Old 07-28-2014, 01:38 PM   #1
Hittenstiehl's Avatar
1961 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Where to look for the (original) Axle tag?
Our 65 Tradewind needs new axles. We believe they may still be the originals. Where do I look to find the tag that may still be on there to find the specs or nomenclature.
Thanks in advance
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 07-28-2014, 01:45 PM   #2
87MH's Avatar
1978 31' Sovereign
Images: 292
Originally Posted by Hittenstiehl View Post
... Where do I look to find the tag that may still be on there to find the specs or nomenclature....
Look in the middle of the tube, either on top or on the front of the square tube.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 07-28-2014, 01:47 PM   #3
1961 28' Ambassador
Mesa , Arizona
Thanks, will give that a try.
Hittenstiehl
Old 08-04-2014, 09:27 AM   #4
1961 28' Ambassador
Mesa , Arizona
Before we headed out this weekend we rolled underneath to look and did not find any Axle tags, nomenclature, serial numbers or specs. So our tag if it's still there, must be on the top. Could not see on top as the fit is to tight.
We'll likely be doing that project next. 14 miles of not so great Forest Road takes a toll on the interior. Thanks for your tips and input.
Hittenstiehl
Old 08-04-2014, 09:44 AM   #5
No need to find the tag.
We have all the axle specs used on Airstreams since 1961.
The trailer serial number is the key.
Old 08-12-2014, 03:09 PM   #6
Robfromnorth's Avatar
1973 25' Tradewind
Calgary , Alberta
Where to look for the (original) Axel tag?
That's ridiculously handy. Do you need to have the tag? On a tradewind could you not just get a set of 3500lb torsion axles and upgrade the brakes at the same time?
I'm in Calgary and the axle shop mentioned on these forums, Standens, manufactures axles and will put the dexter brakes on as well. Installed a pair of axles is $1500CAD. You can also sell the used ones if there is any value left in them.
Should I be hunting for a specific model or set? They knew what I wanted as soon as I said 73 Airstream. I confirmed torsion and that was that.
Robfromnorth is offline   Reply With Quote
Old 08-12-2014, 03:57 PM   #7
Your original brakes were 12 inch. Do not down grade them to 10 inch.
Also, do not increase the axle rating beyond 3500 pounds.
At this point of technology, "self adjusting" electric brakes is the way to go.
They cost a little more, but you no longer would need to be concerned about the adjustment.
Most Canadian owners have the axles shipped to someone in the US, and then pick them up there.
Saves shipping costs and duties.
1972 airstream **look**look**look** eBay Watch Airstreams on eBay 0 07-03-2010 05:20 PM
Tag axle shock rdm Mechanics Corner - Engines, Transmission & More... 8 07-10-2008 07:15 PM
Tag Axle Oil Level? swebster Airstream Motorhome Forums 9 08-25-2003 05:01 AM
Tag Axle Brakes cooperhawk General Motorhome Topics 1 06-23-2003 12:48 PM
Tag Axle Brake Controller winner Brakes & Brake Controllers 4 06-30-2002 08:47 AM
