach is 28`1980 excella.tires are rubbing near top just an inch below where tread starts. tires are st225x15 marathons.wheels are 6" with 0 offset. Torsion bars are horizontal or pointed up a little looking to rear. I`m sure the coach will ride a little higher with new axles but hard to imagine enough to give 2 or 3 " clearance.
thanks,jerry
Old 01-11-2006, 04:01 PM   #5
Somewhere , Indiana
It is true!
thanks,jerry
Jerry,
It can gain you 2 or 3" - truly!
See:
http://i.b5z.net/i/u/1080235/f/Torfl...ation_4-04.pdf
Look at the #10 axle.
Regards,
Henry
axleman is offline   Reply With Quote
Old 01-11-2006, 10:13 PM   #6
1980 28' Excella II
I am talking about 2 or 3 " clearance on the inside of the tire, not the top, which would help also.
what's the difference between the dexter and hunschen axles?
Is it possible I have a pair of short axles????
jerry
Old 01-12-2006, 07:10 AM   #7
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Jerry,
Did you buy this coach new?
Perhaps someone installed axles with a wrong hub face dimension before.
It would help tremendously if you could post some photos.
Also, do the axle tubes have a slight bend in the center? If not, then there's no camber for the wheels, which means they could possibly rub at the top if the clearance is wrong in the first place, and the coach is loaded down.
If you do replace axles, then please go to a specialist with this one. Buying the exact same axles again will give you the exact same problem, in all likelyhood. If not right away, then soon enough.
We need to see pictures of where the tire rubs, from both the tire inside, and the rub mark on the inner wheel well. Also, of the torsion arm and frame, and of the other side with the tires on, to see how far inside the tires sit. Then, a shot of the area of the axle mounting plate where the axle mounting bolts are.
Sounds to me more and more that at some point there was an unscheduled axle job donw, perhaps with the wrong axles.
Uwe
www.area63productions.com
Old 01-12-2006, 11:12 AM   #8
1980 28' Excella II
Ewe: Bought trailer in Tucson in april '05. Owner deceased. Had axles bent last mo. and also re-alighned.
Have never sent photos but will try.
jerry
Old 01-12-2006, 12:21 PM   #9
steelbird312's Avatar
1956 22' Safari
2000 39' Land Yacht XL Diesel w/slide
Crossville , Tennessee
Images: 11
Jerry,
Just last week, I helped a friend (on this forum) put new axles on his '70 Overlander. I am not positive if your dimensions are the same as his as you did not post the year model of your trailer, or I missed it; his dimensions were as follows. Hub face to Hub face, is 79 7/16". The mounting brackets welded to the axles ar 61 1/8". These dimensions gave him beautiful clearance front to back and inside to outside. He used Dexter axles for two reasons. Dexter has a place 35 miles from our home, and the cost was right at half what they would be buying Henschens from the supplier. He useda #11 with a #3700lb rating so as to receive the 12 inch brakes/drums. Heused the 22.5 degree down on the start angle. It sits up nice and pretty now.
Not trying to talk you into anything, just telling you what he did and the results.
steelbird312
2000 390 Landyacht XL
1989 29' Excella
WBCCI #6673 jerry Hodge
Have no intention of arriving at the grave safely, but rather to skid in sideways, chocolate in one hand,throttle in the other, totally worn out and screaming
"WOO HOO, WHAT A RIDE!"
steelbird312 is offline   Reply With Quote
Old 01-12-2006, 03:50 PM   #10
Somewhere , Indiana
A lot of $$$$
jerry
Jerry,
Henschen axle $800.00 each + shipping + packaging
Dexter axle $350-$450 each + shipping (no packaging)
Do the math and the Dexter is about $350+ less expensive. Is the quality of the Henschen worth it? Airstream doesn't seem to think so, as they now use Dexter. The choice is yours!
Just two cents from a RETIRED axle man!
Regards,
Henry
Old 01-12-2006, 06:05 PM   #11
1980 28' Excella II
Thanks gang: Interesting numbers for axle length,,,,,will check mine. waiting for decent light to take some pics of wheel wells and axles. It's raining like mad here in western washington.
Steelbird................coach is 28' 1980 excella
Old 01-13-2006, 03:58 PM   #12
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Hang in there Jerry. The rain will stop soon. I've seen some news on the rainn and you sure have gotten more than normal. Wish you could send some here.
Anyway, do be accurate in all of your measurements. I may also suggest upping the weight carrying ability for the new axles if you get new ones. Not by much maybe by 10% from the old rating.
Henschen was the original equippment for your unit. And it is your unit so if you want to keep the same manufacture or change that is totally up to you. Just feel comfortable in your decision.
>>>>>>>>>>>>>Action
Action is online now   Reply With Quote
Old 01-13-2006, 09:55 PM   #13
Somewhere , Indiana
jerry
Jerry,
I thought you said earlier (in post #4) that "new axles would make the unit ride higher" - I thought that you were indicating up and down with the word "higher" - not side to side - my mistake!
Henry
Restoring Torsion Arm/Axle Resiliency Roadanswer Axles 11 10-11-2009 07:58 AM
Reese Dual Cam Trunnion Bars dscluchfc Hitches, Couplers & Balls 17 04-21-2005 05:52 AM
1974 Excella front window docu post john hd 1973-1974 Excella 500 22 08-06-2004 01:53 PM
Axle replacement question-are they really worn out? oldvws Axles 1 12-30-2002 08:04 AM
proper rivet gun for AS oldvws Ribs, Skins & Rivets 12 11-23-2002 09:04 PM
