Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Axles
Old 01-19-2015, 06:33 PM   #1
Sioux Falls , South Dakota
When to replace axles?
How long do the Torsilastic axles last on an Airstream? I've heard that 20-25 years is a good expectation. True?
Other than one breaking, what symptoms/signs should I look for to know that axle replacement is near?
David Lininger, kb0zke
AIR 54240
Heartland mpg 181 (sold)
1993 Foretravel U300 (sold)
2022 Grand Design Reflection 315RLTS
kb0zke is offline   Reply With Quote
Old 01-19-2015, 06:39 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Depends on the year of the trailer too. The 70's vintage apparently had a poor rubber compound and they wore out pretty quickly. The best way to check is jack the trailer up and see how much down angle there is on the arm. IIRC it should be around 22° on most trailers, some model years had slightly different angles. How long it sat vs how much it was used will have a bearing on it too. A trailer that was used regularly the axle will typically be in better shape than one that spent a lot of time parked.
IMHO 20 years is probably about the maximum life span of a Torflex axle.
Aaron
WBCCI #XXXX AIR #2495
Old 01-19-2015, 07:22 PM   #3
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
Go to the Inland RV website and read Andy's article on axles. I was a non believer until last year when I had one wheel snap off just as we pulled into Aberdeen SD. I replaced all 3 axles, and couldn't believe the difference in ride. Nothing in the trailer moved, no drawers open, on the way home it was like pulling a different trailer!!! If you need axles replaced and are resonably close, I highly recomend Specialty Manufacturing in Bath SD. Great people to work with and resonably priced.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 01-19-2015, 08:53 PM   #4
Rolland's Avatar
1967 30' Sovereign
Chiefland , Florida
Just an additional thought-when checking your axles, and you don't get a lot of movement, your shocks may be rusted solid as mine were. No sag, but no movement either. I replaced the shocks and axles both.
Rolland is offline   Reply With Quote
Old 01-19-2015, 10:05 PM   #5
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
If you can't see the top of your tires, it may be time. If you see a lot of the top of your tires, you probably have a while to figure out the angle of the dangle formula of the hypotnuse wrapped around the tongue in the up positioni at 22 degrees on the soltice meridian. or is it 35 degrees for the 5th trailer made on the firth of fifth Saturday of the Saturni when you've properly jacked your trailer, not improperly jacked your trailer mind you, or you'll do permanent damage to said Axles and the Box Tube frame also for having done the improperly jacking of same said Trailer.
got that? Repeat after a few more Jack
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 01-20-2015, 11:37 AM   #6
1966 24' Tradewind
2005 22' Safari
Bastrop , Texas
the original axles under our 49 year old AS are functioning flawlessly :-)
dannydimitt is offline   Reply With Quote
Old 01-20-2015, 12:07 PM   #7
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
I am seriously considering changing mine out. They look and perform great, but they are 37 years old.... I would rather replace them in my driveway rather than somewhere in the great unknown
NavyCorpsman is offline   Reply With Quote
Old 01-20-2015, 03:38 PM   #8
"I would rather replace them in my driveway rather than somewhere in the great unknow[n.]" So, is this a do-it-yourself project for a full-timer with no home base, or would I be better off having it done, perhaps as part of the sales deal? We're considering 30-34' WB coaches that are about 20 years old.
AIR 54240
Old 01-20-2015, 04:07 PM   #9
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
Replacing them yourself depends upon your ability and equipment. It is one of the things that I would not try myself. My father used this wisdom for years " There are things that you do yourself, and things that you get others to do for you. The wise man knows the difference." I will tackle a lot of things, but axle replacement in not one of them. Just my thoughts. Chris
ACI #7394
1994 Excella 34'
Hensley Hitch
Old 01-20-2015, 05:57 PM   #10
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I was 65 years old when I replaced both axles on the '74 Argosy. I worked alone.
Rolled one axle up on blocks. Removed the tires from the opposite axle. Removed the shock nuts. Removed the 4 bolts holding the axle to the frame. The axle was resting on a cradle I had fabricated for my floor jack. Lowered the axle.
Reversed the procedure to install the new axle and shocks.
I did soak the nuts with penetrating oil a day in advance.
It took about 5 hours on the first axle and just over 2 on the second.
I could have done both in 4 hours or so 30 years ago. But I am older and slower now!
Old 01-20-2015, 06:34 PM   #11
Thanks. I don't have a floor jack (don't have a floor, either), but I do have three bottle jacks, each of which could lift an Airstream. Sounds like I could make up some sort of cradle to do an axle at a time if I had to.
AIR 54240
Old 01-20-2015, 10:40 PM   #12
Vintage Kin
Fort Worth , Texas
Andy Thomson says a tridem is least likely to need new axles; rare enough to be memorable (paraphrased). His opinion and that of Inland Andy are worth your while.
I've read around on the tridem 34 for years as that will be my go to should something happen to my vintage kin. The low TW, low wheel load and outstanding road performance advocate for it.
That said, I am in favor of doing something like axle replacement with antilock disc brake upgrade ASAP.
Old 01-20-2015, 11:46 PM   #13
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
First thing I did was replace the axles,bearings,brakes,shocks,wheels & tires after dragging our 'new' '69 Tradewind home.
Andy at Inland RV shipped them and a bunch of other parts on a large pallet to my door via truck company.
I jacked up the AS and supported it on 4 jack stands and the tongue jack.
Removed the tires, used my transmission jack to lower the axle and slid it out from under the AS, then repeated for the second axle.
Then I cleaned and undercoated the wheel houses.
I used my engine hoist to load the new axle with new shocks attached onto my car dollies and Trans Jack then rolled it under the AS and lifted into place , bolted it in and hooked up the shocks . Then repeated for the second axle.
Next I installed the brakes & bearings hooked up the brake wires and mounted the wheels and tires and dropped the AS back down on the ground.
It took the better part of the first day to get the axles out and the wheel wells done and part of the next day to finish the install.
ID:	230819   Click image for larger version
ID:	230821   Click image for larger version
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 01-21-2015, 07:34 AM   #14
Regular Guy
1978 31' Sovereign
axle swap
"So, is this a do-it-yourself project for a full-timer with no home base, or would I be better off having it done, perhaps as part of the sales deal? We're considering 30-34' WB coaches that are about 20 years old.
Larry,
It's not hard to do. It involves a little heavy lifting, wrestling, and some serious grunting. Just some wholesome, healthy fun guy (or gal) stuff.
I built my 20' utility trailer from the ground up using 12K Dexter axles.
I have also assisted my friend that has a fleet of 15 or so trailers on general maintenance and axle swaps. a typical axle change out takes about 3 hours or so.
If you have access to a concrete surface, a transmission jack, some good jack stands , pneumatic tools, and a couple of young farmhands its really a straight forward operation.
As I age, I like the idea of being the Safety Supervisor / Foreman.
I don't know what the going rate is for the work, but I would charge 300 - 350 to do it (2 axles).
Let us know what you did and how it went.
Clayton
Old 01-21-2015, 07:53 AM   #15
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Based on my conversations with vintage Airstream people I have concluded that axles should be replaced every twenty years or so unless there is an obvious failure which would necessitate an earlier replacement. There will of course be one or two owners out there who swear that their axles date back to the Civil War and work just fine.
Bob Martel
WBCCI# 5766
Old 01-22-2015, 08:15 AM   #16
Regular Guy
1978 31' Sovereign
I took a look at the dexter torflex axle page and they recommended changing if:
When jacking the axle, if it the wheel DOES NOT drop 3 inches, the elastomer is weak and the axle should be changed.
Learned something new today.
Old 01-22-2015, 01:41 PM   #17
2007 22' International CCD
Very useful non-destructive way to verify condition. Thanks!
Old 01-23-2015, 06:15 AM   #18
Starstream's Avatar
Spring , Texas
What do you do with the old axles and shocks?
Starstream is offline   Reply With Quote
Old 01-23-2015, 06:28 AM   #19
Always learning
Lance M's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Lance M
Scrap metal recycler
Take them to a scrap metal recycler. They are worth $0.075/lb.
You can also sell them on CL to someone that is looking for axles for his shop built utility trailer or BBQ.
Lance
Lance M is offline   Reply With Quote
Old 02-04-2015, 09:54 PM   #20
johnnywood's Avatar
1978 31' Sovereign
1968 24' Tradewind
Salem , Oregon
Thanks for the inspiration! Glenritas,I feel that I can confidentially replace my axles myself now that I have seen all your photos and descriptions.
johnny
johnnywood is offline   Reply With Quote
Axles Axles Axles GeocamperAS Axles 33 11-20-2015 12:01 PM
To replace or not to replace the axles airstrmkids Axles 17 01-13-2011 06:20 AM
Replace axles on 1976 31' adonh Axles 32 01-28-2009 02:41 PM
