Originally Posted by Canoe stream
Henry -- I'm sure I could find it but please jump start me on the location. Thanks
Canoe stream,
I think you're looking for the serial number tag correct?
Typically, these tags are located on the main tube body of the axle. I know Dexter and Axis locate these tags on the center of the axle beam facing the front of the coach. They usually contain the following information:
1. Axle Manufacturer
2. Axle Manufacturer address
3. Axle serial number
4. Axle capacity
5. CSA approval (if built to CSA spec)
Older axles used a serial number band, embossed and wrapped around the axle tube. Some manufacturers also stamped numbers into the axle tube itself.
I hope this helps,
Henry
PS: This info is required for any warranty work required on the axle. The industry standard torsion axle warranty is 5 years from date of purchase. Additionally it is of great help when seeking replacement parts.
