Old 01-04-2011, 07:56 PM   #1
1954 25' Cruiser
Marshfield , Massachusetts
Will a torsion axle fit a '54 AS?
My new to me 1954 Cruiser has the original axle w/leaf springs. I plan to completely refurbish the trailer so I'm sure the weight will increase. Based on that part of my plan is to upgrade the axle. I like the idea of a new modern torsion axle but don't know if these are basically a remove the old and replace with new on a 1954. Would it just be a bolt in replacement or would any modifications be required on the 54, in order to install a torsion axle?
Thanks. Don...
54 Cruiser
http://www.donsbushcaddy.com
54Cruiser is offline   Reply With Quote
Old 01-04-2011, 08:24 PM   #2
Thanks. Don...
Remove the old parts from the frame, and weld the new axle in place.
That's it.
Old 01-04-2011, 08:29 PM   #3
pbearsailor's Avatar
Port Hadlock , Washington
Hi Don and welcome to the forums.
I switched my '57 Caravanner from leaf to torsion. You can see some pics of that in my thread link at the bottom of my post.
Not a big deal to do. You'll have to have a mounting plate made up and welded to the frame and then it's a bolt on from there.
BTW, nice looking airplane. Old homebuilder here too, Long EZ many years ago.
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 01-04-2011, 08:48 PM   #4
1954 25' Cruiser
Andy, thanks.
Steve, the airplane was a great adventure...but it's done nd I need another aluminum project so here I am.
I found the pics of your axle install, looks relatively straightforward. How did you know exactly where to weld those plates on the box frame? Do the plates come with the axle?
Don...
1954 Cruiser
http:www.donsbushcaddy.com
Old 01-04-2011, 08:56 PM   #5
I ordered my axle from Colin Hyde and he sent drawings for the mounting plate. I just used the old axle centerline to determine where the new one mounted.
-steve
Old 01-04-2011, 09:02 PM   #6
Benjo's Avatar
1949 18' Trailwind
Huntsville , Alabama
Idea: Perhaps having the original axle overhauled. I thought about replacing mine until I took it apart and saw that is was in amazing shape after 60 yrs. Not to mention the craftsmanship. And I may be speaking out of turn but they just don't make stuff like they used to.
All the best,
-b
Benjo is offline   Reply With Quote
Old 01-04-2011, 09:14 PM   #7
SteveH's Avatar
Common Sense , Texas
The tortion axles bolt to a vertical plate that is welded to the frames, and I'm almost certain your '54 would not have that plate. It would take some fabrication.
Regards,
Steve
Old 01-05-2011, 01:26 AM   #8
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Don,
Whatever you do, don't weld the torsion axle onto your chassis. The correct way to do it is to fabricate mounting plates, like the 60's era & newer Airstream's & have them welded to the chassis by a competent welder, then bolt the new axle to the plates. That way, you or a future owner will be able to easily remove the axle if anything happens to it thoughout it's life. As Steve said, I can supply you with a drawing to have the plates fabricated free of charge & you can order an axle through me or another supplier. Welding a torsion axle on could cause internal failure to the rubber cords & will definately void the warranty. I have done numerous conversion/upgrades like this & they work really well.
Good luck with your project,
Colin
Colin H is offline   Reply With Quote
Old 01-05-2011, 05:06 AM   #9
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
Absolutely correct and vital to note. Welding directly on a torsion axle mount can transfer enough heat to damage the rubber.
Weld mounting plates to frame. Bolt torsion axle(s) to mounting plates. Alignment of the plates needs to be carefully measured, as there are limits to how much you can align the axles once they're bolted in.
TX-16
Dave Park is offline   Reply With Quote
Old 01-05-2011, 07:54 AM   #10
welding axles
As long as the raised axle mounting bracket is installed on the torsion axle, that part of it can be welded onto the frame.
Airstream did that with most of the 1961 Henschen axle installations.
Henschens original warranty was not voided in any way if that bracket was welded to the trailer chassis.
It would be near impossible to generate that much heat from welding the top part of the axle bracket, unless the welding was done with a torch, to ruin or even disturb the rubber rods.
That was Henschens warranty policy for the entire almost one half century in business.
As a matter of fact, the shock brackets were always welded in place, on the torsion arms, by Henschen, after the axle was assembled. Photo's on our web site, clearly show that.
Understandably, if any welding is done to the axle tube, that indeed will void the warranty.
Old 01-05-2011, 09:07 AM   #11
Dave Park's Avatar
2005 22' Safari
The shock mount is attached to the arm, which is a high mass piece allowing heat to travel in many directions. This distributes heat over a large volume. The mounting bracket is a low volume plane that transfers temperatures easily over 450F 2" away - within reach of the rubber cords. This was highlighted to me just last week in welding class, as we were being warned about damaging engine mount rubber through heat transfer.
The symptom of heat damage would not be visible or observable, but is a change of axle rating as the cord melts and slowly re-solidifies. Any time rubber goes through this process it loses elasticity.
There are other reasons not to weld directly. Airstream did this for less than a year before adding the mounting plates - a very rapid design modification considering this is Airstream we're referring to.
Airstream often does things that axle manufacturers do not support or encourage. For example, Dexter strongly cautions against the use of torsion axles where three axles are used, and will not honor warranty claims for triple axles.
Axle side mounting plates that will fit Henschen and Dexter axles are available directly from Dexter. #10 is part A/P-166-00 and #11 is part A/P-167-00.
Hope this helps the original poster.
TX-16
Old 01-12-2011, 04:53 PM   #12
1964 22' Safari
1962 28' Ambassador
enosburg , Vermont
If you attach a torsion X to an A.S. frame that was designed for a leaf spring X without the added support of the vertical mounting plate you are expecting the frame to support the weight of the coach on a bearing surface of 3.5 inches, the width of the torsion beam. With the leaf assembly that same weight was spread out over the aprox 30 inches between the spring shackles. The frame rails are to light to withstand 5/8 bore holes to direct attach the the mounting plates welded to the new torsion X, and welding X to frame is debatable. For an extra 100 bucks in the plates you can bolt up like an original torsion X and forget it. No frame failure. We did this on one. A tip. Before removing the original X hold a plumb bob agianst the frame to find the ctr line of the X spindle, mark the frame for a referance point. The old spring X traveled almost straight up & down. The new torsion X travels an arch. Befor you cut the slots in the new frame plates to recieve the new torsion X be sure you have clearance for tire travel in the rear of the wheel well.
putback is offline   Reply With Quote
Old 01-12-2011, 07:20 PM   #13
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
For whatever it is worth, I had a 54 Safari. I replaced the original 4 inch drop axle with a straight 5200 lb Dexter axle, retaining the original springs and turning new nylon bushing for the spring eyes.
The reason I went to a straight axle is those trailers were very low to the ground. The axle cost less than a dropped hitch bar when you factor in the value of new brakes and drums
Also Andy is correct that in 61 Airstream did weld the axles in place. That is the way my tandem 61 tradewind is. Of course if I ever replace those axles it will take some fabrication to bolt the new ones on.
I find no particular advantage to the torsion axle other than increased ground clearance and have plenty of towing experience with both.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 01-12-2011, 09:43 PM   #14
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Originally Posted by RickDavis View Post
....I find no particular advantage to the torsion axle other than increased ground clearance and have plenty of towing experience with both.
I suppose the advantage is ride quality.
The disadvantage is cost. Both in initial expense and over the life of the trailer. Torsion axles are way more expensive than a leaf spring axle.
>>>>>>>>>>>>Action
Axle, where to buy submariner Axles 26 01-01-2011 02:12 PM
