Old 05-29-2015, 12:10 PM   #15
1996 25' Excella
Tillsonburg , Ontario
The main thing I would be checking is weather you have a ton of 'stuff' in the trailer all the time. Then an extra 500 lbs of water might be taking you to the limit. If you start out with full water and empty holding tanks then the same weight will be distributed from water to holding tanks, so net zero effect other than where the weight is now located (in front of the axles?). If however you refill with water then you could theoretically have 1000 lbs of water weight! That I think is obviously a problem.
JCW
JCWDCW is offline   Reply With Quote
Old 05-29-2015, 12:14 PM   #16
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
Full water tank, Empty Main and Aux tank, and don't worry about it.
NavyCorpsman is offline   Reply With Quote
Old 05-29-2015, 05:54 PM   #17
Dan and Lynda
2012 28' International
Bremerton , Washington
I almost always pull with the fresh water tank full. Some say you get better fuel economy with an empty tank. Well the math is a 28' International weighs about 8000 lbs fully loaded. The fresh water tank is 39 gal at 8.7 lbs per gal, that means a difference of 340 lbs between full and empty. It wont make a difference full or empty. As for weight, it rides better with a full fresh tank and you have water when you need it. The axels are rated for much more than what the trailer weighs.
The Cralls is offline   Reply With Quote
Old 05-29-2015, 06:01 PM   #18
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
He's a restorer and probably is aware of the older Airstreams that had issues with the frame near the rear bath of those trailers. Those models when carrying water could develop cracks in the frame. Airstream has a fix for that specific problem which is also called tail end droop.
The new trailers are engineered to carry a specific amount of weight on the axles and your tanks most likely sit over the axles which is perfect for weight distribution. Full tanks alone will not stress your axles. They are engineered for that weight.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 05-29-2015, 06:01 PM   #19
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Quack! Airstream builds our ships to be towed with full tanks! They tow better, and are engineered to do so!
You'd better look for a more sound source of info and leave that "restorer" alone!
Old 05-29-2015, 06:27 PM   #20
1976 31' Sovereign
Oswego , Illinois
On my 1976 31 AS water tank sits spanning both axles so no prob. of weight. In my opinion floor rot is caused by fiberglass insulation between frame and sides. One cause is lower belt line covers bannana wrap and sides joint. Sides go under wrap huge area to funnel water into insulation gets wet floor rots. My water heater drains on to floor then into wraps. floor rotted small portion in closet, insulation was wet many mos. after draining heater. Any leaks fiberglass gets wet will not dry. In my opinion insulation is not needed in this portion of floor
Old 05-29-2015, 06:44 PM   #21
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Twin Rocks , Oregon
Originally Posted by interstateflyer View Post
I was told recently by a travel trailer restorer that I should avoid towing with the tanks full on my 2014 23D. He said that I could damage my axles and that Airstream warns owners about the potential.
I find the need to travel with a full water tank when dry camping and a partially filled water and full waste tanks until we reach a dump station.
Is there any truth to this concern? What have you experienced?
If you ever need any work done on your trailer, I would not put the restorer who told you this at the top of the list.
Old 05-29-2015, 07:06 PM   #22
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
If you're pulling with the proper TV, tanks don't matter, full or empty. When you're pulling with a wimpy TV, that is underrated & insufficient regardless of who set it up, but you think it's ok, well, beware!
I see these on the Interstate & I really don't care about your safety but it gives me pause because you are jeopardizing mine. If you can afford the Airstream do the right thing & buy a truck & stop work worrying about what's in your tanks.
Mrjkq is offline   Reply With Quote
Old 05-29-2015, 08:52 PM   #23
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Full fresh... Empty gray, a couple gallons in the black to keep "things" fluid and flowing... Water is the best solvent!
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-31-2015, 12:52 AM   #24
interstateflyer's Avatar
2017 25' International
Los Osos , California
He mentioned it in passing. I thinks I've found more than enough validation that towing with a full water tanks is not only OK but beneficial. Thanks everyone.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 06-01-2015, 07:01 PM   #25
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
It was suggested to me in the beginning to put about 4 to 5 gallons of water in each of the gray and black tanks along with the Eco Smart holding tank additive after each dumping. The sloshing from water movement when under way keeps "stuff" moving in the tanks.
We refill the fresh tank before departure so the tires are not supporting as much dead weight while in storage.
Old 06-01-2015, 07:27 PM   #26
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
WE have always towed our 77 with full fresh water tank. No aware of any damage. Although because of the BIG C we have not towed in two seasons but hope to get back at it this summer.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Axles Axles Axles GeocamperAS Axles 33 11-20-2015 12:01 PM
'Convert' from 30# tanks to 40# tanks HeavyAssault LP Gas, Piping, Tanks & Regulators 19 11-28-2013 11:42 AM
Damage with old axles? Ag'71 Axles 13 01-31-2010 09:42 AM
LP Gas Tanks: Replacing 20# with 30# tanks? Pete Vermont LP Gas, Piping, Tanks & Regulators 28 01-30-2008 08:34 AM
